This is the easiest way to install the CrystalHD driver onto your AppleTV!
To make this easy install available log into your AppleTV
and enter:
defaults write com.teamxbmc.xbmclauncher XBMCAdditionalDownloadPlistURLs -array-add http://crystalhd.sartori.at/files/crystalhd.plist
This will add a new download source to your "Downloads" section in Launcher.
Current revision: r174 (Build Date: 20101027)
If you have Problems with a new build, you can enable the last working release CrystalHD r156 (20100826):
defaults write com.teamxbmc.xbmclauncher XBMCAdditionalDownloadPlistURLs -array-add http://crystalhd.sartori.at/devel/crystalhd.plist
Thanks for the update, andy204!
Once this is tested by a few users, we'll integrate it into Launcher.
Does it push also the firmware in the ATV?
sure,
it installs everything you need for working crystalhd environment.
-andy
Wow this is awesome. I already have it installed on mine. But it cant possibly get any easier than this. Next thing you know one of you guys is gonna come over the house and install it.
andy204 Wrote:Code:
Great. But what is the reverse command? I managed to put it in two times
mauzzz Wrote:Great. But what is the reverse command? I managed to put it in two times
read the manual
i assume it is
defaults delete com.teamxbmc.xbmclauncher XBMCAdditionalDownloadPlistURLs -array-add http://crystalhd.sartori.at/files/crystalhd.plist
andy204 Wrote:Code:
Actually it is
The nightlies and crystalhd entries are all removed then. After that you can add again. Thanks
in the next 2 -3 hours there the download server will be under maintenance.
server switch is upgraded.
-andy
Is there a known build of XBMC that does not have the wierdness of slowing and speeding up video which seems to be relating to ins and outs of the Crystal Driver?
Its nice to have it installed but I can't really use it.
garyi Wrote:Is there a known build of XBMC that does not have the wierdness of slowing and speeding up video which seems to be relating to ins and outs of the Crystal Driver?
this appears with some hd content, with sd movies i have no problem at all. i have not found any build that is running 100%. i am sure, that the developers are working on that. lets be happy, that we have a working hardware+driver. the rest will come soon!
-andy
Hi Andy,
I have tested it and its working like a charm
, Thanks!
one comment, since the ATV needs a reboot after the installation, might be a good idea to have the install script do it.
Good job on creating this.
Zeljko
Amet Wrote:Hi Andy,
I have tested it and its working like a charm , Thanks!
Zeljko
why need a reboot? i havent tested that, but i cant imagine why. i am loading the kext in the install script. so it should run without reboot.
andy204 Wrote:why need a reboot? i havent tested that, but i cant imagine why. i am loading the kext in the install script. so it should run without reboot.
sorry, my mistake, I missed the
echo $PW | sudo -S kextload /System/Library/Extensions/BroadcomCrystalHD.kext > /dev/null 2>&1
Ignore my comment.
Zeljko
Looks like the server is down. Anyone else successful grabbing this file?
