Feanor Wrote:I went ahead and modified this myself, I just copied the movies layout to the tv shows layout, and also the tv show information dialog. I didn't know how to add a skin setting and all that, so maybe this is not so useful to you, but well, just in case, here it is:
http://www.mediafire.com/download.php?1jzzlmyyei3
I also changed the list info view for music adding album reviews and artist bio.
Can you post it as a separate thread? Maybe someone will find it useful.
scarfa Wrote:Try getting rid of all the Rapier2.0 entries then rename all Rapier1.6 entries to Rapier2.0
I just renamed all of Rapier1.6 to Rapier2.0 as a test soon after posting the message. As I guessed all the backgrounds came back ok. This will be something for you to think when posting future updates.
rgds,
ck_xbmc Wrote:I just renamed all of Rapier1.6 to Rapier2.0 as a test soon after posting the message. As I guessed all the backgrounds came back ok. This will be something for you to think when posting future updates.
rgds,
Dude, if you just install the skin without renaming the folder to include the version number, the settings just keep working. It's you that's breaking them, not scarfa.
Does this skin work on the XBox version?
Has anybody tried?
marcozd Wrote:Does this skin work on the XBox version?
Has anybody tried?
Yes, works very well on the Xbox.
Rapier is one of the least memory demanding skins out there.
xbs08 Wrote:Yes, works very well on the Xbox.
Are you using any mods of this skin on XBOX?
Im been using T! v2.0 and love the skin but the more I see images from this skin, the more curious I am about possibly testing this on my XBOX.
I tried T! v2.0 on the latest T3ch build for XBOX and it was quite slow, are you using the latest T3ch build or a slightly older nightly build?
No, i didn't tried any mod.
I'm using nightly build 23281 (with the media flags on).
xbs08 Wrote:No, i didn't tried any mod.
Sweet, I will give this a go perhaps tonight if time permits.
Thnx for the reply
Remember that Rapier has the media flags off by default on the xbox.
Any word on a git or svn repo on this?
Sranshaft Wrote:Just wanted to say thank you to Scarfa for all the hard work he's put into this! Great stuff mate.
Added a new view for Episodes. Let me know if there's interest in it and I'll upload the files.
Yes please.
The new view is awesome, especially if it can be modified to work with more than one thumbnail for an episode, maybe even up to three (if the platform allows and design doesn't get too crowded). When can we hope to see it official in Rapier?
raynerape Wrote:The new view is awesome, especially if it can be modified to work with more than one thumbnail for an episode, maybe even up to three (if the platform allows and design doesn't get too crowded). When can we hope to see it official in Rapier?
The view is very nicely put together and is a MOD made by another user, which scarfa may implement to his design. As for more thumbnails, I think it might go against his initial design concept for the skin being very simple and conservative but again he has the final say.
Hope the view gets shared too!!
Good news everyone! I've uploaded the Episode Mods so they are now available to try out! It's a full-replacement mod. Overwrite your old Rapier folder with the one downloaded.
Thread can be found
here. Please keep all bug reports and tweak suggestions to that thread so that I can keep up with it and so that we don't pollute Scarfa's thread.
Awesome skin!
I'm loving how fast it is, while still looking great.
Would it be possible to add a "Wall" view for TV shows and Movies? Or something like the Mulitplex view in Aeon?
