2011-06-17, 08:54
2011-06-17, 15:25
I have an images folder that contains various sub-folders one of them being Icons.
<root> Images
---<node> Folder1
---<node> Folder 2
---<node> Icons exlude this
I wish to exclude the Icons folder from the slide-show. For now, I could make Icons a root folder. Would it be possible to have an folder exclusion option in the future ?
<root> Images
---<node> Folder1
---<node> Folder 2
2011-06-17, 22:43
lupick Wrote:I'm using this script under linux and it doesnt populate the destination folder even if I've no error.
Any Ideas??
L.
xbmc version?
script version?
2011-06-17, 22:46
alertrarimi Wrote:I have an images folder that contains various sub-folders one of them being Icons.
<root> Images
---<node> Folder1
---<node> Folder 2
i really have no clue what you're on about? :-)
slideshow? what slideshow and what's got it to do with this script?
2011-06-18, 07:40
ronie Wrote:xbmc version?
script version?
Opss Sorry..
xbmc version: git20110617.c4dea43 (pre eden)
Script version: 0.2 (downloaded some days ago)
thank you
L
2011-06-18, 11:33
lupick Wrote:Opss Sorry..
thank you
L
try script v0.25:
http://transparency-xbmc.googlecode.com/...v0.2.5.zip
in settings > network enable the webserver and check what port is configured.
go to the video fanart splitter addon settings and configure the same webserver port there.
2011-06-18, 18:22
ronie Wrote:try script v0.25:
yep
the new version works!!
thank you
L.
2011-06-19, 08:02
isamu.dragon Wrote:$HOME/.xbmc/userdata/addon_data/script.video-fanart-splitter/.
Yea but how do i find this directory?
I click on Skin Settings / Backgrounds / HOME-Movies
I make sure FanArt is ticked, then I hit Options... tick custom background and then hit PATH, it opens the film manager..
But i can not find this path at all... is there a way to make teh file manager show hidden files.... is there some "other" way I can get to these dirs...
I Hit Browse and see
Home Folder
Root filesystem
Clicking on Home i only get a few dirs.. none of witch is the XBMC dir.. they are just teh default Downloads/Music/Pictures/TV/Videos
If i click on ROOT I get a lot of dirs... If I click on HOME in the list that pops up I only get the suers (like FTP)....
Where in relation to root is "$HOME/.xbmc/userdata/addon_data/script.video-fanart-splitter/"
Thanks in advance
2011-06-19, 08:05
Jyujinkai Wrote:Yea but how do i find this directory?
Home Folder
Root filesystem
Thanks in advance
you can configure the output dir in the plugin setting...
use the "c " key on the script icon under program
L.
2011-06-19, 09:34
Home Folder
Root filesystem
Thanks in advance
in linux a directory that starts with a "." is hidden. To view a hidden directory go into settings->Appearance->File List.
And Use the Tick for "Show Hidden Files and Directories"
and the directory should be visible under Home Folder
2011-06-19, 12:08
I've seen another "bug" on the dev version.
1. some plugin (E.g lyric) have a trasparent background so it's scrumbled with the music cdart
2. in the addon list the addon version gent over the "Broken" word.
L.
L.
2011-06-22, 21:14
Thanks this script is absolutely perfect! On a side note can anyone tell me what I need to be looking into to get it to run automatically whenever I resume from suspend in Live 10.1? I was looking at autoexec.py but I dont really understand how to use that to call another python script and then I read it was being depreciated in favour of add-on services?
2011-06-23, 15:14
Ok found the answer here: http://wiki.xbmc.org/?title=Create_a_resume_script I assume I just neet to get it to run default.py in the addon folder?
2011-07-03, 23:32
to those who are running a nightly build of xbmc,
i'm looking for some people who are willing to test this script:
script.artworkorganizer-0.0.1.zip
it's a complete re-write of the video fanart splitter script
with a few extra options added as well.
i plan to submit this to the xbmc addon repo as soon as the initial bugs (if any) are fixed,
so please let me know if you encounter any issues.
2011-07-04, 13:08
I´m using yesterday´s nightly: XBMCSetup-20110703-36d20e9-master (today´s crashing at startup)
The script worked well.
I turned debug on:
http://pastebin.com/tTvns1cX
The first time I startet the script without going to the settings first.
Maybe some kind of logic whether there is a destination folder set or not could be integrated.
If no folder is set the Fanart/Thumbs will be saved under addon_data/script.artworkorganizer/
Keep up the good work. I really appreciate this.
I turned debug on:
