teshephe Wrote:No problem... initial things to check is to make sure that you have powershell configured properly as well as vlc 1.1.4 installed. Make sure that you have generated your files after setting up and restart XBMC.
XBMC "WILL" be slow closing as it shuts down the broadcast services in a controlled manner.
Also, on your Global Master, when you start the addon, also open up task manager to make sure that you can see 2 (two) vlc instances.
Let me know if this helps or that you are still having issues.
hi...
Unfortunately the problem remain (no a/v from client ). I've followed all the procedure again but nothing has changed
below a portion of server and client xbmc logs
Server log*******
19:49:39 T:2464 M:2189783040 NOTICE: Running the application...
19:49:40 T:2464 M:2188619776 NOTICE: Webserver: Starting...
19:49:40 T:2464 M:2187993088 NOTICE: WebServer: Started the webserver
19:49:40 T:2464 M:2187968512 NOTICE: ES: Starting event server
19:49:40 T:3448 M:2187919360 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
19:49:40 T:3448 M:2187919360 NOTICE: UDP: Listening on port 9777
19:49:40 T:3992 M:2186940416 NOTICE: -->Python Interpreter Initialized<--
19:49:40 T:3976 M:2176032768 NOTICE: -->Python Interpreter Initialized<--
19:49:40 T:2472 M:2174377984 NOTICE: -->Python Interpreter Initialized<--
19:49:41 T:3976 M:2171990016 NOTICE: [MAV]: MAV-DB - MAV Database already exists...
19:49:41 T:2472 M:2171617280 NOTICE: <html>
<li>OK
</html>
19:49:41 T:2472 M:2171617280 NOTICE: [MAV]: MAV UDP Sender Started and Running in background...
19:49:41 T:2472 M:2171617280 NOTICE: [MAV]: >> MAV UDP Sent - MAV Master @ 192.168.1.10 Livingroom rtp://@224.1.1.152:1152
19:49:44 T:3976 M:2161901568 NOTICE: [MAV]: MAV Streamer Started and Running...
19:49:44 T:3976 M:2161897472 NOTICE: [MAV]: MAV UDP Receiver Started and Running in background...
19:50:14 T:3976 M:2141556736 NOTICE: [MAV]: MAV - Client Office found @ 192.168.1.113
19:50:14 T:3976 M:2141540352 NOTICE: MAV-DB error...Source Already exists in the table
19:50:14 T:3976 M:2141536256 NOTICE: [MAV]: MAV-DB - Source Office updated to DB
------------------------------------------------- client connected---------------------------------------------------------------
19:50:41 T:2472 M:2144038912 NOTICE: [MAV]: >> MAV UDP Sent - MAV Master @ 192.168.1.10 Livingroom rtp://@224.1.1.152:1152
19:50:41 T:3976 M:2144034816 NOTICE: MAV-DB error...Source Already exists in the table
19:50:41 T:3976 M:2144034816 NOTICE: [MAV]: MAV-DB - Source Loopback updated to DB
19:51:14 T:3976 M:2132799488 NOTICE: [MAV]: MAV - Client Office found @ 192.168.1.113
19:51:14 T:3976 M:2132795392 NOTICE: MAV-DB error...Source Already exists in the table
19:51:14 T:3976 M:2132795392 NOTICE: [MAV]: MAV-DB - Source Office updated to DB
19:51:41 T:2472 M:2139164672 NOTICE: [MAV]: >> MAV UDP Sent - MAV Master @ 192.168.1.10 Livingroom rtp://@224.1.1.152:1152
19:51:41 T:3976 M:2139164672 NOTICE: MAV-DB error...Source Already exists in the table
