Full Version: Yatse 2 : Open Source Media Center Remote Control App for Touch Screen
Tolriq Wrote:You should have a log in the directory from where you launch the install please upload it Smile
But if you can start the installer and select x86 build that means that the server is up and running. Maybe you use a proxy or anti virus that block some files during installation.
[18:48:43.1134] Setup : Download : Error (The remote server returned an error: (404) Not Found.) : /Download/x64/Versions
[18:48:43.1144] Setup : Error loading repository - x64
[18:49:00.4034] Setup : Install : Build 112 to : D:\Programs\Yatse2
[18:50:40.6381] ThreadDl7 : Error (The operation has timed out) - https://yatse.leetzone.org/repository/x8...DC6A5C.dat
I turned off Microsoft Security Essentials.
Well strange, it means you have a timeout during the downloading of the files.
And this file is really small. Can you dl it from internet explorer without problems ?
Is it always the same file ?
im able to download the installer with no problem. but when i click the installer to perform the install i get the error
Yes but can you download the file :
from internet explorer ? and is this always this file in the log ?
Tolriq Wrote:Yes but can you download the file :
I copied your link above into internet explorer and i received this message.
Not Found
The requested document was not found on this server.
Web Server at yatse.leetzone.org
Well you must use the full link :
PHP Code:
https://yatse.leetzone.org/repository/x86/112/Files/533480CE5FD5D05EFF477626E6DC6A5C.dat
Without the ... that the forum auto add Smile
i finally got it to download Thanks!!!
alright its installed and it works. but i am unable to use the remote feature nor did it load all of my posters for my movies and tv shows.
Can you please upload the log file ?
For the remote feature i suppose you don't have activated the event server, please check the wiki for proper XBMC configuration.
http://yatse.leetzone.org/redmine/projec...XbmcConfig
For movies and tv shows Yatse use the library mode of XBMC have you scrapped all your data and use library mode ?
Tolriq Wrote:Can you please upload the log file ?
I am able to control XBMC by using the videos or movies selection on Yatse to start the movies or shows. But when I'm trying to use the remote feature ie. the left and right arrows nothing happens. I am using library in XBMC and all of my media and poster along with fanart are loaded into XBMC. Where do I find the log?
The log is in the Log dir in Yatse's one Smile
And please double check the XBMC configuration in the wiki, you need to activate the web server and the event server, 2 more check boxes to check Smile
Ok i have the remote working but the poster are not showing up in Yaste's yet.
Without log file i can"t tell anything Smile
18:01:40.0885] Yatse2 : Starting build : 112
[18:01:40.5265] Yatse2 : End load config
[18:01:40.5295] Yatse2-Plugs : Loading : D:\Programs\Yatse2\Plugins\Remote.XBMC.Camelot.dll
[18:01:40.5655] Yatse2-Plugs : Plugin : XBMC - Camelot (Version : 112)
[18:01:40.5675] Yatse2-Plugs : Loading : D:\Programs\Yatse2\Plugins\Remote.XBMC.Dharma.dll
[18:01:40.6225] Yatse2-Plugs : Plugin : XBMC - Dharma (Version : 102)
[18:01:40.6245] Yatse2-Plugs : Plugin : XBMC - Dharma (Version : 102) reports incompatibility unloading
[18:01:40.6255] Yatse2-Plugs : Loading : D:\Programs\Yatse2\Plugins\Remote.XBMC.DharmaHttp.dll
[18:01:40.6595] Yatse2-Plugs : Plugin : XBMC - Dharma H (Version : 112)
[18:01:41.2066] Yatse2 : Load dictionaries - Skin : Default, Lang : English
[18:01:42.0366] Yatse2DB : Opening database : D:\Programs\Yatse2\Yatse2.db
[18:01:42.1756] Yatse2DB : Query : SELECT MAX(Version) FROM `Version`;
[18:01:42.1876] Yatse2DB : Query : SELECT * FROM `Remotes` WHERE Id = @idRemote;
[18:01:42.1896] Yatse2DB : Param : @idRemote=1
[18:01:42.1956] Yatse2 : Init remote : 1 - XBMC Iraq
