(2021-02-08, 13:20)kambala Wrote: [ -> ]The "support" for bigger devices (using xr) seems to be just to fill the screen and put the remote on top. For a big device, vertically centered or at bottom would be better, due to reachability for top buttons.
Good point. In one of the first pages in this thread it was also suggested to use the "free space" for gestures. But this might be getting a bit complicated.
1.6.1 Build 2051:
- Fix ATS blocking connection to FQDN (
forum post)
- Fix
#162 (Screenshots can't be fired since 1.6)
- Fix
#165 (Weird sorting of artists)
- Fixes
#159 (First audio track is hidden behind topbar of the playlist)
- Do not show JSON-RPC error if no PVR Add-on is installed on Kodi server (
forum post)
- Avoid jumping sort/grid button when selecting a gerne in from the music library
- NowPlaying Screen: Bigger fonts for newer iPads with high resolution
- NowPlaying Screen: Consistent layout when changing between Landscape/Portrait
1.6.1 Build 2054:
- Fix crashes when processing filtered list with empty search string (fixes several crashes reported in
#161)
1.6.1 Build 2060:
- Fix potential crashes in DetailViewController (fixes several crashes reported in issue
#161)
- Fix potential crashes when loosing authentication after connection established (fixes several crashes reported in issue
#161)
- Fix layout issues in NowPlaying and Info view when "Show jewel cases" was enabled in App setting (issue
#171)
1.6.1 Build 2063:
- Fix non-working longpress on filtered list for iPads (issue
#170)
FYI going to submit 2063 to App Store review on weekend
(2021-02-19, 20:57)kambala Wrote: [ -> ]FYI going to submit 2063 to App Store review on weekend
Sounds good. Any reports arrived so far, especially any crash logs?
(2021-02-19, 22:43)Buschel Wrote: [ -> ] (2021-02-19, 20:57)kambala Wrote: [ -> ]FYI going to submit 2063 to App Store review on weekend
there're a couple of others, but pretty rare so far, we can take care of them later.
(2021-02-19, 22:44)kambala Wrote: [ -> ]there're a couple of others, but pretty rare so far, we can take care of them later.
Sure, if there´s anything to share just put it into a github issue.
I can report that this version runs very smoothly, I tried almost everything possible, but no crashes whatsoever. Very good work! (Tested on iPad Air 3rd Gen)
1.6.1 Build 2070:
- Fix overlay position for DetailView in NowPlaying screen (related to issue
#171)
(2021-02-21, 10:10)kambala Wrote: [ -> ] (2021-02-20, 13:49)Buschel Wrote: [ -> ]1.6.1 Build 2070
this build is on the App Store now.
Great, so the late hotfix made it. I wasn´t sure when I saw the update on the AppStore.
(2021-02-21, 10:19)Buschel Wrote: [ -> ] (2021-02-21, 10:10)kambala Wrote: [ -> ] (2021-02-20, 13:49)Buschel Wrote: [ -> ]1.6.1 Build 2070
arrived today at midnight UTC+3
