2022-04-18, 04:08
(2022-04-18, 04:04)darkkmage Wrote: [ -> ]Ok, I tried creating it from scratch in Notepad, that fixed it. My bad!Right. All fixed then.
(2022-04-02, 19:44)grove Wrote: [ -> ]A simple question, that I don't see mentioned anywhere (if it is, please excuse me for overlooking that):
Can you have (sub-)directories in the Extras folder?
As an example of where this would be usable: The edition of Titanic I have, have 29 deleted scenes, and some other extras, I would like to have a directory for those, so they don't clutter up the list of extras.
(2022-05-03, 00:39)grove Wrote: [ -> ]I can't see that anyone ever answered that, maybe I should just try.Yep, I think this would have been the fastest solution. Just try.
(2022-08-05, 08:59)Chalklands Wrote: [ -> ]I select extras but all I see is basically a blank screen with only one line showing '..'Usually means that the Extras folder cannot be found. Your log is of no help as you did not enable Debug Mode.
(2022-08-05, 09:42)Karellen Wrote: [ -> ]Thanks for your response. I'm doing some testing on Kodi installed on a firestick. It does seem to be emby that can't find the extras folder.(2022-08-05, 08:59)Chalklands Wrote: [ -> ]I select extras but all I see is basically a blank screen with only one line showing '..'Usually means that the Extras folder cannot be found. Your log is of no help as you did not enable Debug Mode.
Have you changed the default naming of the folder in the addon settings?
Is your folder named exactly like it is shown in the addon settings?
Where have you placed the Extras folder? Provide a screenshot so we can see.
Also, don't forget to add the advancedsettings.xml code, otherwise you will end up scanning your Extras into the library... https://kodi.wiki/view/Add-on:Extras
But you mention Emby and IIRC, Emby does something weird with accessing media. I think it bypasses the Kodi library database so I am guessing it cannot find your Extras folder?
Can you test by accessing the movies directly through Kodi and see if the Extras folder becomes available.
(2022-08-05, 12:42)Chalklands Wrote: [ -> ]Would this be because in my file structure I have my trailers saved in a 'trailer' sub directory in the individual movie folder?Kodi does not use a Trailers folder. See here for using trailers... https://kodi.wiki/view/Trailers
(2022-08-05, 12:42)Chalklands Wrote: [ -> ]nfo files are showing in extras.Extras don't need nfo files. Extras is just a simple browser that displays items in the extas folder. Hmm, I thought the display was limited to video files, but maybe I am mis-remembering and it displays whatever is in the folder.
(2022-08-05, 17:29)Chalklands Wrote: [ -> ]How does Kodi handle different versions of a movie, eg Theatrical and Directors cut?There is a PR that add a Movie Version feature... https://github.com/xbmc/xbmc/pull/21469
