2010-10-26, 16:33
davilla Wrote:CrystalHD has nothing to do with "RSS feeds scrolling along the bottom of the screen". Also you are running beta2 and your log shows;
i think he wanted to say, that everything is slow the rss was just an example
andy204 Wrote:i think he wanted to say, that everything is slow the rss was just an example
Patrics83 Wrote:Hi, for me it didn´t work so good.
Installation was OK but when I start XBMC everything is very laggy and crystalhd card isn´t in the option menu.
I cant ssh to apple tv after the crash.
Where can i post my logs? Pastbin isn´t working for the moment.
guibaa Wrote:Hi scoot,
same issue with bcm70015, Installation was OK but when I start XBMC everything is very laggy and crystalhd card isn´t in the option menu.
davilla Wrote:Then ssh in before xbmc.log
konan Wrote:Exactly the same picture with me. After installing r172 the entire XBMC UI became much slower including the main menu. Could not even play the SD AVI files: after 30 seconds XBMC hang and had to reboot the ATV. 100% reproducible but due to the hang there is no crash log. Will post the debug log later when get back home. Had to manually revert back to r156 to be able to watch movies.
davilla Wrote:Just want to verify, you launch xbmc, don't play any videos and the gui is slower with r172 ?
davilla Wrote:@guibaa
@nmrs, ^^ do you have same thing in dmesg ?, you can check without launching xbmc.
Quote:BroadcomCrystalHD:tart
crystalhd_hw_open: setting up functions, device = Flea
[crystalhd_flea_core_reset]: Starting core reset
DDR-2 Detected
Opening HW. hw:0x1f51804, hw->adp:0x1f57900
BroadcomCrystalHD: Registering power handler
BroadcomCrystalHD: Found HW and started driver SW.
!!FATAL ERROR!! Core Reset Failure
DDR-2 Detected
Opening HW. hw:0x2294a04, hw->adp:0x1f57900
BroadcomCrystalHD opened
allocated 18 elem
Initializing Dio pool 10 1024 305c 0x1dbde04
Downloading FW
[crystalhd_flea_download_fw]: Sz:864276
[crystalhd_flea_download_fw]: step 1. Enable scrubbing
[crystalhd_flea_download_fw]: step 2. Poll for SCRAM_KEY_DONE_INT
[crystalhd_flea_download_fw]: step 3. Write the BORCH and STARCH addresses. f6004:d2fff, f6008:d2fff
[crystalhd_flea_download_fw]: step 4. Write the firmware to DRAM. Sz:864256 Bytes
[crystalhd_flea_download_fw]: step 5. Write the signature to CMAC register.
[crystalhd_flea_download_fw]: step 6. Write the ARM run bit to 1.
[crystalhd_flea_download_fw]: step 7. Poll for Boot Verification done/failure interrupt.
[crystalhd_flea_download_fw]: step 7. Error bit occured. RetVal:ffffffff
[crystalhd_flea_download_fw]: step 7. Firmware image signature failure.
Firmware Download Failure!! - -1
Closing user[0] handle with mode 417a00
Releasing RX Pkt pool
Released dio pool 10
released 18 elem
BroadcomCrystalHD closed
