flxfxp Wrote:scarfa, would you happen to have the Rapier skin on git or svn? I would like to add it to XBMScript next to some of the other popular scripts.
No its not on svn or git at the moment. I would like it to add it sometime.
xbs08 Wrote:First of all thanks for the update scarfa
I didn't had time to test this realese yet but i would like to suggest that the weather in home screen should be a button, that when pressed would display the weather forecast and that the default focus should be the shutdown icon.
Sry if this is already implemented.
I could make so if you pressed it it goes directly to the weather window. If you are suggesting to have a popup that shows the forecast on the home window then it just makes the weather window useless.
jdx66 Wrote:I can not display background images on the Home screen!
On the secondary screen is ok.
An idea?
And especially thank you for a great skin.
I'm not too sure. Are you refering to the default background or custom backgrounds? Or are they both not showing.
Hey guys, if you have a specific problem that demands my attention please make a seperate thread so I can better address it. It's kinda crazy going through this thread, thanks.
scarfa Wrote:I could make so if you pressed it it goes directly to the weather window.
That's what i meant. It's Like a shortcut to the weather window.
scarfa Wrote:It's a filesystem limitation on the Xbox. Try FlashFXP, although it mangles the name up.
I've had good luck ftping the zip to the xbox and extracting it using the filebrowser. Seems faster and I don't see any errors.
scarfa Wrote:I'm not too sure. Are you refering to the default background or custom backgrounds? Or are they both not showing.
it sounds like my problem: both are not showing/black, only in the submenu. and now he is the third reporting this bug.
i'll create a new topic!
I'm loving this skin.
this and Aeon skins are in my top list.
Is possible to remove the TOP menu? sorry, don't know a better name. The gray list at top. Can i hide it? its verry big, don't like that so mutch.
Other feature i would like to see in, is a random background like AEON have.
Is that possible? I know we can have a single background, but how about random background?
zeus[x];407907 Wrote:I'm loving this skin.
You can hide the top options menu in skin settings. Random backgrounds are supported, also in skin settings.
First thanks for your fast reply and let me say congratulations for this amazing skin.
i'm really loving it.
Maybe I didn't explore so well all skin settings, i will give a deep look at home.
thanks for suport and keep your great work.
Both, I see the icons categorie but never on the background screens Homepage.
Thanks,
scarfa Wrote:No its not on svn or git at the moment. I would like it to add it sometime.
If you need help setting it up and using git, let me know!
Nice skin, really love it.
I was wondering though, (and please forgive me if this is the wrong place to ask) how do you get the video file info, by that I mean, how many audio channels does the rip have? is it an xvid or x264? and so forth
I havent been able to find any plugin that does this, so could anyone please tell me how to enable this?
But I havent been able to compile a working xbmc.exe yet (I get a runtime error every time) so I am still running with the stable release. I dont know if the video info thing is just a part of a never version?
Sorry for being noobish, but could use your help on this one
I already tried to hide the top info panel, but it remains, didn't hide.
Any idea why? i selected to hide (sorry don't know the exact name) top pannel.
but still the same.
other problem, i always get the same background. don't have random backgrounds. Can any one help me please.
Thanks in advance.
jbetzer Wrote:Nice skin, really love it.
Yea, the more appropriate place to ask (AFTER Searching "SVN Builds for x" - where x is your OS/setup ) would be over here:
http://forum.xbmc.org/forumdisplay.php?fid=111
XBMC will scrape and handle the video file info, once you have a newer svn build. Since you didn't state what OS you're building for...
http://sshcs.com/xbmc/ may be a good place to look.
If you are looking for a windows build, there is a thread here:
http://forum.xbmc.org/showthread.php?tid=35452
Take note that while there are users that are running the bleeding edge builds, we still haven't had an official 'all-clear' from the xbmc developers... back up your current install whenever you're using an SVN build.
Oh, and welcome to the community! Enjoy your stay, feel free to participate (in the correct threads
), and don't feed the trolls.
