Hello
Would it be possible X-Forwarded-For incorporate into the NRK App ?
I see that radio (NRK) P1 Trøndelag, is missing. I added it for myself, but hopefully you can add it to the plugin so that it stays with updates etc.
(2015-04-12, 18:30)Øyvind Wrote: [ -> ]Hello
Yes please!!
Ketil
Nrk1 stops quite frequetly
strangly enough NRK 2 and NRK3 don't
Hi! I have problems running live streams on Android tv box (androdi version 4.4.2). Nothing happens when clicking on the channel. I have Kodi 14.2. Where is the bug? I would be grateful for help.
Hi. Enjoying the plug-in on Nexus Player!
Have a problem though. After completing a stream, the second one will make Kodi close after a few seconds (back to launcher) and I have to reopen. Tried to upgrade to 15.0 beta and it still closes on the second stream, but even worse, the sound from the stream continues to play, and when I try to reopen Kodi I only get a black screen. Have to restart the Nexus Player.
Hei Takoi,
det være snill at du kan fikse søk og kategorier.
Øyvind
I haven't been able to access the archives for a couple of weeks, anyone else have this problem or is it just time for me to get on the program and do an upgrade? My kids are pestering me for their 'barne tv fix'
(2015-06-15, 20:20)ironlung Wrote: [ -> ]I haven't been able to access the archives for a couple of weeks, anyone else have this problem or is it just time for me to get on the program and do an upgrade? My kids are pestering me for their 'barne tv fix'
You can get a zip from
here if you can't wait. I'll try to push the update to the repo tomorrow
I just have tried and re-tried, but doesn't works for me.
Den nye versjonen krasjer ved oppstart.
Sorry guys, didn't spot the error until updating on my htpc. I have pushed a fix. Should be out withing 24 hours.
(2015-06-17, 20:45)takoi Wrote: [ -> ]Sorry guys, didn't spot the error until updating on my htpc. I have pushed a fix. Should be out withing 24 hours.
Den nye versjonen fungerer perfekt!
Takk skal du har !
Any chance of adding NRK P1 Trøndelag to the plug-in? Its no real problem adding it myself to default.py (the stream url is
http://lyd.nrk.no/nrk_radio_p1_trondelag_mp3_h ), but I have to do this again after each update. Afaik, its the only P1 stream missing in the plug-in.
