i have upgraded to the 2006-04-12 t3ch build and am having the same problems with the contents of smb shares not being displayed.
i also have a build from the end of march that i also use, which picks up the content of the smb shares flawlessly.
whatever the problem is, it's crept in the last few builds.
log: (bookmark stuff snipped)
13:40:03 m: 54521856 info: map drives...
13:40:03 m: 54521856 info: map drive c:
13:40:03 m: 54521856 info: map drive e:
13:40:03 m: 54521856 info: map drive d:
13:40:03 m: 54521856 info: map drive f:
13:40:03 m: 54521856 info: drives are mapped
13:40:03 m: 54521856 info: checking skinpath existance, and existence of keymap.xml:q:\skin...
13:40:03 m: 54521856 debug: setting resolution 6
13:40:03 m: 54521856 debug: we set resolution 6
13:40:03 m: 49614848 debug: setting resolution 6
13:40:03 m: 49614848 debug: we set resolution 6
13:40:03 m: 49614848 info: load language info file:q:\language\english\langinfo.xml
13:40:03 m: 49090560 info: load language file:q:\language\english\strings.xml
13:40:04 m: 48939008 notice: loaded q:\system\players\mplayer\iso639-1.xml
13:40:04 m: 48898048 notice: loaded q:\system\players\mplayer\iso639-2.xml
13:40:04 m: 48898048 info: load keymapping
13:40:04 m: 48898048 info: loading q:\keymap.xml
13:40:04 m: 48852992 info: checking skin version of: project mayhem iii
13:40:04 m: 48852992 info: skin version is: 2.0
13:40:04 m: 48852992 info: gui format 720x576 pal 4:3
13:40:04 m: 48775168 info: install unhandled exception filter
13:40:04 m: 48775168 info: creating subdirectories
13:40:04 m: 48775168 info: shortcuts folder:q:\shortcuts
13:40:04 m: 48775168 info: albums folder:q:\albums
13:40:04 m: 48775168 info: recording folder:q:\recordings
13:40:04 m: 48775168 info: screenshots folder:q:\screenshots
13:40:04 m: 48775168 info: thumbnails folder:q:\thumbs
13:40:04 m: 48775168 info: playlists folder:q:\albums\playlists
13:40:04 m: 48775168 info: subtitle folder:q:\subtitles
13:40:04 m: 48775168 notice: initialize assignment:[dash] network ip:[192.168.0.3] netmask:[255.255.255.0] gateway:[192.168.0.1] nameserver:[0.0.0.0]
13:40:04 m: 48775168 warning: not initializing network, using settings as they are setup by dashboard
13:40:04 m: 48775168 info: init network
13:40:04 m: 48455680 info: get local ip address:
13:40:06 m: 48455680 info: ip adres:192.168.1.105
13:40:06 m: 48455680 notice: start webserver
13:40:06 m: 48369664 debug: xbmchttpshim starts
13:40:06 m: 47779840 info: webserver: server starting using q:\web on 192.168.1.105:80
13:40:06 m: 47779840 debug: db: registering database table <users>
13:40:06 m: 47779840 debug: db: registering database table <groups>
13:40:06 m: 47779840 debug: db: registering database table <access>
13:40:06 m: 47779840 debug: um: loading user configuration from file <umconfig.txt>
13:40:06 m: 47779840 debug: db: about to read data file <q:\web\umconfig.txt>
13:40:06 m: 47779840 debug: db: failed to stat persistent data file.
13:40:06 m: 47779840 debug: webs: listening for http requests at address 192.168.1.105
13:40:06 m: 47779840 notice: xbfilezilla: starting...
13:40:06 m: 45658112 notice: xbfilezilla: started
13:40:06 m: 45658112 notice: checking the date!
13:40:06 m: 45658112 info: - current date is: 14-4-2006
13:40:06 m: 45658112 notice: start dvd mediatype detection
13:40:06 m: 45133824 notice: initializing playlistplayer
13:40:06 m: 45133824 info: lcd not used
13:40:06 m: 45133824 notice: load default skin:[project mayhem iii]
13:40:06 m: 45133824 info: load skin from:q:\skin\project mayhem iii
13:40:06 m: 45133824 info: delete old skin...
13:40:06 m: 45133824 info: default 4:3 resolution directory is q:\skin\project mayhem iii\pal
13:40:06 m: 45133824 info: default 16:9 resolution directory is q:\skin\project mayhem iii\pal16x9
13:40:06 m: 45133824 info: skin version is: 2.0
13:40:06 m: 45133824 info: loading skin includes from q:\skin\project mayhem iii\pal\includes.xml
13:40:06 m: 45109248 info: load fonts for skin...
