2015-04-04, 07:58
2015-04-04, 07:58
2015-04-04, 08:35
just installed and worked like a charm,thanks for addon!+1
2015-04-04, 15:33
(2015-04-04, 07:58)Jandalf Wrote: [ -> ](2015-04-03, 16:03)HeresJohnny Wrote: [ -> ]Helix 14.2 error:
"Add-on does not have the correct structure."(2015-04-03, 22:44)Slipx Wrote: [ -> ]I'm getting the same error
sorry, something went wrong with the zip file. I fixed the problem, redownload the zip file.
Just re downloaded and still getting the same error
2015-04-04, 16:15
(2015-04-04, 15:33)Slipx Wrote: [ -> ]Just re downloaded and still getting the same error
did you really download it using this link: https://github.com/Jandalf/script.imdbup...-0.6.0.zip ?
try to uninstall an existing version of this addon first. Just tested it again and there were no errors.
2015-04-05, 09:18
(2015-04-04, 16:15)Jandalf Wrote: [ -> ](2015-04-04, 15:33)Slipx Wrote: [ -> ]Just re downloaded and still getting the same error
Yes. I'm running OpenElec. I don't have a previous version installed. I could try manually extracting into the add-on directory?
2015-04-05, 09:56
I also had the same issue after redownloading but all i needed to do was to restart Kodi and then it installed without complaints.
2015-04-05, 12:11
(2015-04-05, 09:56)stromrickard Wrote: [ -> ]I also had the same issue after redownloading but all i needed to do was to restart Kodi and then it installed without complaints.
Thanks. A restart fixed the issue
2015-04-06, 12:06
ok, thanks for the help. seems strange...
2015-04-07, 19:18
Im new @kodi and spend some time to scrap my Movies, change Covers, cdarts .... with the integrated moviedb scraper.
After all that work i realized that no Age Rating was inserted into my MySQL Database
Now i know its a bug when scraping ratings from moviedb and not imdb.
OK scrap all data new and all covers or insert age rating manually
Then i read your code, extended it a little bit and now i can scrap all the Age Ratings with one Click
At the Moment he scrap only the German FSK Ratings from https://altersfreigaben.de/api_desc.html and insert it to Database like the integrated Kodi Scraper "Rated XX"
With a little bit more time i can add also usa and other mpaa ratings, a Config Option for Format in Database like "germany:xx", better code and so on if you like my work at your addon.
Here is the diff code to your actual Git Version: http://pastebin.com/JT7Bq59t
Edit: I have added two new Options:
MPAA Language: DE or US - DE comes from altersfreigabe.de, US comes also from omdb
MPAA Format: Rated|USA:|FSK|Germany: - Format as it save to Database (germany: 6, FSK 6, Rated R and so on)
Also the Database will only be updated if the new and old variable are different.
2015-04-08, 19:17
(2015-04-07, 19:18)semool Wrote: [ -> ]Im new @kodi and spend some time to scrap my Movies, change Covers, cdarts .... with the integrated moviedb scraper.
After all that work i realized that no Age Rating was inserted into my MySQL DatabaseNow i know its a bug when scraping ratings from moviedb and not imdb.
very nice! I can add this to the addon, if you make a pull request to the github repository: https://github.com/Jandalf/script.imdbupdate
I like your work, if you have other ideas, feel free to implement them
2015-04-08, 20:11
OK Pull Request is send.
I am glad that you like my work.
Eventually i add the same thing for TV Shows when i find a good Source for Rating.
2015-04-09, 18:18
(2015-04-08, 20:11)semool Wrote: [ -> ]OK Pull Request is send.
ok, I will release a version next week, need to get some other things done.
TV shows have no IMDb ID so you need to match be name, thats a bit weird...
2015-04-12, 16:10
new version:
- new feature: write missingTop250.csv
- new feature: update MPAA rating for Movies (Credits to loomes)
Download:
script.imdbupdate-0.7.1.zip
2015-04-12, 18:52
PHP Code:
18:51:49 T:7008 NOTICE: [IMDB Update] - Starting IMDB Update v0.7.0
18:51:51 T:7008 NOTICE: [IMDB Update] - Movies IMDb Top250 summary: updated: 0, added: 0, removed: 0, missing: 218
18:51:51 T:7008 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.NameError'>
Error Contents: global name 'notification' is not defined
File "C:\Users\sualfred\AppData\Roaming\Kodi\addons\script.imdbupdate\default.py", line 48, in <module>
Top250().start(hidden)
File "C:\Users\sualfred\AppData\Roaming\Kodi\addons\script.imdbupdate\resources\lib\top250.py", line 32, in start
self.startProcess(movies, length)
File "C:\Users\sualfred\AppData\Roaming\Kodi\addons\script.imdbupdate\resources\lib\top250.py", line 71, in startProcess
notification("%s %s" % (l("Completed"), l("Top250")))
NameError: global name 'notification' is not defined
Your changes broke the hidden process.
2015-04-12, 19:56
(2015-04-12, 18:52)sualfred Wrote: [ -> ]PHP Code:18:51:49 T:7008 NOTICE: [IMDB Update] - Starting IMDB Update v0.7.0
damn