19:51:41 T:3976 M:2139164672 NOTICE: [MAV]: MAV-DB - Source Loopback updated to DB
19:52:14 T:3976 M:2165362688 NOTICE: [MAV]: MAV - Client Office found @ 192.168.1.113
19:52:14 T:3976 M:2165358592 NOTICE: MAV-DB error...Source Already exists in the table
19:52:14 T:3976 M:2165358592 NOTICE: [MAV]: MAV-DB - Source Office updated to DB
19:52:41 T:2472 M:2148282368 NOTICE: [MAV]: >> MAV UDP Sent - MAV Master @ 192.168.1.10 Livingroom rtp://@224.1.1.152:1152
19:52:41 T:3976 M:2148278272 NOTICE: MAV-DB error...Source Already exists in the table
19:52:41 T:3976 M:2148278272 NOTICE: [MAV]: MAV-DB - Source Loopback updated to DB
19:53:14 T:3976 M:2153390080 NOTICE: [MAV]: MAV - Client Office found @ 192.168.1.113
19:53:14 T:3976 M:2153385984 NOTICE: MAV-DB error...Source Already exists in the table
19:53:14 T:3976 M:2153385984 NOTICE: [MAV]: MAV-DB - Source Office updated to DB
19:53:41 T:2472 M:2150494208 NOTICE: [MAV]: >> MAV UDP Sent - MAV Master @ 192.168.1.10 Livingroom rtp://@224.1.1.152:1152
19:53:41 T:3976 M:2150486016 NOTICE: MAV-DB error...Source Already exists in the table
19:53:41 T:3976 M:2150481920 NOTICE: [MAV]: MAV-DB - Source Loopback updated to DB
--------------------------------- streaming----------------------------------------------------------------------
Client Log****
19:50:09 T:5632 M:2268323840 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
19:50:09 T:5632 M:2268323840 NOTICE: UDP: Listening on port 9777
19:50:09 T:4128 M:2267738112 NOTICE: -->Python Interpreter Initialized<--
19:50:10 T:2812 M:2261102592 NOTICE: -->Python Interpreter Initialized<--
19:50:10 T:360 M:2260766720 NOTICE: -->Python Interpreter Initialized<--
19:50:11 T:2812 M:2257563648 NOTICE: [MAV]: MAV-DB - MAV Database already exists...
19:50:11 T:2812 M:2257575936 NOTICE: [MAV]: MAV UDP Receiver Started and Running in background...
19:50:11 T:360 M:2257567744 NOTICE: <html>
<li>OK
</html>
19:50:11 T:360 M:2257567744 NOTICE: [MAV]: MAV UDP Sender Started and Running in background...
19:50:11 T:360 M:2257453056 NOTICE: [MAV]: >> MAV UDP Sent - MAV Client @ 192.168.1.113 Office rtp://@224.1.1.152:1152
19:50:11 T:2812 M:2257436672 NOTICE: MAV-DB error...Source Already exists in the table
19:50:11 T:2812 M:2257432576 NOTICE: [MAV]: MAV-DB - Source Loopback updated to DB
19:50:39 T:2812 M:2254528512 NOTICE: [MAV]: MAV - Global Master Livingroom found @ 192.168.1.10
19:50:39 T:2812 M:2254524416 NOTICE: MAV-DB error...Source Already exists in the table
19:50:39 T:2812 M:2254524416 NOTICE: [MAV]: MAV-DB - Source Livingroom updated to DB
----------------------client connected-------------------------------------------------------
19:51:11 T:360 M:2255327232 NOTICE: [MAV]: >> MAV UDP Sent - MAV Client @ 192.168.1.113 Office rtp://@224.1.1.152:1152
19:51:11 T:2812 M:2255323136 NOTICE: MAV-DB error...Source Already exists in the table
19:51:11 T:2812 M:2255323136 NOTICE: [MAV]: MAV-DB - Source Loopback updated to DB
19:51:39 T:2812 M:2256785408 NOTICE: [MAV]: MAV - Global Master Livingroom found @ 192.168.1.10