[18:01:42.1996] Yatse2Api-XDT : Configure : 100.100.0.110:8080
[18:01:42.2016] Yatse2 : Init Timer
[18:01:42.2046] Yatse2DB : Query : SELECT * FROM `Remotes`;
[18:01:42.2126] Yatse2 : Refresh weather
[18:01:42.3416] Yatse2 : Dispay settings changed
[18:01:42.3436] Yatse2 : End init
[18:01:44.2137] Yatse2 : Remote connected : 1 - XBMC Iraq
[18:01:44.2167] Yatse2Api-XDT : COMMAND : GetSystemInfo - 120
[18:01:44.2297] Yatse2Api-XDT : COMMAND : GetSystemInfo - 146
[18:01:44.2637] Yatse2Api-XDT : Cancelling downloads
[18:01:44.2687] Yatse2 : Starting Library Refresh
[18:01:44.2847] Yatse2 : Start Refresh : Movies
[18:01:44.2967] Yatse2Api-XDT : DBCOMMAND : video - SELECT c00,c01,c03,c04,c05,c07,C09,c11,c12,c14,c15,c16,c18,idFile,idMovie,strFileName,strPath,playCount FROM movieview
[18:01:44.3307] Yatse2 : Remote Movies : 28
[18:01:44.3527] Yatse2 : End Refresh : Movies
[18:01:44.3587] Yatse2 : Start Refresh : TvShows
[18:01:44.3797] Yatse2Api-XDT : DBCOMMAND : video - SELECT tvshow.idShow,tvshow.c00,tvshow.c01,tvshow.c04,tvshow.c05,tvshow.c08,tvshow.c12,tvshow.c13,tvshow.c14,path.strPath as strPath,counts.totalcount as totalCount FROM tvshow join tvshowlinkpath on tvshow.idShow=tvshowlinkpath.idShow join path on path.idpath=tvshowlinkpath.idPath left outer join ( select tvshow.idShow as idShow,count(1) as totalcount,count(files.playCount) as watchedcount from tvshow join tvshowlinkepisode on tvshow.idShow = tvshowlinkepisode.idShow join episode on episode.idEpisode = tvshowlinkepisode.idEpisode join files on files.idFile = episode.idFile group by tvshow.idShow) counts on tvshow.idShow = counts.idShow
[18:01:44.4038] Yatse2 : Remote TvShows : 7
[18:01:44.4148] Yatse2 : End Refresh : TvShows
[18:01:44.4178] Yatse2 : Start Refresh : TvSeasons
[18:01:44.4298] Yatse2Api-XDT : DBCOMMAND : video - SELECT idShow, COUNT(idShow), c12, strPath FROM episodeview GROUP BY idShow,c12
[18:01:44.4558] Yatse2 : Remote TvSeasons : 15
[18:01:44.4628] Yatse2 : End Refresh : TvSeasons
[18:01:44.4678] Yatse2 : Start Refresh : TvEpisodes
[18:01:44.4798] Yatse2Api-XDT : DBCOMMAND : video - SELECT idEpisode,c00,c01,c03,c05,c10,c12,c13,idFile,strFileName,strPath,playCount,strTitle,strStudio,idShow,mpaa FROM episodeview
[18:01:44.5348] Yatse2 : Remote TvEpisodes : 214
[18:01:44.6208] Yatse2 : End Refresh : TvEpisodes
[18:01:44.6318] Yatse2 : Start Refresh : MusicGenres
[18:01:44.6468] Yatse2Api-XDT : DBCOMMAND : music - SELECT idGenre,strGenre,COUNT(DISTINCT strAlbum) AS albumCount FROM albumview GROUP BY idGenre
[18:01:44.6668] Yatse2 : Remote MusicGenres : 0
[18:01:44.6718] Yatse2 : End Refresh : MusicGenres
[18:01:44.6968] Yatse2 : Start Refresh : MusicAlbums
[18:01:44.7138] Yatse2Api-XDT : DBCOMMAND : music - SELECT idAlbum,strAlbum,idGenre,idArtist,strArtist,strGenre,iYear,strThumb FROM albumview GROUP BY strAlbum
[18:01:44.7488] Yatse2 : Remote MusicAlbums : 0
[18:01:44.7538] Yatse2 : End Refresh : MusicAlbums
[18:01:44.7588] Yatse2 : Start Refresh : MusicSongs
[18:01:44.7798] Yatse2Api-XDT : DBCOMMAND : music - SELECT idSong,strTitle,iTrack,iDuration,iYear,strFileName,idAlbum,strAlbum,strPath,idArtist,strArtist,idGenre,strGenre,strThumb FROM songview
[18:01:44.8008] Yatse2 : Remote MusicSongs : 0
[18:01:44.8058] Yatse2 : End Refresh : MusicSongs
[18:01:44.8098] Yatse2 : Start Refresh : MusicArtists
[18:01:44.8298] Yatse2Api-XDT : DBCOMMAND : music - SELECT idArtist,strArtist FROM artist
[18:01:44.8498] Yatse2 : Remote MusicArtists : 0
[18:01:44.8548] Yatse2 : End Refresh : MusicArtists
[18:01:44.8778] Yatse2 : Start Refresh : Thumbs/Fanarts
[18:01:44.8798] Yatse2Api-XDT : Cancelling downloads
[18:01:44.9418] Yatse2 : Refresh : Thumbs/Fanarts : 498 files
[18:01:44.9508] Yatse2Api-XDT : ERROR - DOWNLOAD : http://100.100.0.110:8080/vfs/special://...a34ff0.tbn The remote server returned an error: (401) Unauthorized.
