Still can't export "My List". Here is my full log.
http://xbmclogs.com/show.php?id=131832
Edit: Further clarification. I am able to export individual items such as movies or tv series (some tv series throw an error though). I am unable to export "My List" as a whole.
nitehawk_98
Please give me the error log, it will help me find the problem.
As for the plugin reload, Ihave the same problem. I haven't soleved it yet. Maybe if my addin matures enough it would get into the main plugin.
Hello!
A fresh user of XBMC. I'm on a windows 8 64-bit htpc and XBMC Frodo 12.3.
I'm having trouble installing this add-on. I've tried installing it, uninstalling it, disabling it, enabling it again, force refresh, check updates, uninstalling XBMC and re-installing it again. Nothing seems to work.I tried it installing it to another computer (Sony Vaio -laptop running win 7 64-bit) and somehow it happened in that machine.
But on the htpc it won't happen.
Any tips?
Is there any way to add a suffix to the Netflix videos so that the library know which are and aren't using Netflix? I use PseudoTV Live frequently but have recently been coming across errors when it tries to play these videos - it doesn't expect them to be spat out into Chrome. I'd like to set up a rule for it to ignore videos that have the "(Netflix)" suffix but can of course only do that if they DO have that suffix.
I think the reason is/was the firewall + my pc is acting all strange. Trying a reinstall.
I too would like to add my name to the list of those who would greatly appreciate Xbox 360 controller support.
(2014-02-16, 01:52)alli95 Wrote: [ -> ]Hello!
Any tips?
Had a spare Windows 7 license and it did the trick. The windows 8 had become corrupted giving me all weird missing dll-alarms.
Now all seems to be working, netflix plugin for xbmc included. Thank you vero much!
Alright, first off this is an amazing plugin thank you for it.
For those of you looking for xbox controller support, I have it working. I'm actually using a PS3 controller, but the pc thinks its xbox so it should work for you.
First, watch this video
https://www.youtube.com/watch?v=TpSaOJJIun8 this will show you exactly how to setup a PS3 controller ( I assume xbox would work aswell?) to you pc. it's WAY better than any of that betterds3 or motionjoy crap out there. THe controllers pair EVERY time with no fiddling.
Out of the gate...the wireless controller with work with xbmc and it's fantastic. I did run into an issue though with netflixbmc as the controller doesnt really make use of a direct keyboard translation....so the MCE mapping didnt work. So we have to find a way around it.
The first thing you need to do is remove the files that are currently allowing the remote to work out of the box,we do this because in the next step we are going to remap and if we leave both we will get weird double keypresses, they are located in C:\ProgramFiles\xbmc\settings\keymaps ( something like that) there will be a few of them, I just removed all of the ones that looked like "Microsoft xbox controller. Joystick controller,ps3 controller etc..etc.. I only left the files that were titled like " keyboard and mouse" I put them in a folder on the desktop for safe keeping incase something went wrong.
then I downloaded a program called xpadder...xpadder is used alot in the emulation world...basically all you do is press each button on your remote and it registers it in the program graphically....then you reposition the buttons on your screen to match the general layout of your controller ( just so it's easier to know which buttons are which"
once you have the controller layout all mapped out..you can click on each button and link it to a coorsponding key on your regular keyboard...they are all there including some more advanced options like multiple key strokes at the same time, pauses, durations of keypress etc..etc.. this is pretty strait forward and you can set it up however you want.... then save it and your done...you need to make sure xpadder starts when windows does ( which can be set in xpadders settings) and as long as the program is open while you are in xbmc it will register everything you hit as if you were using the keyboard ( which was needed to get the netflixbmc mapping screen to register the buttons.
Hi, is there anyone who tested this on an apple tv2?
(2014-02-19, 13:04)tizke Wrote: [ -> ]Hi, is there anyone who tested this on an apple tv2?
iOS or Android won't work!
Hi
I'm using the danish netflix, and got connection error after selecting the movie i want to see
i'm on linux mint 13.10
can anyone help ?
Hello everyone. I'm having trouble installing Netflixbmc. I installed in on my girlfriend's computer no problem, but when I try it on my brand new HTPC I have no luck. Could I get some help? Here's an excerpt from my log file.
