i've added support for thumbs to the static map list. i will include an include file when i commit to svn. i also have created thumbs for most maps. the ones missing were invalid links so you will now by looking if you use a thumb panel for map selection.
map panel with map pack:
current conditions showing the notification.
that looks very nice Nuka1195.
makes me want to do some more skinning myself with the weather.com plus plugin. :-)
please do. if you want the <content> include file. i will upload now. i didn't see in your home where you can select a map. i could just post the py script i use to create it. let me know which you prefer. it would be eassier to modify with the py script.
actually i think i will commit my changes to the script now, even though it's still being modified.
i'll put the thumb pack in svn also.
it's about 10MB zipped. i'm not shure if it should be included with skins or not. it doesn't have to be to work. i added support for a couple settings skinners can use.
here's a sample of the content file there are three includes for the three map lists. it will take me til this afternoon to get it in svn.
PHP Code:
<includes>
<include name="MapsList1.Content">
<content>
<item>
<label>$INFO[Window.Property(MapList.1.MapLabel1)]</label>
<icon>$INFO[Skin.String(Weather.MapIconPath)]$INFO[Window.Property(MapList.1.MapIcon1)]</icon>
<onclick>SetProperty(Weather.CurrentMap,$INFO[Window.Property(MapList.1.MapLabel1)])</onclick>
<onclick>$INFO[Window.Property(MapList.1.MapOnclick1)]</onclick>
<visible>!IsEmpty(Window.Property(MapList.1.MapLabel1))</visible>
</item>
<item>
<label>$INFO[Window.Property(MapList.1.MapLabel2)]</label>
<icon>$INFO[Skin.String(Weather.MapIconPath)]$INFO[Window.Property(MapList.1.MapIcon2)]</icon>
<onclick>SetProperty(Weather.CurrentMap,$INFO[Window.Property(MapList.1.MapLabel2)])</onclick>
<onclick>$INFO[Window.Property(MapList.1.MapOnclick2)]</onclick>
<visible>!IsEmpty(Window.Property(MapList.1.MapLabel2))</visible>
</item>
no rush, i'm currently busy adding the pvr stuff to the skin so it'll be another week before i get to the weather part.
i'll keep an eye on whatever you commit to svn.
as for the thumb pack, would it be possible to include it in the plugin instead of the skin?
10 MB is a little big, but i will add a download button in the plugin settings to grab it, then the user has easy access and it doesn't bloat the plugin.
aaarghh, this plugin gets more and more amazing Nuka! Excellent work!
That should be badly supported by Confluance.
Quote:[weather.com plus]
-changed: version -> 1.2
-changed: English language strings
-changed: speedups and eliminating the need to repeat tasks
-added: customized maps list (WIP) *see (resources/samples/sample-user-defined-maps.udm)
-added: MapList.(1-3).MapIcon.(1-3) for static content lists (allows for thumbnails and panel containers, optional Map Icon Pack available. install from settings)
-added: more properties see first post
-added: new settings for alert notification, custom maps file (WIP), install map icon pack
-added: addons manager to handle the install
i'll update the first post tomorrow with important updates/changes and links to helper files
some images to show what can be done
current w/ 7 day
36 hour
weekend
settings
Map w/opt skin settings
map panel w/icon pack
Alerts
video US only
updated 1st post: 12/21/2009
very nice work indeed thanks for the continued updates. The Confluence screenshots look fantastic.
Could you please post your files for modifying confluence theme as shown in your screenshots?
By the way the link on the first page for the PMIII files is dead.
thanks,
link is fixed.
the confluence skin isn't finished. a couple views aren't done and i'm still tweaking it.
i'm taking a break from it for a little bit.
I look forward to the completed version. thanks
olympia and wstewart, i've packaged up my changes. i'm not releasing it publicly.
you two seemed the most interested. if you want to test it and let me know. there are navigation issues and 10 day and hourly views aren't done. i will email it to you.
just drop it in the confluence folder.
i won't be getting back to it until i finish some other things so. it could be a while.
Quote:
[weather.com plus]
-changed: version -> 1.2.1
-fixed: no video found for two worded states
-changed: removed calls to unneeded properties
-changed: added an id to the map download setting. this will display the RunScript() command until you download the map pack
*see http://forum.xbmc.org/showthread.php?tid=52034
minor fix
Hey, i'm surprised there's not more action in this thread. That's looking brilliant Nuka - looking forward for the updates
