Full Version: LanDrive/LanDrive (3.5" HDD NAS enclosure) SMB/SAMBA problems
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
bought a landrive one like this one..
http://www.usbex.com/landrive
or
http://www.fan-tec.com/html/en/0/article.html
when i am viewing the folders on my landrive share
the xbox often halts. the times it works, the xbox
halts when i change folder.
the landrive works pretty good when my folders dont
have so much entries in them (like folder and files).
when a i notice that my xbox doesnt follow the
commands i give it. (like the back and start button)
i still can start files on the share. but xbmc hangs
when it tries to chache...
is it a problem with xbmc usage of smb protocol or
perhaps different versions on the landrive and xbmc,
idont know.
help!!..
24-07-2002 04:22:54 notice
24-07-2002 04:22:54 notice starting xboxmediacenter. built
on dec 13 2005
24-07-2002 04:22:54 notice q is mapped to:
harddisk0\partition1\apps\xbmc.1216
24-07-2002 04:22:54 notice log file is located: q:\xbmc.log
24-07-2002 04:22:54 notice setup directx
24-07-2002 04:22:54 info available videomodes:
24-07-2002 04:22:54 info found mode: 720x480 at 50hz,
widescreen
24-07-2002 04:22:54 info found mode: 720x576 at 50hz,
widescreen
24-07-2002 04:22:54 info found mode: 720x480 at 60hz,
widescreen
24-07-2002 04:22:54 notice load settings...
24-07-2002 04:22:54 notice loading t:\settings.xml
24-07-2002 04:22:54 notice getting hardware information now...
24-07-2002 04:22:54 info using analog output
24-07-2002 04:22:54 info ac3 pass through is disabled
24-07-2002 04:22:54 info dts pass through is disabled
24-07-2002 04:22:54 notice checking resolution 7
24-07-2002 04:22:54 info av pack: standard
24-07-2002 04:22:54 info av flags: widescreen,pal60
24-07-2002 04:22:54 notice loading q:\xboxmediacenter.xml
24-07-2002 04:22:54 info key combination detected for full
debug logging (x+y)
24-07-2002 04:22:55 info map drives...
24-07-2002 04:22:55 info map drive c:
24-07-2002 04:22:55 info map drive e:
24-07-2002 04:22:55 info map drive d:
24-07-2002 04:22:55 info map drive f:
24-07-2002 04:22:55 info drives are mapped
24-07-2002 04:22:55 info checking skinpath existance, and
existence of keymap.xml:q:\skin...
24-07-2002 04:22:55 debug setting resolution 7
24-07-2002 04:22:55 debug we set resolution 7
24-07-2002 04:22:55 info load language
file:q:\language\swedish\strings.xml
24-07-2002 04:22:55 notice loaded
q:\system\players\mplayer\iso639-1.xml
q:\system\players\mplayer\iso639-2.xml
24-07-2002 04:22:55 info load keymapping
24-07-2002 04:22:55 info loading q:\keymap.xml
24-07-2002 04:22:55 info checking skin version of: project
mayhem iii
24-07-2002 04:22:55 info skin version is: 1.8
24-07-2002 04:22:55 info gui format 720x576 pal 16:9
24-07-2002 04:22:55 info gui screen offset (0,0)
24-07-2002 04:22:55 info install unhandled exception filter
24-07-2002 04:22:55 info creating subdirectories
24-07-2002 04:22:55 info thumbnails folder:q:\thumbs
24-07-2002 04:22:55 info shortcuts folder:q:\shortcuts
24-07-2002 04:22:55 info albums folder:q:\albums
24-07-2002 04:22:55 info recording folder:q:\recordings
24-07-2002 04:22:55 info screenshots folder:q:\screenshots
24-07-2002 04:22:55 info subtitle folder:q:\subtitles
24-07-2002 04:22:55 notice initialize assignment:[dash]
network ip:[192.168.0.3] netmask:[255.255.255.0]
gateway:[192.168.0.1] nameserver:[0.0.0.0]
24-07-2002 04:22:55 warning not initializing network, using
settings as they are setup by dashboard
24-07-2002 04:22:55 info init network
24-07-2002 04:22:55 info get local ip address:
24-07-2002 04:22:55 info ip adres:192.168.0.2
24-07-2002 04:22:55 notice start webserver
24-07-2002 04:22:55 debug xbmchttpshim starts
24-07-2002 04:22:55 info webserver: server starting using
q:\web on 192.168.0.2:80
24-07-2002 04:22:55 debug db: registering database table
<users>
<groups>
<access>
24-07-2002 04:22:55 debug um: loading user configuration
from file <umconfig.txt>
24-07-2002 04:22:55 debug db: about to read data file
<q:\web\umconfig.txt>
24-07-2002 04:22:56 debug webs: listening for http requests
at address 192.168.0.2
24-07-2002 04:22:56 notice xbfilezilla: starting...