00:28:53 T:4084 DEBUG: FileManager: copy http://addonscriptorde-beta-repo.googlecode.com/svn/trunk/plugin.video.netflixbmc/icon.png -> special://home/addons/plugin.video.netflixbmc/icon.png
00:28:53 T:4084 DEBUG: CurlFile::Open(06F3A730) http://addonscriptorde-beta-repo.googlecode.com/svn/trunk/plugin.video.netflixbmc/icon.png
00:28:53 T:4084 DEBUG: FileManager: create folder special://home/addons/plugin.video.netflixbmc/resources
00:28:53 T:4084 DEBUG: FileManager: copy http://addonscriptorde-beta-repo.googlecode.com/svn/trunk/plugin.video.netflixbmc/resources/NetfliXBMC_Utility.exe -> special://home/addons/plugin.video.netflixbmc/resources/NetfliXBMC_Utility.exe
00:28:53 T:4084 DEBUG: CFileCache::Open - opening <svn/trunk/plugin.video.netflixbmc/resources/NetfliXBMC_Utility.exe> using cache
00:28:53 T:4084 DEBUG: CurlFile::Open(06F3A730) http://addonscriptorde-beta-repo.googlecode.com/svn/trunk/plugin.video.netflixbmc/resources/NetfliXBMC_Utility.exe
00:29:00 T:3248 DEBUG: ------ Window Deinit (Pointer.xml) ------
00:29:04 T:3248 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://addonscriptorde-beta-repo.googlecode.com (easy=03CBFFF0, multi=00000000)
00:29:19 T:4084 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
00:29:19 T:4084 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
00:29:19 T:4084 ERROR: XFILE::CFileCache::Open - failed to open source <http://addonscriptorde-beta-repo.googlecode.com/svn/trunk/plugin.video.netflixbmc/resources/NetfliXBMC_Utility.exe>
00:29:19 T:4084 ERROR: Could not read addon description of plugin.video.netflixbmc
00:29:19 T:4084 DEBUG: FileManager, processing folder: special://home/addons/plugin.video.netflixbmc/
00:29:19 T:4084 DEBUG: -- special://home/addons/plugin.video.netflixbmc/addon.xml
00:29:19 T:4084 DEBUG: -- special://home/addons/plugin.video.netflixbmc/changelog.txt
00:29:19 T:4084 DEBUG: -- special://home/addons/plugin.video.netflixbmc/default.py
00:29:19 T:4084 DEBUG: -- special://home/addons/plugin.video.netflixbmc/download.py
00:29:19 T:4084 DEBUG: -- special://home/addons/plugin.video.netflixbmc/icon.png
00:29:19 T:4084 DEBUG: -- special://home/addons/plugin.video.netflixbmc/LICENSE.txt
00:29:19 T:4084 DEBUG: -- special://home/addons/plugin.video.netflixbmc/resources/
00:29:19 T:4084 DEBUG: FileManager, processing folder: special://home/addons/plugin.video.netflixbmc/resources/
00:29:19 T:4084 DEBUG: FileManager: delete special://home/addons/plugin.video.netflixbmc/addon.xml
00:29:19 T:4084 DEBUG: FileManager: delete special://home/addons/plugin.video.netflixbmc/changelog.txt
00:29:19 T:4084 DEBUG: FileManager: delete special://home/addons/plugin.video.netflixbmc/default.py
00:29:19 T:4084 DEBUG: FileManager: delete special://home/addons/plugin.video.netflixbmc/download.py
00:29:19 T:4084 DEBUG: FileManager: delete special://home/addons/plugin.video.netflixbmc/icon.png
00:29:19 T:4084 DEBUG: FileManager: delete special://home/addons/plugin.video.netflixbmc/LICENSE.txt
00:29:19 T:4084 DEBUG: FileManager: delete folder special://home/addons/plugin.video.netflixbmc/resources/
Nevermind, I tried again this morning and it worked fine. I think the campus network does some maintenance overnight, which would explain the connectivity issues.
Is there any way to use keyboard shortcuts with ie11 which uses the new html5 player?
Can't get this plugin to work, I get a script error. Here is my log:
Quote:21:54:41 T:2953318400 NOTICE: -->Python Interpreter Initialized<--
21:54:44 T:2953318400 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.URLError'>
Error Contents: <urlopen error [Errno 8] _ssl.c:480: EOF occurred in violation of protocol>
File "/Users/Tim/Library/Application Support/XBMC/addons/plugin.video.netflixbmc/default.py", line 771, in <module>
index()
File "/Users/Tim/Library/Application Support/XBMC/addons/plugin.video.netflixbmc/default.py", line 101, in index
if login():
File "/Users/Tim/Library/Application Support/XBMC/addons/plugin.video.netflixbmc/default.py", line 473, in login
content = opener.open("http://movies.netflix.com/").read()
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 397, in open
response = meth(req, response)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 510, in http_response
'http', request, response, code, msg, hdrs)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 429, in error
result = self._call_chain(*args)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 369, in _call_chain
result = func(*args)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 605, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 391, in open
response = self._open(req, data)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 409, in _open
'_open', req)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 1169, in https_open
return self.do_open(httplib.HTTPSConnection, req)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 1136, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 8] _ssl.c:480: EOF occurred in violation of protocol>
21:54:44 T:2702283176 ERROR: GetDirectory - Error getting plugin://plugin.video.netflixbmc/
21:54:44 T:2702283176 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/) failed
21:54:44 T:2953924608 NOTICE: Thread Background Loader start, auto delete: false
I'm from Germany and I'm using Smart DNS Proxy, the DNS settings are changed in my router. I can open https-sites in any browser. Haven't found a workaround in this thread. I tried to change the user agent setting in the default.py. I don't know if the delete cache and cookies buttons work in the config, I deleted them in my browser. When I uninstall the plugin and then install it again, my login credentials are still there.
What else can I try to do?
EDIT: Tried Unblockus-service and this works, so it's an smartdnsproxy issue.