13:40:06 m: 45109248 info: loading fonts from q:\skin\project mayhem iii\pal\font.xml
13:40:06 m: 45109248 info: load font:common-font13.xpr path:q:\skin\project mayhem iii\fonts\common-font13.xpr
13:40:06 m: 44957696 info: load font:common-font14.xpr path:q:\skin\project mayhem iii\fonts\common-font14.xpr
13:40:06 m: 44826624 info: load font:matrix8.xpr path:q:\skin\project mayhem iii\fonts\matrix8.xpr
13:40:06 m: 44675072 info: load font:common-font10.xpr path:q:\skin\project mayhem iii\fonts\common-font10.xpr
13:40:06 m: 44609536 info: load font:common-font12.xpr path:q:\skin\project mayhem iii\fonts\common-font12.xpr
13:40:06 m: 44519424 info: load font
pecial-normal-pal.xpr path:q:\skin\project mayhem iii\fonts\special-normal-pal.xpr
13:40:06 m: 44363776 info: load font
pecial-bold-pal.xpr path:q:\skin\project mayhem iii\fonts\special-bold-pal.xpr
13:40:06 m: 44232704 info: load new skin...
13:40:06 m: 44212224 info: skin version is: 2.0
13:40:06 m: 44212224 info: loading skin file: home.xml
13:40:07 m: 44040192 info: loading references file: q:\skin\project mayhem iii\pal\references.xml
13:40:07 m: 44011520 info: loading user windows q:\skin\project mayhem iii\pal\custom*.xml
13:40:07 m: 44032000 info: loading skin file: q:\skin\project mayhem iii\pal\custom1.xml
13:40:07 m: 44027904 info: loading skin file: q:\skin\project mayhem iii\pal\custom5.xml
13:40:07 m: 44032000 info: initialize new skin...
13:40:07 m: 44032000 info: loading skin file: pointer.xml
13:40:07 m: 43683840 info: loading skin file: musicoverlay.xml
13:40:07 m: 43683840 info: loading skin file: videooverlay.xml
13:40:07 m: 43683840 info: loading skin file: dialogvolumebar.xml
13:40:07 m: 43675648 info: loading skin file: dialogseekbar.xml
13:40:07 m: 43626496 info: loading skin file: dialogkaitoast.xml
13:40:07 m: 43626496 info: loading skin file: dialogmutebug.xml
13:40:07 m: 43229184 info: loading q:\skin\project mayhem iii\sounds\sounds.xml
13:40:07 m: 43229184 info: skin loaded...
13:40:07 m: 43229184 warning: curl::curl - url has no protocol ?, empty curl created
13:40:07 m: 43323392 debug: activating window id: 10000
13:40:07 m: 42864640 info: removing tempfiles
13:40:07 m: 42864640 notice: initialize done
13:40:07 m: 42340352 notice: running the application...
13:40:07 m: 35123200 info: get url:
http://feeds.feedburner.com/xboxscene
13:40:08 m: 35074048 debug: activating window id: 10006
13:40:08 m: 36126720 debug: freevisualisation() started
13:40:08 m: 36126720 debug: freevisualisation() done
13:40:08 m: 42205184 info: attempting to default to:
13:40:08 m: 42225664 info: loading skin file: myvideo.xml
13:40:09 m: 41996288 debug: cguimediawindow::getdirectory ()
13:40:09 m: 41996288 debug: parentpath = []
13:40:09 m: 37601280 debug: got rss feed:
13:40:09 m: 38227968 debug: cguimediawindow::getdirectory (smb://192.168.1.102/)
13:40:09 m: 38227968 debug: parentpath = []
13:40:10 m: 37892096 debug: cvideodatabase::getmoviesbypath query = select * from path join files on path.idpath = files.idpath join movieinfo on files.idmovie = movieinfo.idmovie where path.strpath like '%smb://192.168.1.102' or path.strpath like '%stack://smb://192.168.1.102'
13:40:11 m: 37892096 debug: cguimediawindow::getdirectory (smb://192.168.1.102/movies/)
13:40:11 m: 37892096 debug: parentpath = [smb://192.168.1.102/]
13:40:11 m: 37752832 error: exception in capplication::framemove()
13:40:12 m: 38187008 debug: cguimediawindow::getdirectory (smb://192.168.1.102/)
13:40:12 m: 38187008 debug: parentpath = []
13:40:12 m: 38326272 debug: cvideodatabase::getmoviesbypath query = select * from path join files on path.idpath = files.idpath join movieinfo on files.idmovie = movieinfo.idmovie where path.strpath like '%smb://192.168.1.102' or path.strpath like '%stack://smb://192.168.1.102'