24-07-2002 04:22:56 notice xbfilezilla: started
24-07-2002 04:22:56 notice checking the date!
24-07-2002 04:22:56 info - current date is: 24-7-2002
24-07-2002 04:22:56 notice start dvd mediatype detection
24-07-2002 04:22:56 notice initializing playlistplayer
24-07-2002 04:22:56 info lcd not used
24-07-2002 04:22:56 notice load default skin:[project mayhem
iii]
24-07-2002 04:22:56 info load skin from:q:\skin\project
mayhem iii
24-07-2002 04:22:56 info delete old skin...
24-07-2002 04:22:56 info default 4:3 resolution directory is
q:\skin\project mayhem iii\pal
24-07-2002 04:22:56 info default 16:9 resolution directory
is q:\skin\project mayhem iii\pal16x9
24-07-2002 04:22:56 info skin version is: 1.8
24-07-2002 04:22:56 info load fonts for skin...
24-07-2002 04:22:56 info loading fonts from q:\skin\project
mayhem iii\pal16x9\font.xml
24-07-2002 04:22:56 info load font:font13
path:q:\skin\project mayhem iii\fonts\common-font13.xpr
24-07-2002 04:22:56 info load font:font14
path:q:\skin\project mayhem iii\fonts\common-font14.xpr
24-07-2002 04:22:56 info load font:matrix8
path:q:\skin\project mayhem iii\fonts\matrix8.xpr
24-07-2002 04:22:56 info load font:font04
24-07-2002 04:22:56 info load font:font10
path:q:\skin\project mayhem iii\fonts\common-font10.xpr
24-07-2002 04:22:56 info load font:font12
path:q:\skin\project mayhem iii\fonts\common-font12.xpr
24-07-2002 04:22:56 info load font:fontkb
24-07-2002 04:22:56 info load font:font101
24-07-2002 04:22:56 info load fontConfusedpecial12
path:q:\skin\project mayhem iii\fonts\special-normal-pal.xpr
24-07-2002 04:22:56 info load fontConfusedpecial13
path:q:\skin\project mayhem iii\fonts\special-bold-pal.xpr
24-07-2002 04:22:56 info load font:fontbl
24-07-2002 04:22:56 info load new skin...
24-07-2002 04:22:56 info loading skin file: home.xml
24-07-2002 04:22:56 info loading references file:
q:\skin\project mayhem iii\pal16x9\references.xml
24-07-2002 04:22:56 info loading user windows
q:\skin\project mayhem iii\pal16x9\custom*.xml
24-07-2002 04:22:56 info loading skin file: q:\skin\project
mayhem iii\pal16x9\custom1.xml
mayhem iii\pal16x9\custom3.xml
mayhem iii\pal16x9\custom4.xml
mayhem iii\pal16x9\custom5.xml
24-07-2002 04:22:56 info initialize new skin...
