2022-11-11, 16:13
@Buschel
To change the shape of the keyboard you put your thumbs on the S and the K key and “pull” the keyboard apart by dragging your thumbs to the edge of each side of the screen. Also, you can long press the dismiss keyboard button in the lower right corner of the keyboard to do this.
Note I discovered there’s actually a third keyboard style. A one handed iPhone style one you can drag anywhere on the screen. To trigger that one “scrunch” the keyboard with your thumbs doing the opposite of pulling it apart.
Seeing that there’s three keyboards I decided to test a few things and found some wonky behavior when the remote control is displayed. Full width keyboard is handled properly, the remote shifts up maintaining full visibility.
When split keyboard is already enabled and the remote is brought up, everything is fine but if you switch from full width to split key the remote incorrectly shifts down partially hiding it.
Of course now I can’t reproduce the bug I encountered last night with the flickering keyboard but I also can’t figure out how I had the tv pane in the middle of the screen in portrait view. Must be linked. Fortunately I took a video of this behavior to prove I did encounter the bug. It looks like my keyboard split view was actually docked to the bottom of the screen but I can’t figure out how to do that again.
I discovered another search related bug that again has to do with that footer. If you are in full screen view and you tap in search and dismiss the keyboard the exit full screen button is gone. To bring it back you must tap cancel on the search, even when blank.
It also looks like keyboard dismissal when scrolling isn’t enabled on iPad? I just checked with iPhone and I know that was something I asked you to implement there. What are your thoughts on doing the same for iPad?
Finally, an amusing animation. If you have the search bar visible on TV shows, then go fullscreen then exit full screen you can watch the search bar grow to fill the available space. Maybe this was intended?