19:51:39 T:2812 M:2256781312 NOTICE: MAV-DB error...Source Already exists in the table
19:51:39 T:2812 M:2256781312 NOTICE: [MAV]: MAV-DB - Source Livingroom updated to DB
19:52:11 T:360 M:2257620992 NOTICE: [MAV]: >> MAV UDP Sent - MAV Client @ 192.168.1.113 Office rtp://@224.1.1.152:1152
19:52:11 T:2812 M:2257616896 NOTICE: MAV-DB error...Source Already exists in the table
19:52:11 T:2812 M:2257616896 NOTICE: [MAV]: MAV-DB - Source Loopback updated to DB
19:52:39 T:2812 M:2261110784 NOTICE: [MAV]: MAV - Global Master Livingroom found @ 192.168.1.10
19:52:39 T:2812 M:2261106688 NOTICE: MAV-DB error...Source Already exists in the table
19:52:39 T:2812 M:2261106688 NOTICE: [MAV]: MAV-DB - Source Livingroom updated to DB
19:53:11 T:360 M:2258071552 NOTICE: [MAV]: >> MAV UDP Sent - MAV Client @ 192.168.1.113 Office rtp://@224.1.1.152:1152
19:53:11 T:2812 M:2258067456 NOTICE: MAV-DB error...Source Already exists in the table
19:53:11 T:2812 M:2258067456 NOTICE: [MAV]: MAV-DB - Source Loopback updated to DB
19:53:38 T:4816 M:2255831040 NOTICE: ExternalPlayer Filename: C:\Program Files\VideoLAN\VLC\vlc.exe
19:53:38 T:4816 M:2255831040 WARNING: ExternalPlayer: invalid value for warpcursor: none
19:53:38 T:4816 M:2255831040 NOTICE: ExternalPlayer Tweaks: hideconsole (true), hidexbmc (false), islauncher (false), warpcursor (none)
19:53:38 T:4816 M:2255831040 NOTICE: CExternalPlayer::OpenFile: rtp://@224.1.1.152:1152
19:53:38 T:1208 M:2255790080 NOTICE: CExternalPlayer:
rocess: Player : C:\Program Files\VideoLAN\VLC\vlc.exe
rocess: File : rtp://@224.1.1.152:1152
rocess: Content:
rocess: Args : --intf dummy --dummy-quiet "{1}" --play-and-exit --extraintf=http --http-host=192.168.1.113:8085 --netsync-master --netsync-master-ip= --netsync-timeout=500 --file-caching=0 --fullscreen
rocess: Start
rocess: Releasing audio device 2
19:53:38 T:2812 M:2255699968 NOTICE: [MAV]: Master Livingroom Playback Started...
19:53:38 T:1208 M:2256388096 NOTICE: CExternalPlayer::ExecuteAppW32: C:\Program Files\VideoLAN\VLC\vlc.exe "C:\Program Files\VideoLAN\VLC\vlc.exe" --intf dummy --dummy-quiet "rtp://@224.1.1.152:1152" --play-and-exit --extraintf=http --http-host=192.168.1.113:8085 --netsync-master --netsync-master-ip= --netsync-timeout=500 --file-caching=0 --fullscreen
19:53:39 T:2812 M:2252681216 NOTICE: [MAV]: MAV - Global Master Livingroom found @ 192.168.1.10
19:53:39 T:2812 M:2252480512 NOTICE: MAV-DB error...Source Already exists in the table
19:53:39 T:2812 M:2252480512 NOTICE: [MAV]: MAV-DB - Source Livingroom updated to DB
19:54:11 T:360 M:2254536704 NOTICE: [MAV]: >> MAV UDP Sent - MAV Client @ 192.168.1.113 Office rtp://@224.1.1.152:1152
19:54:11 T:2812 M:2254532608 NOTICE: MAV-DB error...Source Already exists in the table
19:54:11 T:2812 M:2254536704 NOTICE: [MAV]: MAV-DB - Source Loopback updated to DB
----------------------------------------- streaming from server----------------------------------------------------------