24-07-2002 04:22:56 info loading skin file: pointer.xml
24-07-2002 04:22:56 info loading skin file: musicoverlay.xml
24-07-2002 04:22:56 info loading skin file: videooverlay.xml
24-07-2002 04:22:56 info loading skin file: dialogvolumebar.xml
24-07-2002 04:22:56 info loading skin file: dialogseekbar.xml
24-07-2002 04:22:57 info loading skin file: dialogkaitoast.xml
24-07-2002 04:22:57 info loading skin file: dialogmutebug.xml
24-07-2002 04:22:57 info loading q:\skin\project mayhem
iii\sounds\sounds.xml
24-07-2002 04:22:57 info skin loaded...
24-07-2002 04:22:57 info activating window id: 10000
24-07-2002 04:22:57 info removing tempfiles
24-07-2002 04:22:57 notice initialize done
24-07-2002 04:22:57 notice running the application...
24-07-2002 04:22:57 debug loadlibrarya('zlib.pyd')
24-07-2002 04:22:57 warning kernel32.dll fake function
disablethreadlibrarycalls called
24-07-2002 04:22:57 debug loadlibrary('zlib.pyd')
returning:
0x8325b0
24-07-2002 04:22:57 debug zlib.pyd!getprocaddress(0x8325b0,
'initzlib') => 0x962210
24-07-2002 04:22:57 info -->python initialized<--
24-07-2002 04:22:58 warning kernel32.dll fake function
24-07-2002 04:22:58 info get url:
http://www.xbox-scene.com/xbox1data/xbox-scene.xml
24-07-2002 04:22:58 debug got rss feed:
24-07-2002 04:22:58 debug rss feed encoding: utf-8
24-07-2002 04:22:58 debug parsed rss feed:
24-07-2002 04:22:58 debug filecurl::close(d062db84)
24-07-2002 04:23:03 debug freevisualisation() started
24-07-2002 04:23:03 debug freevisualisation() done
24-07-2002 04:23:03 info activating window id: 10006
24-07-2002 04:23:03 info attempting to default to:
24-07-2002 04:23:03 info loading skin file: myvideo.xml
24-07-2002 04:23:03 debug cguiwindowvideofiles::getdirectory ()
24-07-2002 04:23:03 debug parentpath = []
24-07-2002 04:23:03 debug fetching directory ()
24-07-2002 04:23:03 debug current m_vecpathhistory:
24-07-2002 04:23:03 debug 00.[]
24-07-2002 04:23:05 debug cguiwindowvideofiles::getdirectory
(smb://192.168.0.5/public/)
24-07-2002 04:23:05 debug parentpath = []
24-07-2002 04:23:05 debug fetching directory
24-07-2002 04:23:15 debug cvideodatabase::getmoviesbypath
query = select * from path join files on path.idpath =
files.idpath join movieinfo on files.idmovie =
movieinfo.idmovie where path.strpath like
'%smb://192.168.0.5/public' or path.strpath like
'%stack://smb://192.168.0.5/public'
24-07-2002 04:23:15 debug current m_vecpathhistory:
24-07-2002 04:23:15 debug 00.[]
24-07-2002 04:23:15 debug 01.[smb://192.168.0.5/public/]
24-07-2002 04:23:18 debug cguiwindowvideofiles::getdirectory
(smb://192.168.0.5/public/serier/)
24-07-2002 04:23:18 debug parentpath =
24-07-2002 04:23:18 debug fetching directory
24-07-2002 04:23:18 debug cvideodatabase::getmoviesbypath
'%smb://192.168.0.5/public/serier' or path.strpath
like
'%stack://smb://192.168.0.5/public/serier'
24-07-2002 04:23:18 debug current m_vecpathhistory:
24-07-2002 04:23:18 debug 00.[]
24-07-2002 04:23:18 debug 01.[smb://192.168.0.5/public/]
02.[smb://192.168.0.5/public/serier/]
24-07-2002 04:23:19 debug cguiwindowvideofiles::getdirectory
(smb://192.168.0.5/public/serier/drama/)
24-07-2002 04:23:19 debug parentpath =
24-07-2002 04:23:19 debug fetching directory
24-07-2002 04:23:19 debug cvideodatabase::getmoviesbypath
'%smb://192.168.0.5/public/serier/drama' or
