Ah. I figured r26 was the latest version since that's what comes up below the XBMC nightly builds. I see now that you're up to r140-something but you're not releasing it for some reason. This is not a complaint; thanks for your efforts and I hope they bear fruit soon.
just going to go out on a limb on this one, Dan correct me if i'm wrong...
current drivers are up to r14X, but those only seem to work on the logic supply chd cards, with the latest svn's they work pretty darn good...
stable drivers for the ebay cards are the r26 drivers... but don't have as good as playback as the logic supply + r14X drivers... Dan is trying to find if there is a solution to this problem...
is that the gist of where we're at?
my ebay card works with r143 and linux on the atv.
-andy
what's the theory on AppleOS vs Linux with the new drivers and the ebay cards (on the ATV)
Any idea when r143 Will be available with the luncher?
curlyjs Wrote:Any idea when r143 Will be available with the luncher?
same answer as usual: "when davilla says its ready"
-andy
still waiting on a few driver/lib issues to be resolved.
Any update or release date? Thanks for all your hard work.
look one post up:
davilla Wrote:still waiting on a few driver/lib issues to be resolved.
stucook Wrote:Any update or release date? Thanks for all your hard work.
Some time after I get home from traveling so I can finish up testing.
I am guessing this is the last / latest EASY WAY to install Crystal HD XBMC for ATV OSX?
crashnburn Wrote:I am guessing this is the last / latest EASY WAY to install Crystal HD XBMC for ATV OSX?
yes. i update the installed with a new compiled version when the driver is ready to be published.
-andy
what is the latest version? My download screen shows r26.
short notice: i will be on vacation from 14th to 24th. if a new and "ready" version is released from davilla, then i will build it after the 24th.
-andy
