Full Version: [RELEASE] Norwegian NRK Web-TV (Video) Plugin
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
(2013-12-29, 14:31)Senilix Wrote: [ -> ]Update:
Okay so i compiled XBMC master branch with the HLS patch. (vs2010/DirectX)
And now it plays the streams in HD! Smile success!
startup time is ok now. video is ok.
However.... after 30sec -> 2min i'm sometimes getting buffering issues... this seems to repeat at non regular intervals....
Is there anything that can be done with that?
can and wil you share this?
Sure.... if you install: http://mirrors.xbmc.org/nightlies/win32/...master.exe
and then copy my binary over.....
Hmmm where do you normally save Binary files....... can't attatch files here.........
(2013-12-29, 15:03)Senilix Wrote: [ -> ]Sure.... if you install: http://mirrors.xbmc.org/nightlies/win32/...master.exe
dropbox might be an option
XBMC with https / HLS patch
Install: http://mirrors.xbmc.org/nightlies/win32/...master.exe
And then copy my binary over.....
http://sarcon.palantir.no/files/XBMC.exe
(2013-12-29, 15:15)Senilix Wrote: [ -> ]XBMC with HLS patch
http://www.sarcon.no/files/XBMC.exe
Oops! Google Chrome could not connect to www.sarcon.no
this link does not work
same old Smile
Oops! Google Chrome could not connect to sarcon.palantir.no
Did you mean: palantir.­no
Hi. Love the plugin but recently having a problem with frequent buffering of NRK streams (not live). Whereas this wasn't an issue a week or so ago, all of a sudden XMBC is buffering every ten seconds or so whenever I attempt to watch NRK content. Note that I do not have this problem with other add-ons, such as the BBC iPlayer or Hulu, My network connection is 50 mbps, yet I am seeing the problem both on a Windows 7 box running XBMC as well as an ATV1 using Crystalbuntu. I can watch NRK content thru the website, but the quality is poor. Wondering if this is an issue with the NRK servers at the moment and whether others are experiencing the same thing, or whether i need to make some configuration change.
My debug log is here
http://xbmclogs.com/show.php?id=104839
Hi, great work on the plugin! My only problem is that while live radio works, live TV gives an error message telling me to check my log file. So, here goes. Look for "Skipping unplayable item".
The system is a 512 MB model B raspberry pi running raspbmc, installed today and (supposedly) up-to-date.
~/.xbmc/temp % tail -f xbmc.log
11:05:52 T:2865767488 NOTICE: disable service: surveil
11:05:53 T:2865767488 NOTICE: disable service: ftp
11:05:55 T:2865767488 NOTICE: disable service: samba
11:05:55 T:2865767488 NOTICE: disable service: vnc
11:05:56 T:2865767488 NOTICE: disable service: boblight
11:05:58 T:2865767488 NOTICE: enable service: ssh
11:05:58 T:2865767488 NOTICE: disable service: cron
11:05:59 T:2865767488 NOTICE: disable service: sabnzbd
11:06:01 T:2865767488 NOTICE: system settings from addon: {'sys.config.freq.arm': 850, 'sys.config.freq.gpu': 250, 'sys.config.freq.sdram': 400, 'sys.config.freq.core': 375, 'sys.config.freq.overvolt': 0, 'sys.config.decode.wvc1': '', 'sys.config.disable.overscan': '1', 'sys.config.decode.ac3': '', 'sys.config.freq.isp': 250, 'sys.config.decode.mpg2': '', 'sys.config.decode.dts': ''}
11:06:01 T:2865767488 NOTICE: system settings from /boot/config.txt: {'sys.config.freq.arm': 850, 'sys.config.freq.gpu': 250, 'sys.config.freq.sdram': 400, 'sys.config.freq.core': 375, 'sys.config.freq.overvolt': 0, 'sys.config.decode.wvc1': '', 'sys.config.disable.overscan': '1', 'sys.config.decode.ac3': '', 'sys.config.freq.isp': 250, 'sys.config.decode.mpg2': '', 'sys.config.decode.dts': ''}
11:07:17 T:2838377536 NOTICE: Thread Background Loader start, auto delete: false
11:07:19 T:2838377536 NOTICE: Thread Jobworker start, auto delete: true
11:07:21 T:2865767488 NOTICE: Previous line repeats 1 times.