path.strpath
like '%stack://smb://192.168.0.5/public/serier/drama'
24-07-2002 04:23:19 debug current m_vecpathhistory:
24-07-2002 04:23:19 debug 00.[]
24-07-2002 04:23:19 debug 01.[smb://192.168.0.5/public/]
03.[smb://192.168.0.5/public/serier/drama/]
24-07-2002 04:23:20 debug cguiwindowvideofiles::getdirectory
(smb://192.168.0.5/public/serier/drama/gilmoregirls/)
24-07-2002 04:23:20 debug parentpath =
24-07-2002 04:23:20 debug fetching directory
24-07-2002 04:23:20 debug cvideodatabase::getmoviesbypath
'%smb://192.168.0.5/public/serier/drama/gilmoregirls'
or
path.strpath like
'%stack://smb://192.168.0.5/public/serier/drama/gilmoregirls'
24-07-2002 04:23:20 debug current m_vecpathhistory:
24-07-2002 04:23:20 debug 00.[]
24-07-2002 04:23:20 debug 01.[smb://192.168.0.5/public/]
04.[smb://192.168.0.5/public/serier/drama/gilmoregirls/]
24-07-2002 04:23:22 debug cguiwindowvideofiles::getdirectory
(smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/)
24-07-2002 04:23:22 debug parentpath =
24-07-2002 04:23:22 debug fetching directory
24-07-2002 04:23:22 debug cvideodatabase::getmoviesbypath
'%smb://192.168.0.5/public/serier/drama/gilmoregirls/s2'
or
path.strpath like
'%stack://smb://192.168.0.5/public/serier/drama/gilmoregirls/s2'
24-07-2002 04:23:22 debug current m_vecpathhistory:
24-07-2002 04:23:22 debug 00.[]
24-07-2002 04:23:22 debug 01.[smb://192.168.0.5/public/]
05.[smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/]
24-07-2002 04:23:24 debug item:
smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e17.dvdrip.xvid-river.[bt].avi
24-07-2002 04:23:24 info mplayer
playConfusedmb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e17.dvdrip.xvid-river.[bt].avi
cachesize:8192
24-07-2002 04:23:24 debug msg: set audio functions called
24-07-2002 04:23:24 debug msg: done
24-07-2002 04:23:24 info flipping bi-directional subtitles
disabled
24-07-2002 04:23:24 debug msg:mplayer_init()
24-07-2002 04:23:24 debug msg:enable mplayer osd
dev-cvs-051019-22:33-3.4.4 &copy; 2000-2004 mplayer team
24-07-2002 04:23:24 debug msg:cpu: intel celeron 2/pentium
iii coppermine,geyserville
24-07-2002 04:23:24 debug msgSadfamily: 6, stepping: 10)
24-07-2002 04:23:24 debug msg:detected cache-line size is
32 bytes
24-07-2002 04:23:24 debug msg:cpuflags: mmx: 1 mmx2: 1
3dnow: 0 3dnow2: 0 sse: 0 sse2: 0
24-07-2002 04:23:24 debug msg:compiled for x86 cpu with
extensions:
24-07-2002 04:23:24 debug msg: mmx
24-07-2002 04:23:24 debug msg: mmx2
24-07-2002 04:23:24 debug msg: sse
24-07-2002 04:23:24 debug msg:creating config file:
q:\system\players\mplayer\config
24-07-2002 04:23:24 debug msg:88 audio & 199 video codecs
msg:mplayer_open_file(smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e17.dvdrip.xvid-river.[bt].avi)
24-07-2002 04:23:24 info stating file
smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e17.dvdrip.xvid-river.[bt].avi.conf
q:\system\players\mplayer\gilmore.girls.s02e17.dvdrip.xvid-river.[bt].avi.conf
24-07-2002 04:23:24 debug msg:playing
24-07-2002 04:23:24 debug msg:find subtitles
24-07-2002 04:23:24 debug msg:auto open z:\subtitle
24-07-2002 04:23:24 debug msg:protocolConfusedmb
24-07-2002 04:23:24 debug msg:use standard file for
protocolConfusedmb
24-07-2002 04:23:24 debug msg:option stream url: this url
doesn't have a hostname part.
