2009-12-31, 20:33
mythicalLibrarian
http://wiki.xbmc.org/?title=MythicalLibrarian
Key features:How to use:
mythicalLibrarian will generate usable content for XBMC out of your MythTV recorded libraries by utilizing the standard Showname.SxxExx (Episode Title).ext format.
run the mythicalSetup.sh program
run mythicalLibrarian --help
This will explain how to use everything.
It can be configured in the following ways
A problem report consists of a brief discription of the problem and a copy of a single debug log from output.log Please report anything you consider to be a problem as it will help out others and improve the development of the program. Before posting, please look at the log to see if it contains any valuable information.
The entire debug log is located in ~/.mythicalLibrarian/output.log and a single log starts with "NEW SEARCH INITIATED AT" and contains the words "DEBUG MODE ENABLED". Logs should be wrapped in [ code] [ /code] tags for clenliness.
Here is an example debug log:
Please report all errors you find.
I am subscribed to this thread and will be notified within about 15 minutes on my Android.
Last "stable" is here: http://mythicallibrarian.googlecode.com/...alSetup.sh
Newest version will be here: http://mythicallibrarian.googlecode.com/...alSetup.sh
I am accepting donations at my sourceforge page as a way to justify the time I spend on this project to my girlfriend: https://sourceforge.net/projects/mythicallibrari/
Key features:
- Episodes renamed to Show name.SxxExx (episode title).ext
- Movies renamed to Movie (year).ext
- Special provisions for naming sports and news which is compatible with XBMC.
- Symlinks allow MythTV to maintain your library.
- TvDb recognition of Show Name and Episode Name
- Zap2it ID and fuzzy logic Title matching allows for perfect naming of Titles
- Airdate and fuzzy logic episode matching allows for perfectly named episodes
- User defined show name translations for improper guide data
- User is notified at the end of each operation, XBMC is updated
- Dynamic mount support with alternate move dir
- mythicalSetup allows for easy installation and selection of options, while also making decisions based on your setup.
- Can be run as MythTV job.
- Scan mode will set the naming convention of your existing library
- User jobs can be configured to run using the information mythicalLibrarian has collected
mythicalLibrarian myfile.ext "title to match" "subtitle to match"
--or--
mythicalLibrarian "path/to/mythtv_file.ext"
--or as a user job in mythtv--
mythicalLibrarian "%DIR%/%FILE%"
- Move your files and create symlinks in place of the original so that MythTV can manage your library
- Leave the original in place and create symlinks to your folder
- Move files to a NAS and if the NAS is not present, move it to a local folder
- After extinguishing all other resources, create a symlink to the original file in a local folder
@@@@@@@@@@@NEW SEARCH INITIATED AT Mon Sep 20 18:30:42 CDT [email protected]@@@@@@@@@@@@@
Revision 600 Mon Sep 20 17:56:31 CDT 2010 on Linux
PERFORMING MAINTENANCE ROUTINE
REMOVING ORPHAN /home/mythtv/Videos/Episodes/SpongeBob SquarePants/Season 6/SpongeBob SquarePants S06E16 (Boating Buddies).txt
REMOVING ORPHAN /home/mythtv/Videos/Episodes/SpongeBob SquarePants/Season 6/SpongeBob SquarePants S06E10 (A Life in a Day).txt
REMOVING ORPHAN FOLDER:/home/mythtv/.mythicalLibrarian/mythicalSetup/Episodes/Mister Rogers Neighborhood/Season 7
SEARCHING: www.TheTvDb.com SHOW NAME: Tosh.0 EPISODE:
DATE: 2009-08-06 FILE NAME: /home/mythtv/Videos/1056_20100920180000.mpg
SEARCH FOUND:Tosh.0 ID#: 97731
MATCH!!!! Zap2itID:Tosh.0 ID.97731
###################DEBUG MODE ENABLED####################
MY USER NAME:mythtv-
LISTING INTERNAL VARIABLES USED BY mythicalLibrarian.
INTERNET TIMEOUT:50- TVDB API KEY:6DF511BB2A64E0E9- mythicalLibrarian WORKING DIR:/home/mythtv/.mythicalLibrarian-
MOVE DIR:/home/mythtv/Videos/Episodes- USING SHOWNAME AS FOLDER:Enabled-
FAILSAFE MODE:Enabled- FAILSAFE DIR:/home/mythtv/FailSafe- ALTERNATE MOVE DIR:/home/mythtv/Videos/Episodes-
USE ORIGINAL DIR:Enabled NOTIFICATIONS:Enabled
INPUT SHOW NAME:Tosh.0- LOCAL SHOW NAME TRANSLATION:- ShowName:Tosh.0
DATABASE UPDATED:- TVDB LAST UPDATED:1285090977- CURRENT:1285026385-
RESOLVED SERIES ID:97731- RESOVED SHOW NAME:Tosh.0-
INPUT EPISODE NAME:- ABSOLOUTE EPISODE NUMBER:9- RESOLVED EPISODE NAME:Web Redemption Drunk Dunk-
SEASON:S01- EPISODE:E09- SYMLINK MODE:MOVE- FILESIZE: 0kB-
CREATE AND DELETE FLAGS: ORIGINALDIR:1- FREE:4355428kB- WORKINGDIR:1 FREE:4355364kB-
MOVEDIRWRITABLE:1- FREE:4355428kB- ALTERNATEMOVEDIR:1- FREE:4355428kB-
PRIMARYSHOWDIRWRITABLE:1- FREE:4355428kB-ALTERNATESHOWDIRWRITABLE:1- FREE:4355428kB-
PRIMARYMOVIEDIRWRITABLE:1- FREE:4355428kB- ALTERNATEMOVIEDIR:1- FREE:4355428kB-
DATABASE TYPE:schedulesdirect1-
RECSTART:2010-09-20 18:00:00- MOVIE YEAR:- ORIGINAL SERIES DATE:2009-08-06-
PROGRAMID:EP011496300009- CHANNEL ID:1056- CATEGORY:Comedy- GOFORDOOVER:1-
EXTRAPOLATED DATA DETERMINED THIS RECORDING AS A:Series With Episode Data- STARS:0 RATING:0
ZAP2IT SERIES ID:1149630- MATCHED TVDB SERIES ID:97731-
PLOT: Daniel's Popcorn Challenge; Dizzy Dunk's web redemption; Tommy Chong.
####################END OF DEBUG LOG#####################
MOVING FILE: '/home/mythtv/Videos/1056_20100920180000.mpg' to '/home/mythtv/Videos/Episodes/Tosh.0/Season 1/Tosh.0 S01E09 (Web Redemption Drunk Dunk).mpg'
@@@@@@@@@@@@@OPERATION COMPLETE Mon Sep 20 18:30:47 CDT 2010 @@@@@@@@@@@@@@@@
