Greetins,
Here some answers for the issues you have been experiencing lately:
Loading animation spinning forever / Login data not remembered:
The issue and the possible workaround are described on the
FAQ. Unfortunately a fix for this will have to wait.
Track skipping issue
As said, a fix for this may be included on the next alpha (which will be probably released in a week or two), so be patient and stay tuned!
(2012-03-24, 16:41)adytum Wrote: [ -> ]This is an extremely well made addon! Thanks so much!
Do you have plans to implement the radio too?
Yes, it's planned for a future release.
(2012-03-26, 14:42)mattg42 Wrote: [ -> ]So in summary the Cyrus skin is causing problems here and playlists can be fixed by removing the imported iTunes ones - at least on my system.
I already have the fixes for most of the skin related startup crashes (ReFocus, Cirrus, etc.), the'll be included on the next alpha. Thanks for the iTunes playlist clue!
(2012-03-26, 19:42)Cthugha Wrote: [ -> ]Feel free to use these shots in your OP.
Thanks! Unfortunately I've noticed a new issue on these screenshots. It seems that text is displayed smaller using Xperience1080, quite different to the reference rendering with Confluence and others...
(2012-03-26, 21:50)Sambuccashake Wrote: [ -> ]I can't seem to get it too launch. (Windows 7)
"Script failed" and then the spinning thing.
Reinstalled twice but no change.
http://pastebin.com/7yp7UZyB
Did you get if from the binary packages of the lower part of the download screen? The upper left links generate only a dump of the latest version in the repository, no binary dependencies included. Try uninstalling it first, and then get it from mortstar's repo.
(2012-03-26, 23:53)baldsasquatch Wrote: [ -> ]I get Script failed. script.audio.spotify. Then exits.
Mmm, would love to see a debug log. Hopefully it's a bug described earlier on this thread and a fix is on the works.
(2012-03-27, 19:36)Cthugha Wrote: [ -> ] (2012-03-27, 19:22)cloverfield Wrote: [ -> ]Do I need a premium account for this plugin? I do think so, bad use only in the original client you can use spotify free. Or do I think wrong?
That's right, you need Spotify Premium for this to work.
Would love to see a webUI for this addon, or any other kind of "remote access"
It's built on top of the official Spotify api, and they require a premium account.
Regarding to the WebUI thing, I'm considering it for a future release. Thanks!
(2012-03-27, 22:38)Fox Wrote: [ -> ]One thing I noticed is if you have local music added in a playlist it will stop playing in the middle of the song that is before the local song. Guess thats when it tries to start buffering for the next song and realize it can't find it.
Mmmm are you sure? As far as I know it fails randomly regardless local tracks are present or not.
(2012-03-28, 15:38)Bendecks Wrote: [ -> ] (2012-03-11, 01:38)mortstar Wrote: [ -> ]Queue and Add to playlist are already on my to-do list.
Would cream for this :p
Any eta.?
Sorry, no eta yet. I'll try to fix crashes and annoying bugs first and then continue adding functionality. I also believe that they are required features, but they are more complicated than they may look.