cache fill: 0.00% (0 bytes)
24-07-2002 04:23:25 debug msg:
cache fill: 0.78% (65536 bytes)
cache fill: 1.56% (131072 bytes)
cache fill: 2.34% (196608 bytes)
cache fill: 3.13% (262144 bytes)
cache fill: 3.91% (327680 bytes)
cache fill: 4.69% (393216 bytes)
cache fill: 5.47% (458752 bytes)
cache fill: 6.25% (524288 bytes)
cache fill: 7.03% (589824 bytes)
cache fill: 7.81% (655360 bytes)
cache fill: 8.59% (720896 bytes)
cache fill: 9.38% (786432 bytes)
cache fill: 10.16% (851968 bytes)
cache fill: 10.94% (917504 bytes)
cache fill: 11.72% (983040 bytes)
cache fill: 12.50% (1048576 bytes)
cache fill: 13.28% (1114112 bytes)
cache fill: 14.06% (1179648 bytes)
cache fill: 14.84% (1245184 bytes)
cache fill: 15.63% (1310720 bytes)
cache fill: 16.41% (1376256 bytes)
cache fill: 17.19% (1441792 bytes)
24-07-2002 04:23:26 debug msg:
cache fill: 17.97% (1507328 bytes)
cache fill: 18.75% (1572864 bytes)
cache fill: 19.53% (1638400 bytes)
24-07-2002 04:23:26 debug msg:avi file format detected.
24-07-2002 04:23:27 info loading skin file: dialogprogress.xml
24-07-2002 04:23:28 debug msg:video: [xvid] 576x432
12bpp 23.976 fps 973.9 kbps (118.9 kbyte/s)
24-07-2002 04:23:28 debug msg:clip info:
24-07-2002 04:23:28 debug msg: software: virtualdubmod
1.5.10.1 (build 2439/release)
24-07-2002 04:23:28 debug msgConfusedtarting lookup for subs
24-07-2002 04:23:28 debug msg:global subsize: 0 - vobsub:
-1, demux: -1, subs: -1
24-07-2002 04:23:28 debug msg:global subpos : -1
msg:==========================================================================
24-07-2002 04:23:28 debug msg:opening audio decoder:
[mp3lib] mpeg layer-2, layer-3
24-07-2002 04:23:28 debug msg:audio: 48000 hz, 2 ch, 16
bit (0x10), ratio: 10000->192000 (80.0 kbit)
24-07-2002 04:23:28 debug msgConfusedelected audio codec: [mp3]
afm:mp3lib (mp3lib mpeg layer-2, layer-3)
24-07-2002 04:23:28 debug msg:opening video decoder:
[ffmpeg] ffmpeg's libavcodec codec family
24-07-2002 04:23:28 debug msgConfusedelected video codec:
[ffodivx] vfm:ffmpeg (ffmpeg mpeg-4)
24-07-2002 04:23:28 debug msg:checking audio filter chain
for 48000hz/2ch/16bit -> 48000hz/6ch/16bit...
24-07-2002 04:23:28 debug msg:af_pre: af format: 2 bps, 2
ch, 48000 hz, little endian signed int
24-07-2002 04:23:28 debug msg:af_pre: 48000hz 2ch signed
16-bit (little-endian)
24-07-2002 04:23:28 debug msg:ao: [win32] 48000hz 2ch
signed 16-bit (little-endian) (2 bps)
24-07-2002 04:23:28 debug msg:building audio filter chain
for 48000hz/2ch/16bit -> 48000hz/2ch/16bit...