13:40:14 m: 38322176 debug: cguimediawindow::getdirectory (smb://192.168.1.102/public/)
13:40:14 m: 38322176 debug: parentpath = [smb://192.168.1.102/]
13:40:14 m: 38182912 error: exception in capplication::framemove()
13:40:15 m: 38187008 debug: cguimediawindow::getdirectory (smb://192.168.1.102/)
13:40:15 m: 38187008 debug: parentpath = []
13:40:15 m: 38322176 debug: cvideodatabase::getmoviesbypath query = select * from path join files on path.idpath = files.idpath join movieinfo on files.idmovie = movieinfo.idmovie where path.strpath like '%smb://192.168.1.102' or path.strpath like '%stack://smb://192.168.1.102'
13:40:16 m: 38318080 debug: cguimediawindow::getdirectory (smb://192.168.1.102/tv/)
13:40:16 m: 38318080 debug: parentpath = [smb://192.168.1.102/]
13:40:16 m: 38178816 error: exception in capplication::framemove()
13:40:17 m: 38182912 debug: cguimediawindow::getdirectory (smb://192.168.1.102/)
13:40:17 m: 38182912 debug: parentpath = []
13:40:17 m: 38322176 debug: cvideodatabase::getmoviesbypath query = select * from path join files on path.idpath = files.idpath join movieinfo on files.idmovie = movieinfo.idmovie where path.strpath like '%smb://192.168.1.102' or path.strpath like '%stack://smb://192.168.1.102'
13:40:18 m: 42819584 info: loading skin file: home.xml
13:40:22 m: 35528704 debug: activating window id: 10501
13:40:22 m: 36581376 debug: freevisualisation() started
13:40:22 m: 36581376 debug: freevisualisation() done
13:40:22 m: 42807296 info: attempting to default to:
13:40:22 m: 42795008 info: loading skin file: mymusicsongs.xml
13:40:22 m: 42610688 debug: cguimediawindow::getdirectory ()
13:40:22 m: 42610688 debug: parentpath = []
13:40:22 m: 42610688 debug: retrievemusicinfo() took 0msec
13:40:23 m: 38277120 debug: cguimediawindow::getdirectory (smb://192.168.1.102/)
13:40:23 m: 38277120 debug: parentpath = []
13:40:23 m: 38277120 debug: retrievemusicinfo() took 0msec
13:40:24 m: 38277120 debug: cguimediawindow::getdirectory (smb://192.168.1.102/music/)
13:40:24 m: 38277120 debug: parentpath = [smb://192.168.1.102/]
13:40:24 m: 38133760 error: exception in capplication::framemove()
13:40:25 m: 42651648 info: loading skin file: home.xml
13:40:27 m: 35336192 debug: activating window id: 10111
13:40:27 m: 35336192 info: loading skin file: dialogbuttonmenu.xml
13:40:29 m: 35160064 notice: storing total system uptime
13:40:29 m: 35160064 notice: saving settings
13:40:29 m: 35160064 notice: stop all
13:40:29 m: 35160064 notice: stop webserver
13:40:29 m: 35160064 debug: webserver:exiting thread sockready=0, sockselect=0.
13:40:29 m: 35160064 debug: webserver:onexit - exit web server.
13:40:29 m: 35741696 debug: xbmchttpshim ends
13:40:29 m: 35741696 notice: stop time server
13:40:29 m: 35741696 info: xbfilezilla: stopping...
13:40:29 m: 37318656 info: xbfilezilla: stopped
13:40:29 m: 37318656 notice: stop dvd detect media
13:40:30 m: 37842944 notice: stop fancontroller
13:40:30 m: 37842944 notice: stop daap clients
13:40:30 m: 37842944 notice: stop python
13:40:30 m: 37842944 notice: clean cached files!
13:40:30 m: 37842944 notice: unload skin
13:40:30 m: 39260160 debug: freevisualisation() started
13:40:30 m: 39260160 debug: freevisualisation() done
13:40:30 m: 45465600 debug: setting resolution 6
13:40:30 m: 45465600 debug: we set resolution 6
13:40:30 m: 45735936 debug: setting resolution 6
13:40:30 m: 45735936 debug: we set resolution 6
13:40:30 m: 46678016 notice: unload sections
13:40:30 m: 46764032 notice: destroy
13:40:30 m: 51716096 notice: stopped
13:40:30 m: 51716096 info: launch xbe:harddisk0\partition2 d:\evoxdash.xbe
13:40:30 m: 51716096 info: mount harddisk0\partition2 as d:
13:40:30 m: 51716096 info: launch xbe:d:\evoxdash.xbe
