Units have been shipped today, more to ship tomorrow, with all back orders expected to be cleared early next week!
All pre-orders (including orders made before the 3rd) will get the pre-order gift promised and we will announce it on our blog
If I were to order today can I expect a delay or is it better to wait for supplies to catch up?
hey martin, is there a keymap.xml file available for download for dharma and/or eden?
How long would it be for a new order to get processed?
YAY! I got a notification that my order is shipping today! Thanks!
Not sure where I should post this. I tried the OpenElec ION build from 8/13 to get ready for my CEC adapter. It installed just as expected but I get an xbmc reboot anytime I click to download any program addons.
If this isn't a known issue/reproducable I can reinstall it and get the debug log, Sorry I didn't grab it the first time cause I needed to get a working system quick (before my roommates complained).
Thanks for all your work!
A few people have reported this, we will look into it, right now we are just prepping code for the CEC adapter and will release new builds hopefully tonight or tomorrow.
Hopefully these new builds fix it
Malard Wrote:A few people have reported this, we will look into it, right now we are just prepping code for the CEC adapter and will release new builds hopefully tonight or tomorrow.
If you can't reproduce it just message me and I can get you a log
Malard, so do we just grab the copy from github or does the nightly XBMC builds package up the latest copy as well? Is there a way to get XBMC to use a different keymap file rather than renaming so that one who constantly updates to latest nightly doesn't have to also rename the file each time it's updated?
BTW: did order #444 get shipped ?
thanks
Malard Wrote:if you order today, it will ship on Monday or Tuesday next week
Keymap, look here: https://github.com/xbmc/xbmc/blob/master...xboard.xml
azaze1 Wrote:Malard, so do we just grab the copy from github or does the nightly XBMC builds package up the latest copy as well? Is there a way to get XBMC to use a different keymap file rather than renaming so that one who constantly updates to latest nightly doesn't have to also rename the file each time it's updated?
thanks
There is actually some logic in the mainline xbmc to switch to the nyxboard config, except there is one file which needs updating, you can do this manually by editing the deviceidmappings.xml in system with the correct VID and PID for the nyxboard (or any remote for that matter) and it will switch to the relevant keymap file.
Malard Wrote:There is actually some logic in the mainline xbmc to switch to the nyxboard config, except there is one file which needs updating, you can do this manually by editing the deviceidmappings.xml in system with the correct VID and PID for the nyxboard (or any remote for that matter) and it will switch to the relevant keymap file.
is this file not correct:
<devicemappings>
<device id="HID#VID_1915&PID_003B&MI_00#7&314e95d&0&0000#" keymap="Motorola Nyxboard Hybrid" />
</devicemappings>
what are the correct values then ?
(I should receive my remote soon and I want to be ready :p)
hey, thought i would post this over here as well....
hi,
received my remote today
works fine on my windows box, plug and play.... but not on my ubuntu box, Ubuntu 11.04 (GNU/Linux 2.6.38-11-generic x86_64)(my media server!!!)
plug it in, wait a minute and when i press the buttons i get a double flash red led which means out of range? but i'm stood 2ft away from it...
anyways took a look at lsusb and see:
iSerial 3 ?
the only thing that looks wrong
not really how else to troubleshoot... but ideas welcome !
server@server:~$ sudo lsusb -v
Bus 007 Device 007: ID 22b8:003b Motorola PCS
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 32
idVendor 0x22b8 Motorola PCS
idProduct 0x003b
bcdDevice 1.00
iManufacturer 1 Motorola
iProduct 2 Motorola NYXboard, 2.4GHz device
iSerial 3 ??????????
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 116
bNumInterfaces 4
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 1 Keyboard
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.11
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 76
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x000a 1x 10 bytes
bInterval 10
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 2 Mouse
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 136
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 2
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 226
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 10
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.10
bNumDescriptors 1
wDescriptorLength 54
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0020 1x 32 bytes
bInterval 6
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 6
Device Status: 0x0000
(Bus Powered)
Double flash would mean its failed to pair with the dongle, reset it by removing the batteries.
The 3 devices are
1x Mouse
1x Top side keyboard
1x Bottom side keyboard
Cheers