24-07-2002 04:23:28 debug msgConfusedtarting playback...
done 1.0000
24-07-2002 04:23:28 debug playback has started
24-07-2002 04:23:28 info activating window id: 12005
24-07-2002 04:23:28 info loading skin file: videofullscreen.xml
24-07-2002 04:23:28 info loading skin file: videoosd.xml
videoosdsettings.xml
24-07-2002 04:23:28 debug msg:vdec: vo config request -
576 x 432 (preferred csp: planar yv12)
24-07-2002 04:23:28 debug msg:vdec: using planar yv12 as
output csp (no 0)
24-07-2002 04:23:28 debug msg:movie-aspect is 1.33:1 -
prescaling to correct movie aspect.
24-07-2002 04:23:28 debug msg:vo: [directx] 576x432 =>
576x432 planar yv12
24-07-2002 04:23:28 info created yuv texture
24-07-2002 04:23:28 debug created yv12 texture 0
cguiinfomanager:Confusedetcurrentmovie(smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e17.dvdrip.xvid-river.[bt].avi)
24-07-2002 04:23:28 debug msg:ffrw:normal play
24-07-2002 04:23:32 debug msg: mplayer_close_file()
24-07-2002 04:23:32 debug msg: uninit_player
24-07-2002 04:23:32 debug deleted yv12 texture (0)
24-07-2002 04:23:32 debug deleted yuv video texture
24-07-2002 04:23:32 debug msg: uninit_player - done
24-07-2002 04:23:32 debug freeing fs segment @ 0x768220
24-07-2002 04:23:32 debug setting resolution 7
24-07-2002 04:23:32 debug we set resolution 7
24-07-2002 04:23:32 info loading skin file: myvideo.xml
24-07-2002 04:23:33 debug cguiwindowvideofiles::getdirectory
24-07-2002 04:23:33 debug parentpath =
24-07-2002 04:23:33 debug fetching directory
24-07-2002 04:23:33 debug cvideodatabase::getmoviesbypath
or
path.strpath like
24-07-2002 04:23:33 debug current m_vecpathhistory:
24-07-2002 04:23:33 debug 00.[]
24-07-2002 04:23:33 debug 01.[smb://192.168.0.5/public/]
24-07-2002 04:23:34 debug item:
smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].avi
24-07-2002 04:23:34 info mplayer
playConfusedmb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].avi
cachesize:8192
24-07-2002 04:23:34 error cmplayer::openfile()
failed
24-07-2002 04:23:34 error playlist player: skipping
unplayable item: 0, path
[smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].avi]
24-07-2002 04:23:42 info filesmb->open: unable to open file
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].utf'
unix_err:'2' nt_err : 'c0000034' error :
'nt_status_object_name_not_found'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].utf8'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].utf-8'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].sub'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].srt'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].smi'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].rt'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].txt'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].ssa'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].aqt'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].jss'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].ass'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].idx'
'smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].ifo'
24-07-2002 04:23:42 debug item:
24-07-2002 04:23:42 info mplayer
cachesize:8192
24-07-2002 04:23:43 debug initializing fs_seg..