[18:01:44.9528] Yatse2 : End Refresh : Thumbs/Fanarts
[18:01:44.9548] Yatse2 : End Library Refresh
[18:01:44.9568] Yatse2Api-XDT : ERROR - DOWNLOAD : http://100.100.0.110:8080/vfs/special://...a34ff0.tbn The remote server returned an error: (401) Unauthorized.
[18:01:44.9608] Yatse2Api-XDT : ERROR - DOWNLOAD : http://100.100.0.110:8080/vfs/special://...ec1cbd.tbn The remote server returned an error: (401) Unauthorized.
[18:01:44.9658] Yatse2Api-XDT : ERROR - DOWNLOAD : http://100.100.0.110:8080/vfs/special://...ec1cbd.tbn The remote server returned an error: (401) Unauthorized.
[18:01:44.9698] Yatse2Api-XDT : ERROR - DOWNLOAD : http://100.100.0.110:8080/vfs/special://...f7142f.tbn The remote server returned an error: (401) Unauthorized.
[18:01:44.9738] Yatse2Api-XDT : ERROR - DOWNLOAD : http://100.100.0.110:8080/vfs/special://...f7142f.tbn The remote server returned an error: (401) Unauthorized.
[18:01:44.9808] Yatse2Api-XDT : ERROR - DOWNLOAD : http://100.100.0.110:8080/vfs/special://...170396.tbn The remote server returned an error: (401) Unauthorized.
[18:01:44.9978] Yatse2Api-XDT : ERROR - DOWNLOAD : http://100.100.0.110:8080/vfs/special://...170396.tbn The remote server returned an error: (401) Unauthorized.
[18:01:45.0148] Yatse2Api-XDT : ERROR - DOWNLOAD : http://100.100.0.110:8080/vfs/special://...1c73d4.tbn The remote server returned an error: (401) Unauthorized.
[18:01:45.0168] Yatse2 : Checking for updates. Current version : 2.0.112.0
[18:01:45.0198] Yatse2Api-XDT : ERROR - DOWNLOAD : http://100.100.0.110:8080/vfs/special://...1c73d4.tbn The remote server returned an error: (401) Unauthorized.
[18:01:45.0238] Yatse2Api-XDT : ERROR - DOWNLOAD : http://100.100.0.110:8080/vfs/special://...ea2e93.tbn The remote server returned an error: (401) Unauthorized.
[18:01:57.0495] Setup : Download : Error (The remote name could not be resolved: 'yatse.leetzone.org') : /Download/x86/Versions
[18:01:57.0515] Setup : Error loading repository - x86
[18:02:02.2268] Setup : Download : /Download/Translations
[18:02:02.2488] Yatse2 : Build list empty !
[18:02:02.2528] Setup : Cleanup : Temporary deleted
[18:02:02.2548] Yatse2 : Home Page : grd_Home
[18:02:03.2968] Yatse2 : Image cache filling completed
[18:02:03.2998] Yatse2DB : Query : UPDATE `Remotes` SET Name = ? , Api = ?, ProcessName = ?, IP = ?, Port = ?, MacAddress = ?, Login = ?, Password = ?, Version = ?, Os = ?, Additional = ?, CacheFilled = ? WHERE Id = @Id;
[18:02:03.3018] Yatse2DB : Param : a1=XBMC Iraq , a2=XBMC - Dharma H , a3=XBMC , a4=100.100.0.110 , a5=8080 , a6=00:1c:7e:8d:d4:b7 , a7=xbmc , a8=xbmc , a9=PRE-10.5 r32466 , a10=Windows , a12=Master user , a13=1 , @Id=1
[18:02:03.3098] Yatse2 : Home Page : grd_Home
[18:02:06.3540] Yatse2DB : Query : SELECT * FROM `Movies` WHERE IdRemote = @idRemote ORDER BY Title;
[18:02:06.3570] Yatse2DB : Param : @idRemote=1
[18:02:06.4370] Yatse2 : Show Grid : grd_Movies
[18:02:13.7964] Yatse2 : Show Grid : grd_Home
[18:02:16.5396] Yatse2 : Closing
Well every things works ok on Yatse side.
It seems that it's XBMC that send an error 401. But i doubt, so you may be using a proxy that don't like the images url because of the :
You should check your proxy configuration.
