2011-10-06, 17:42
^^ I read somewhere that the USB 2.0 standards have allowances for higher current then 1.1.
I asked before.. But please, if you have a unit which is deemed defective, please send it my way. I'm sure Motorola will attempt to blame the users... Whereas if I get a device for teardown, I may be able identify and isolate the problem then make it known which will basically force the manufacturer to correct and possibly recall the device if a hardware problem is to blame... Not that this is ideal, but even still, I'd like to help if I can.
I'm responsible for several on-board modifications on various mobile devices. I will publish results if I can find any as I have in the following threads:
http://forum.xda-developers.com/showthre...?t=1206216
http://forum.xda-developers.com/showthre...?t=1111866
http://forum.xda-developers.com/showthre...?t=1065318
http://forum.xda-developers.com/showthre...?t=1245391
http://forum.xda-developers.com/showthre...?t=1288162
http://forum.xda-developers.com/showthre...?t=1287780
http://forum.xda-developers.com/showthre...?t=1273083
http://forum.xda-developers.com/showthre...?t=1274999
Just saying... If you have a problem with a device, consider sending it my way for teardown. I will try to make sure we all learn from it.
Malard Wrote:Investigations are still taking place in Motorola to find out what the actual issue is, but my post on the pulse-eight forums is a _known_ way to resolve it. Not the only way I am sure
