Full Version: Cheapest small 'box' for XBMC?
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
eskro Wrote:you can easily build the 'same deal' yourself Smile
[MOBO+CPU+GPU] ASRock Atom 330 1.6Ghz ION1 Mini-ITX ($120 + $0)
[CASE+PSU] Apex MI-100 Black mini-ITX 250W ($53 + $0)
[FAN] Scythe Slipstream 120mm 800RPM 40.17CFM 10.70dBA ($13 + $0)
TOTAL: ($186)
just add 2GB(2x1GB) of RAM $29 http://ow.ly/1s0jjU
a small 250GB Hard Disk Drive $40 http://ow.ly/1s2HuA
Final Price-tag, $255!!!
Smile
that case is at least 3 or 4 times bigger than the zotac, plus it won't fit in standard A/V gear furniture Wink
well get another case then Tongue
My box...
pico PSU £17
Power Brick £6.50
Clear mITX Perspex case £25
Second hand IONITX-P-E £80
1gb DDR3 - £5
Total - £133.50
Looks like this
http://cgi.ebay.co.uk/Perspex-Mini-ITX-H...4877wt_952
This is a great deal, especially to use as an XBMC box now that it's been ported to iOS. Only $80 shipped.
http://cgi.ebay.com/Apple-TV-MC572LL-A/2...0.m2000036
mcan Wrote:eskro
how does your a330ion board sound? i've tried reducing my cpu fan speed in teh BIOS to reduce its noise but find that the system will shutdown even with very minor reduction in fan speed. its probably something to do with autoprotect system. btw - if i run fan at 100% the system is very stable and never crashes
its a 30mm cpu fan and so is naturally noisy but would like to hear how your system fairs.
m
Just jumping in on this:
The asrock ION 330 HT makes a lot of noise because of a louse fan-construction. I silenced my Asrock ION 330HT using this guide:
http://zandman.nl/archives/8
and have been enjoying the silence ever since.
