(2021-08-17, 22:21)UlfSchmidt Wrote: [ -> ] (2021-08-17, 21:47)Buschel Wrote: [ -> ]
Wow, thanks for this quick update!
I hope you confirm that this corner size looks so much better?
At least I like it! Appreciate your work and open mindset
Well, the "rounded corners" feature is all about personal preference. My stomach feeling was that the radius was too large in its initial state, now I made it even smaller than I was thinking of. But overall the users and not only me (
) shall be comfortable using this, and I am fine with the look & feel of the latest beta version. Any many thanks again for your always appreciated feedback and testing time you put into the Remote App.
On the topic of the App layout for different screen sizes: It is obvious that the screen layout was mainly influenced by the iPhones (with smaller screens) several years back. You can see this especially from the way how the remote and the NowPlaying screens are designed. There is even some special code in the remote screen implementation to handle the very small screen of e.g. iPhone 4S which is still supported. Except the fullscreen solutions even the iPad follows basically the same screen layout -- just with in general wider screens.
The last remote screen changes already leave this limitation and use more of the available vertical space, but still keeping the special treatment for smaller devices. The additional vertical space is used for a toolbar and the volume slider. For larger devices you now can even move the remote buttons to the upper or lower part of the screen which should make it easier to use it 1-handed. In my opinion having the new toolbar and the volume slider on the remote screen really makes a difference as you now can reach all functions on the same screen which were (and for the small screen devices still are) spread over two screens.
For iPads I feel the remote screen looks weird -- too bloated, especially on the large screens. Maybe I will try to bring this into a popover style with a smaller size.
The NowPlaying screen layout is also limited by the size of the small screens of the older iPhone models. There is a lot of vertical free space left on newer iPhone models. This could be used for additional buttons (repeat, shuffle) or for more detail info like audio or video codecs, bitrate, number of channels, sample rate or bits per samples. These could possibly be removed from the detail view overlay. Other control point apps -- especially for audio -- have similar information / buttons on the NowPlaying screen. We just need to take care the screen does not become overloaded with information, and that we have several playback items with different needs (video, audio, recordings, radio, pictures, ...).
For iPads this is even more difficult. The screens -- depending on the orientation -- can even have less height but more width. Also I personally think that having the basic playback controls (play, pause, skip, ...) in a very small toolbar on the left, and not directly related to the NowPlaying screen, is not a good solution. This is becoming more obvious when looking at the devices with larger screens where the controls are really small and "lost" on the screen. I did not yet think through the options, but I feel the App layout on iPad can take some re-design.
