(2017-08-14, 07:24)Snaah Wrote: [ -> ] (2017-08-14, 07:16)isitmeor Wrote: [ -> ] (2017-08-14, 06:57)asplundj Wrote: [ -> ]It is a different add-on that also support NRK and has the feature you're asking for. Check out http://www.rieter.net/content/
no it does not as it is named its for yesterday news
Huh? Did you follow the link and read what the addon Retrospect is? As previous poster said, among many channels it has NRK and the X-Forwarded-For feature you want.
[Written by my thumbs on a state-of-the-art Ericsson Hotline 450.]
did you get the NRK live streams working if so, do you live outsite norway and if so what are your setting for the NRK live stream setting
In country settings you need to set a Norwegian IP address (as Local IP) for Norway and then under Channel settings choose NRK and set Local IP to Norway
(2017-08-14, 14:20)asplundj Wrote: [ -> ]In country settings you need to set a Norwegian IP address (as Local IP) for Norway and then under Channel settings choose NRK and set Local IP to Norway
sorry to be such a pain in the ..but would you be so kind to post screenshots?
its for my 79 yrs old Norwegian dad who lives in the netherlands
(2017-08-14, 14:03)isitmeor Wrote: [ -> ] (2017-08-14, 07:24)Snaah Wrote: [ -> ] (2017-08-14, 07:16)isitmeor Wrote: [ -> ]no it does not as it is named its for yesterday news
Yes, I live outside Norway.
(2017-08-14, 14:30)isitmeor Wrote: [ -> ] (2017-08-14, 14:20)asplundj Wrote: [ -> ]In country settings you need to set a Norwegian IP address (as Local IP) for Norway and then under Channel settings choose NRK and set Local IP to Norway
Here you go! I switched to Norwegian in the system. All strings are not translated in Retrospect though. Hope this helps. If not, I suggest to continue in the
Retrospect thread.
(2017-08-16, 07:00)isitmeor Wrote: [ -> ]thanks but no thanksm no pictures
I fixed it now. Check again!
(2017-08-16, 08:33)isitmeor Wrote: [ -> ] (2017-08-16, 07:13)Snaah Wrote: [ -> ] (2017-08-16, 07:00)isitmeor Wrote: [ -> ]thanks but no thanksm no pictures
thanks
So did you get it to work?
Hei Takoi,
it doesn't work anymore under Libreelec Kodi 18 can you please fix it?
Øyvind
jeg fant min feil , alt i orden nå.
Is this plugin broken? I cant get it working under 17.6
20:25:06.721 T:140020824573696 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: 'NoneType' object is not callable
File "/home/kodi/.kodi/addons/plugin.video.nrk/main.py", line 21, in <module>
addon.run()
File "/home/kodi/.kodi/addons/plugin.video.nrk/addon.py", line 279, in run
plugin.run()
File "/home/kodi/.kodi/addons/script.module.routing/lib/routing.py", line 109, in run
self._dispatch(path)
File "/home/kodi/.kodi/addons/script.module.routing/lib/routing.py", line 120, in _dispatch
view_func(**kwargs)
File "/home/kodi/.kodi/addons/plugin.video.nrk/addon.py", line 49, in live
for ch in nrktv.channels():
File "/home/kodi/.kodi/addons/plugin.video.nrk/nrktv.py", line 184, in channels
chs = [Channel.from_response(item) for item in _get('/channels')]
File "/home/kodi/.kodi/addons/plugin.video.nrk/nrktv.py", line 156, in _get
return r.json()
File "/home/kodi/.kodi/addons/script.module.requests/lib/requests/models.py", line 892, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/lib/python2.7/dist-packages/simplejson/__init__.py", line 516, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/dist-packages/simplejson/decoder.py", line 370, in decode
obj, end = self.raw_decode(s)
File "/usr/lib/python2.7/dist-packages/simplejson/decoder.py", line 400, in raw_decode
return self.scan_once(s, idx=_w(s, idx).end())
File "/usr/lib/python2.7/dist-packages/simplejson/scanner.py", line 33, in __init__
ValueError.__init__(self, errmsg(msg, doc, pos, end=end))
TypeError: 'NoneType' object is not callable
20:25:06.785 T:140024120150400 ERROR: GetDirectory - Error getting plugin://plugin.video.nrk/live
(2018-01-15, 22:28)runel Wrote: [ -> ]Is this plugin broken? I cant get it working under 17.6
addon.run()
plugin.run()
view_func(**kwargs)
return r.json()
I'm running LibreELEC official 8.2.2 (Kodi 17.6) on a Raspberry Pi 3, and the plugin works flawlessly.
What system are you running Kodi on?
linorg: I was running on an old Acer Revo.. But I have since switch it for a RPi running LibreELEC and its working fine, like you said.
This used to work for me but recently I am getting this error on every installation I try:
NRK Nett-TV error
Check to log file for more information
This is the log file from Kodi 17.6 on a Windows 10 desktop PC but I have the same issue on my Windows 10 laptop and on a Raspberry PI.
https://paste.ubuntu.com/p/Q95s58B3Mz/
