2009-09-25, 17:30
2009-09-25, 17:30
2009-09-25, 18:43
The skin has been updated to version 1.60 in the XBMC Xbox Skins Repository
I love this skin! Thanks a lot!
edit: There is a good chance I'm alone on this one. But could you possibly add an option to show fanart anywhere BUT the homescreen? I really like fanart, but I also really like the clean homescreen you've created.
This is about the fastest skin for the XBOX. Animations are smooth and there are no memory problems what-so-ever. You've done an excelent job!
2009-09-25, 21:15
2009-09-25, 21:16
Bram77 Wrote:The skin has been updated to version 1.60 in the XBMC Xbox Skins Repository
I'm glad you like it.
I'll be releasing another small update shortly. Stay tuned.
2009-09-25, 21:26
scarfa Wrote:I'll look into it, but this skin only supports 16:9 displays.
First - Nice and fast skin.
Second - I have the same lines on a 1440x900 display. Also there is a line all across the screen just after the shadow in the top menu. Was about to look at the gfx myself by they were in a xpr file - so thought I would mention it here.
/needtotest
2009-09-25, 21:36
Hi
I've added folder on F: called tv-shows. Uploaded a show. Added the source under videos. The file I uploaded works, but can you explain how I add "tv shows" to main menu??
pob
pob
2009-09-25, 22:06
Hello,
I got this lines also at 1920x1080 (16:9) but thank you for the theme anyway
2009-09-26, 00:07
xboxpob Wrote:Hi
pob
You need to scan the content into the library first before the TV Shows category shows up on the main menu
2009-09-26, 04:08
I've noticed a couple small bugs:
1. In the movie info screen, if the plot spans the viewable window, the last line is cut in half. Herer is a screen shot to show what I mean:
http://farm4.static.flickr.com/3461/3954...308b_b.jpg
2. In the movies 'thumbnail' view the focussed movie thumb enlarges somewhat, but in the TV 'wide icon' view, it does not. Is this by design or a bug? I find it makes it harder to tell the selected\focussed title without the enlargement.
P.S. I do love this skin and it is now the skin I use on all my machines. Thanks so much for it!!
2009-09-26, 11:18
Can I do one small request...?
Could you make the in-video menu buttons (video; sound; subtitels) slightly bigger. It's almost impossible to see which is which on my 16:9 82cm CRT PAL TV.
2009-09-26, 17:56
tmc701 Wrote:Yea, the more appropriate place to ask (AFTER Searching "SVN Builds for x" - where x is your OS/setup ) would be over here: http://forum.xbmc.org/forumdisplay.php?fid=111
XBMC will scrape and handle the video file info, once you have a newer svn build. Since you didn't state what OS you're building for... http://sshcs.com/xbmc/ may be a good place to look.
If you are looking for a windows build, there is a thread here: http://forum.xbmc.org/showthread.php?tid=35452
Take note that while there are users that are running the bleeding edge builds, we still haven't had an official 'all-clear' from the xbmc developers... back up your current install whenever you're using an SVN build.
Oh, and welcome to the community! Enjoy your stay, feel free to participate (in the correct threads ), and don't feed the trolls.
It is for windows, but I found the precompiled SVN thread on the forum, and after installing one of these it all works as it should
Thx for the link though, seems better updated than the forum link is.
I dont have a lot (if any) experinces with svn builds, c++ compiling, so I didnt really know what to look for. I usually only ask for advice as a last resort, I know how annoying clueless newbies can be, so thanks for the help
2009-09-26, 22:35
This skin is awesome - only one issue - not sure if it is the skin or not, but i am using an external player, and when i exit the player and it goes back to xmbc the fanart background flickers (the brightness goes down, then up, then back to normal). This happens where i have the dimmed fanart option selected or not.
Anyone else face this issue?
2009-09-27, 23:28
2009-09-28, 04:47
Incredible skin Scarfa.. Snappy as all get out on the XBOX running rev23183..
I've been looking forever for a reliable skin that has all the eye candy I want..
The only thing I added to it was the sounds from Horizonz.
Great work, thanks again
2009-09-29, 22:57
--made a new topic---
