Thank you so much for making mythicallibrarian.
I have an issue: even though the episode is new, mythicallibrarian matches with the first on the list, so my links are being Season 1, Ep 1.
Here is the Log
Stable - Downloaded Thu Oct 11 02:00:22 CDT 2012
Attemting to pull database information on /var/lib/mythtv/recordings/2081_20121010200000.mpg
COMMERCIAL DATA START:50559 STOP:55598
/usr/local/bin/mythicalLibrarian: line 718: None=: command not found
RECSTART:2012-10-10 20:00:00 DATE: None
PROGRAMID: ShowCategory:
PLOT: Schooled: Claire and Phil embarrass Haley when they drop her off at college; Manny makes Gloria and Jay take a class; Lily gets into a tussle on her first day of kindergarten.
PERFORMING MAINTENANCE ROUTINE...
SEARCHING:
www.TheTvDb.com SHOW NAME: Modern Family EPISODE:
TESTING FOR ZAP2ITID MATCH:EP01158124 Modern Family
FOUND:Modern Family ID#:95011 WITH CONFIDENCE:-1
DATABASE IS OUT OF DATE. NEXT UPDATE 1350007525 Current 1350136708
Parsing Downloaded information: Modern Family.xml
AIRDATE FAILED. TITLE MATCH ON ABSOLUTE EPISODE NUMBER:
TOTAL MATCHES:14 TOTAL VERIFIED FUZZY ERRORS:0
EPISODE
ilot EPISODE NUMBER:2 S01E01 WITH CONFIDENCE: -1
WARNING: FILE IS A LINK FORCING SYMLINK LINK MODE
CONFIDENCE:-2 LOGIC PATH: Attempted Match On Zap2itID: Failed; Attemted match on Standard Logic: Sucessful; Attemped match on OriginalAirDate: Failed; Attemted SubTitle match on Standard logic: Sucessful;
JOB: mythicalLibrarian '/var/lib/mythtv/recordings/2081_20121010200000.mpg' 'Modern Family' ''
TARGET SET:/var/lib/mythtv/recordings/Episodes/Modern Family/Season 1/Modern Family S01E01 (Pilot).mpg
FILE NAME EXISTS. FILE WILL BE KNOWN AS:
Modern Family S01E01 (Pilot)-2
CREATING LINK IN LINK MODE WITH CONFIDENCE:-2
SENDING REQUESTED COMMANDS TO:192.168.99.190:8080
RSS generation failed:
File exists but is not writeable: /var/www/mythical-rss/rss.xml
SUCCESSFUL COMPLETEION TYPE: LinkModeSuccessful
