2019-01-04, 15:08
2019-01-04, 17:13
(2019-01-04, 15:08)C.O.D. Wrote: [ -> ]What's that version 1.0 in the kodi repo?Version 1.0.
2019-01-04, 17:31
2019-01-04, 19:12
2019-01-05, 09:50
2019-01-05, 17:25
First one is a skin issue so best report it there.
2019-01-08, 02:10
This nice addon suddenly stopped working on the latest nightly Leia build for Android. Does this sound familiar to anyone or should UpNext still work?
2019-01-08, 05:10
Thanks im85288 for this new version of the addon. I was a fan of the old UI in the bottom right of the screen, so went ahead and made different versions of the fancy skin xmls. They're on my github if anyone else want to them. The color of the UI also changes according to whatever color is selected in Estuary.
https://github.com/falling-fading/legacy...i18-plugin
What I ended up with:
2019-01-08, 20:10
Hi im85288, would it be possible to implement "endtime" of the next episode? Thanks
2019-01-09, 18:11
You absolute beast !
This is exactly what I wanted, thanks a million !
2019-01-10, 11:25
Thanks for the addon.
I can't get it working. Always getting tvshowid -1. Any help?
html:UP NEXT Api -> log : Got details of now playing media "{\"id\":1,\"jsonrpc\":\"2.0\",\"result\":{\"item\":{\"episode\":2,\"genre\":[\"Crimen, Drama\"],\"label\":\"Cap\u00edtulo 2\",\"playcount\":0,\"plotoutline\":\"\",\"season\":1,\"showtitle\":\"La casa de papel\",\"tvshowid\":-1,\"type\":\"episode\"}}}"
UP NEXT PlayItem -> log : Fetched missing tvshowid "-1"
2019-01-10, 17:05
2019-01-12, 03:10
(2019-01-10, 17:05)mardukL Wrote: [ -> ]Hi, first thanks to bring that to a new level.The show that is playing doesn't look like Game of Thrones. What's the catch, why are they different shows?
I miss 2 info properties ("mpaa", "videoresolution")
, i could adjust it to my skin, and i rellay missed those 2 :-)
2019-01-12, 03:41
(2019-01-05, 17:25)Hitcher Wrote: [ -> ]First one is a skin issue so best report it there.OK
what about the pink, will there be an option to change the colour?
2019-01-12, 10:51
(2019-01-12, 03:10)adun79 Wrote: [ -> ]That's the developer mode where it shows the dialog you're coding as soon as you play something. It's so you don't have to seek to the end each time.(2019-01-10, 17:05)mardukL Wrote: [ -> ]Hi, first thanks to bring that to a new level.The show that is playing doesn't look like Game of Thrones. What's the catch, why are they different shows?
