RaGeS Wrote:Hi,
I try to compile XBMC pvr branch on pandaboard.
I have this error when make:
CPP xbmc/cores/DllLoader/exports/emu_kernel32.o
In file included from /usr/include/GLES2/gl2.h:6:0,
from /home/emanuele/xbmc/xbmc/system.h:271,
from emu_kernel32.h:26,
from emu_kernel32.cpp:22:
/usr/include/GLES2/gl2platform.h:20:29: fatal error: KHR/khrplatform.h: No such file or directory
compilation terminated.
make[1]: *** [emu_kernel32.o] Error 1
make: *** [xbmc/cores/DllLoader/exports/exports.a] Error 2
help me plz ...
Emanuele
looks like KHR dev headers/libs are not installed which is odd as gles is installed and it's referencing it.
RaGeS Wrote:.. how i can install it?
don't know, I don't dev on pandaboard.
I install libegl1-mesa-dev , but remove libegl1-sgx-dev.
Now I'm in compiling.
Emanuele
Any fourther steps in aplying hardware acceleration with XBMC on the pandaboard yet? I'm running Ubuntu 11.10 now and there is still no way to get 1080p movies playing with more than 1/5 fps
Even with the rep (
https://launchpad.net/~tiomap-dev/+archi...er=oneiric)..
christian667 Wrote:Any fourther steps in aplying hardware acceleration with XBMC on the pandaboard yet?
no, but patches are welcome.
I have problems compile the development xbmc with pandaboard and the latest ubuntu 11.10 installed. At this time i got
CPP xbmc/cores/dvdplayer/DVDClock.o
DVDClock.cpp: In member function ‘int CDVDClock::UpdateFramerate(double, double*)’:
DVDClock.cpp:212:1: internal compiler error: in fp_immediate_constant, at config/arm/arm.c:12877
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.6/README.Bugs> for instructions.
Preprocessed source stored into /tmp/ccgMwO4I.out file, please attach this to your bugreport.
make[1]: *** [DVDClock.o] Error 1
make: *** [xbmc/cores/dvdplayer/DVDPlayer.a] Error 2
Any one who knows to solve this?
V=1 make, to see the full compiler output
I have the same problem of naj666.
davilla Wrote:V=1 make, to see the full compiler output
Ok, here it is.
make[1]: Entering directory `/home/jan/xbmc/xbmc/cores/dvdplayer'
/usr/bin/ccache g++ -MF DVDClock.d -MD -c -D__STDC_FORMAT_MACROS -fPIC -DPIC -D_REENTRANT -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -g -D_DEBUG -Wall -O2 -mfloat-abi=softfp -mno-apcs-stack-check -Wa,-march=armv7a -mcpu=cortex-a8 -DTARGET_POSIX -DTARGET_LINUX -D_LINUX -D_ARMEL -D_FILE_DEFINED -D__STDC_CONSTANT_MACROS -DBIN_INSTALL_PATH="\"/usr/local/lib/xbmc\"" -DINSTALL_PATH="\"/usr/local/share/xbmc\"" -DHAS_SDL_JOYSTICK -D'GIT_REV="20111023-89082a9"' -DHAVE_CONFIG_H -DDBUS_API_SUBJECT_TO_CHANGE -D_GNU_SOURCE=1 -D_REENTRANT -I/home/jan/xbmc -I/usr/include/SDL -I/usr/include/alsa -I/usr/include/dbus-1.0 -I/usr/include/freetype2 -I/usr/include/fribidi -I/usr/include/hal -I/usr/include/libpng12 -I/usr/include/mysql -I/usr/lib/arm-linux-gnueabi/dbus-1.0/include -I/home/jan/xbmc/lib -I/home/jan/xbmc/xbmc -I/home/jan/xbmc/lib/ffmpeg -I/home/jan/xbmc/xbmc/linux -I/home/jan/xbmc/xbmc/cores/dvdplayer DVDClock.cpp -o DVDClock.o \
&& cp DVDClock.d DVDClock.P && sed -e 's/#.*//' -e 's/^[^:]*: *//' -e 's/ *\\$//' -e '/^$/ d' -e 's/$/ :/' < DVDClock.d >> DVDClock.P && rm -f DVDClock.d || ( rm -f DVDClock.P DVDClock.o && exit 1 )
Preprocessed source stored into /tmp/ccUR5MqX.out file, please attach this to your bugreport.
make[1]: Leaving directory `/home/jan/xbmc/xbmc/cores/dvdplayer'
I have not had a got yet compiling XBMC on ubuntu 11.10 for the Pandaboard but I do know that TI has not released support for multimedia acceleration, until they do playback will be pretty rubbish.
naj666 Wrote:Ok, here it is.
MathUtils.h change the __arm__ code for round_int to match the __powerpc__/__ppc__ code.
i = floor(x + round_to_nearest);
also, xbmc's configure was changed with respect to neon, needs --enable-neon passed in to turn on neon.