24-07-2002 04:23:43 debug fs segment @ 0x768220
24-07-2002 04:23:43 debug msg: set audio functions called
24-07-2002 04:23:43 debug msg: done
24-07-2002 04:23:43 info flipping bi-directional subtitles
disabled
24-07-2002 04:23:43 debug msg:mplayer_init()
24-07-2002 04:23:43 debug msg:enable mplayer osd
24-07-2002 04:23:43 debug msg:cpu: intel celeron 2/pentium
24-07-2002 04:23:43 debug msgSadfamily: 6, stepping: 10)
24-07-2002 04:23:43 debug msg:detected cache-line size is
32 bytes
24-07-2002 04:23:43 debug msg:cpuflags: mmx: 1 mmx2: 1
24-07-2002 04:23:43 debug msg:compiled for x86 cpu with
extensions:
24-07-2002 04:23:43 debug msg: mmx
24-07-2002 04:23:43 debug msg: mmx2
24-07-2002 04:23:43 debug msg: sse
24-07-2002 04:23:43 debug msg:creating config file:
24-07-2002 04:23:43 debug msg:88 audio & 199 video codecs
msg:mplayer_open_file(smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].avi)
24-07-2002 04:23:43 info stating file
smb://192.168.0.5/public/serier/drama/gilmoregirls/s2/gilmore.girls.s02e18.dvdrip.xvid-river.[bt].avi.conf
q:\system\players\mplayer\gilmore.girls.s02e18.dvdrip.xvid-river.[bt].avi.conf
24-07-2002 04:23:43 debug msg:playing
24-07-2002 04:23:43 debug msg:find subtitles
24-07-2002 04:23:43 debug msg:auto open z:\subtitle
24-07-2002 04:23:43 debug msg:protocolConfusedmb
24-07-2002 04:23:43 debug msg:use standard file for
protocolConfusedmb
24-07-2002 04:23:43 debug msg:option stream url: this url
24-07-2002 04:23:44 debug msg:
24-07-2002 04:23:45 debug msg:
24-07-2002 04:23:45 info loading skin file: dialogprogress.xml
24-07-2002 04:23:46 debug msg:
24-07-2002 04:23:47 debug msg:
24-07-2002 04:23:48 debug msg:
24-07-2002 04:23:49 debug msg:
24-07-2002 04:23:50 debug msg:
24-07-2002 04:23:51 debug msg:
24-07-2002 04:23:52 debug msg:
24-07-2002 04:23:53 debug msg:
24-07-2002 04:23:54 debug msg:
24-07-2002 04:23:55 debug msg:
24-07-2002 04:23:56 debug msg:
24-07-2002 04:23:57 debug msg:
24-07-2002 04:23:58 debug msg:
24-07-2002 04:23:59 debug msg:
24-07-2002 04:24:00 debug msg:
24-07-2002 04:24:01 debug msg:
24-07
asfar as i can tell, there is no error occureing.. just looks like the server doesn't deliver any data to xbmc. no idea why that can be.
soo it seams,, but why does it never happend when u try the same thing from a regular windows/linux mashine??.
when i notice the next click is going to hang the xbox i tryed to get an video/mp3 from my stationary pc (whicth i never have had any probs with) but the same caching problems happends.
so i took the conclution that it must be something in the xbmc.
someone please give me som input??!!
i would really apriciate it
i suppose increasing the samba loglevel in xboxmediacenter.xml could give some info.. kinda doubt it will help thou Sad
but what can couse xbmc to freeze , all other op´s dont get things like this,,, and the strange thing is that when the "bug" comes along it hangs even when i try to stream from my stationary pc.
the file is there but why doesnt it resive it Confused
ffs someone of the developers must know!!!
and a friend of with the same problem/configuration and tryed using ccxgui and it worked fine with the lan drive that way ,, but i want to be able so shut down the main comp and still be able to listen/watch movies
(validus @ feb. 22 2006,09:54 Wrote:bought a landrive one like this one..
or
idont know.
help!!..
i have the same exact problem as you. if the folders dont have alot of files, no real issues....
anyboby have any ideas? increase the network cache?
i dont think increasing the cache level would help becouse it doesn recive anything from the disk when using smb protocol Confused ,,, work just fine with "ccxgui" but that kinda dizzes the point of a network storage.
(validus @ mar. 02 2006,00:57 Wrote:i dont think increasing the cache level would help becouse it doesn recive anything from the disk when using smb protocol Confused ,,, work just fine with "ccxgui" but that kinda dizzes the point of a network storage.
anybody else have an idea??
another interesting point is that people with samba shares on their local drives haven't had any issues, where as the network drives have.
i have a cobalt raq3 just sitting around....maybe it's time to revive that project and build me a real file server.
does anyone know where the problem is , is it the landrive or is it the xbmc ,, doens matter what build i use,, always the same problem Confused
please give me some help and suggestions
the problem is likely with the combination.. looks like the nas drive (or xbmc) drops the connection, but xbmc doesn't notice it. like stated before, if somebody could increase their smb loglevel in xboxmediacenter.xml and post log, we might get one step closer.