11:07:21 T:2865767488 NOTICE: Thread XBPyThread start, auto delete: false
11:07:21 T:2865767488 NOTICE: -->Python Interpreter Initialized<--
11:07:21 T:2857378880 NOTICE: Thread Background Loader start, auto delete: false
11:07:27 T:2857378880 NOTICE: Thread XBPyThread start, auto delete: false
11:07:27 T:2857378880 NOTICE: -->Python Interpreter Initialized<--
11:07:33 T:2857378880 NOTICE: CommonFunctions-2.5.1
11:07:34 T:2865767488 NOTICE: Thread Background Loader start, auto delete: false
11:07:36 T:2857378880 NOTICE: Thread CFileCache start, auto delete: false
11:07:37 T:3040395264 NOTICE: COMXPlayer: Opening: https://nrk1us-f.akamaihd.net/i/nrk1us_0...m3u8?dw=31
11:07:37 T:3040395264 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
11:07:37 T:2857378880 NOTICE: Thread COMXPlayer start, auto delete: false
11:07:37 T:2857378880 NOTICE: Creating InputStream
11:07:37 T:2857378880 NOTICE: Creating Demuxer
11:07:37 T:2857378880 ERROR: OpenDemuxStream - Error creating demuxer
11:07:37 T:2857378880 NOTICE: COMXPlayer::OnExit()
11:07:37 T:2857378880 NOTICE: COMXPlayer::OnExit() deleting input stream
11:07:37 T:3040395264 ERROR: Playlist Player: skipping unplayable item: 0, path [https://nrk1us-f.akamaihd.net/i/nrk1us_0...m3u8?dw=31]
11:07:37 T:2857378880 NOTICE: Thread Background Loader start, auto delete: false
11:07:37 T:3040395264 NOTICE: COMXPlayer::CloseFile
11:07:37 T:3040395264 NOTICE: COMXPlayer: waiting for threads to exit
11:07:37 T:3040395264 NOTICE: DVDPlayer: finished waiting
11:10:21 T:3040395264 NOTICE: COMXPlayer: Opening: pipe://1/
11:10:21 T:3040395264 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
11:10:21 T:2744120384 NOTICE: Thread COMXPlayer start, auto delete: false
11:10:21 T:2744120384 NOTICE: Creating InputStream
11:10:21 T:2744120384 NOTICE: Creating Demuxer
11:10:21 T:2744120384 NOTICE: Opening audio stream: 0 source: 256
11:10:21 T:2744120384 NOTICE: Creating audio thread
11:10:21 T:2857378880 NOTICE: Thread COMXPlayerAudio start, auto delete: false
11:10:21 T:2744120384 WARNING: CDVDMessageQueue(video):Tongueut MSGQ_NOT_INITIALIZED
11:10:21 T:2744120384 NOTICE: OMXClock using audio as reference
11:10:21 T:2865767488 NOTICE: Thread Jobworker start, auto delete: true
11:10:41 T:3040395264 NOTICE: COMXPlayer::CloseFile
11:10:41 T:3040395264 NOTICE: COMXPlayer: waiting for threads to exit
11:10:41 T:2744120384 NOTICE: COMXPlayer::OnExit()
11:10:41 T:2744120384 NOTICE: OMXPlayer: closing audio stream
11:10:41 T:2744120384 NOTICE: Closing audio stream
11:10:41 T:2857378880 NOTICE: thread end: OMXPlayerAudio::OnExit()
11:10:41 T:2744120384 NOTICE: COMXPlayer::OnExit() deleting demuxer
11:10:41 T:2744120384 NOTICE: COMXPlayer::OnExit() deleting input stream
11:10:41 T:3040395264 NOTICE: DVDPlayer: finished waiting
11:10:41 T:3040395264 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
11:11:06 T:3040395264 NOTICE: COMXPlayer: Opening: pipe://2/
11:11:06 T:3040395264 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
11:11:06 T:2838377536 NOTICE: Thread COMXPlayer start, auto delete: false
11:11:06 T:2838377536 NOTICE: Creating InputStream
11:11:06 T:2838377536 NOTICE: Creating Demuxer
11:11:06 T:2838377536 NOTICE: Opening audio stream: 0 source: 256
11:11:06 T:2838377536 NOTICE: Creating audio thread
11:11:06 T:2857378880 NOTICE: Thread COMXPlayerAudio start, auto delete: false
11:11:06 T:2838377536 WARNING: CDVDMessageQueue(video):Tongueut MSGQ_NOT_INITIALIZED
11:11:07 T:2838377536 NOTICE: OMXClock using audio as reference
11:11:23 T:2718954560 NOTICE: Thread Jobworker start, auto delete: true
11:12:04 T:3040395264 ERROR: GetDirectory - Error getting /home/pi/.xbmc/media/Fonts/
11:12:04 T:3040395264 ERROR: GetDirectory - Error getting special://home/media/Fonts/
11:12:08 T:2718954560 NOTICE: Thread Jobworker start, auto delete: true
For those of you with a Raspberry Pi:
There is a build of RaspBMC just out that will play HLS streams using HTTPS.
Plays fine on my RPI without stuttering, see some stuttering playing stored programs, though.
Check <http://forum.xbmc.org/showthread.php?tid=176043&pid=1593321#pid1593321>
And for those on Raspberry PI preferring Openelec, the latest Openelec by MilhouseVH also includes this patch. Tested quickly and seems to work!
Anybody have the Windows version with the patch? The links provided by Senilix don't work
@takoi. Tested and working on the RPI with the NRK plugin playing live streams as you've seen.
However... trying to play the same HTTPS streams through the PVR system using iptvsimple as the backend, it will not work. So I guess there's some other files to patch up to get that working?
I made a post here on the issue with a logfile:
http://forum.xbmc.org/showthread.php?tid...pid1604524
Any idea? Anything I should add to the PR3875?
(2014-01-19, 18:28)ProsjektX Wrote: [ -> ]@takoi. Tested and working on the RPI with the NRK plugin playing live streams as you've seen.
PR4083
Fyi the patch has been merge so builds as of yesterday will have fully working live streaming
Hi! Have been testing builds with this latest patch. On the Raspberry PI both NRK nett-tv and streaming through the PVR systems seems to work fine! Super.
However on the Windows builds, for instance the latest XBMCSetup-20140131-a4342cf-master.exe, which includes this patch, I can not get anything in the nett-tv to work, nor through pvr. Do you know of some breakage? Here is the log if of interest. I try to first play NRK1 through the addon, then try to play some other shows also, but nothing plays.
Hi.
Same issue for me when using XBMCSetup-20140201-fc8358e-master.exe.
Still no live stream (only sound when I choose "Play from here"), but now none of the other NRK clips will start anymore.
