Full Version: Featherence [Leia]
Pages: 1 2 3 4 5 6 7
Featherence v0.5.1-3 (16-Jun-16)
- Major bug fix with Video OSD on the subtitles window and on pause.
- Major performance update on startup.
- Major update of startup Music and Video.
- Minor update of choosing icon/fanart method.
- Minor update of skin's icons.
Featherence v0.5.4 (19-Jun-16)
- Added Multi-Fanart Cross Fade Time, Time per Image and shuffle/randomize options.
- Major bug fixed of selecting colors.
- Major bug fix with ExtendedInfo + TVshows addons.
- Skin's changelog now can be toggle on/off (Featherence Service Settings).
Featherence v0.5.8 (31-Jul-16)
- Major bug fix of coloring virtual keyboard.
- Minor bug fix of Video OSD buttons while playing live TV (PVR).
- Minor bug fix of showing top information bar upon entering a fullscreen video.
- Update video osd auto close feature.
Featherence v0.5.10 (07-Sep-16)
- Added Featherence GUI sound.
- Added option to choose delay time for Video and Audio intro.
- Added option to force volume level on startup.
- Added startup category in skin settings.
- Major bug fix with FileBrowser.
- Update auto close video/audio OSD feature.
Featherence v0.5.11 (11-Sep-16)
- Added genres icons and multilanguage labels support for several addons.
- Improve video intro feature.
- Update AutoView feature.
- Update FileBrowser window information.
Sent from my iPhone
Ok, so trying to make my way around this skin. Is there support for custom widgets or no?? Possible to configure widgets for addons or are widgets for Library only?? If possible, how do I get to widget settings to make widgets for addons?
There is no real widget support atm but you can activate sub menu for a main button (Notice the diagonal sub mark pop up) and add up some sub buttons.
Sent from my iPhone
(2016-09-13, 23:13)finalmakerr Wrote: [ -> ]There is no real widget support atm but you can activate sub menu for a main button (Notice the diagonal sub mark pop up) and add up some sub buttons.
Sent from my iPhone
Ahh, darn. Ok, thanks!
It's on my WIP high priority. Next update will have a full widget support.
Featherence v0.5.12 (18-Sep-16)
- Added customized image on startup.
Can work pretty good with video intro follow up.
- Added full widget support.
You may now add widget to any button with full actions support, icons, fanart etc..
Moving widgets around is very user friendly.
- Added internal widget support for movies, tvshows and weather.
You may now decide which button carry those build-in widgets and see which one is with a special mark (When in the skin design window).
- Added shapes and effects support for widgets.
- Added widget category in skin design window.
- Minor bugs fix.
- Minor performance boost.
- Update Featherence Classico auto-update feature.
- Update Music in Slideshow and Screensaver feature.
- Update pass protection feature.
You won't be able to enter any locked button at all without the right password and widgets will remain hidden.
- Update titles design in DVD Case mode for views: Wall, Poster and Line.
- Update video intro feature.
(2016-09-18, 18:16)finalmakerr Wrote: [ -> ]------------------------
- Minor bugs fix.
Awesome, thank you!!
Any plans for Krypton support?
Yes will be about 1 month after it's release.
Btw: Next update is going to be huge with a lots of good things so stay tuned Smile
Sent from my iPhone
Featherence v0.6.0 (23-Sep-16)
- Added IMDB rating to Side List view (Can be toggle on/off).
- Added pass-lock category in skin design window.
- Added password lock setting for skin design window.
You better remember your password now if this option is enable
- Added option to always show video/audio settings in the Video OSD buttons.
- Added option to toggle skin changelog on/off and tweak it to show for Today, two days or a one week.
Default is now 2 days - The day of the update and the next day.
- Added option to change mouse cursor icon and color.
- Added option to have a bit larger Top Information bar.
- Added option to reschedule lock up after x minutes.
- Added option to toggle button's labels postion in/out of the button.
- Added option to toggle skin version on/off in home window.
- Added option to have a 3 smaller icons at the end of your Vertical/Horizontal layout (Favourite, Settings, Power).
- Added option to set RSS visibility across the entire skin.
- Added option to set RSS delay time.
- Added RSS category in skin design window.
- Added RSS support.
- Added two new buttons layout views: Horizontal 3 (9) and Panel 3 (18).
- Added two new widget layout: Horizontal 7/9
- Default favourite button ID has been changed.
If you have two buttons you may disable one.
- Minor bug fix with Arial font when switching skins.
- Major bug fix with Transperancy Colour Fanart Background feature.
- Major update of lock/unlock design and position.
- Minor bugs fix.
- Minor update of big icons feature.
- Minor update of DialogFavourites window.
- Major update of Touch Screen feature.
Useable in every dialog window, design tweaked, can change the icon etc..
- Minor update of Vertical layout.
Nice job man! Thanks!
