2019-07-19, 14:20
(2019-07-18, 01:12)daking1512 Wrote: bugs i found in the latest version you have on github
1- Netflix spotlight widget will auto highlight the spotlight area making it hard to scroll through the widget as I have to keep switching back to the widget tiles to scroll to the next tile, which will cause the same bug again. (also is it possible to hide the "trailer" button the spotlight view?)
https://streamable.com/j0lca
2- Cannot customize widgets on custom hubs (movies hub, TV shows hub, etc) they will not show the "set widget" item to choose what widget to put. hubs will basically copy the home menu and become a new home and it'll be impossible to go back to the home screen, if its possible to revert back to the old hubs implementation that we have in the stable release on the repo that would be great
https://streamable.com/xq1je
3- The power menu in the side blade while in custom hubs will be highlighted only when the side blade is off (look at the bottom left corner of the video). is it possible to disable power menu entries inside hubs ONLY?, or have a toggle to disable i, because currently we have a toggle to disable it everywhere
https://streamable.com/yw4z3
4- is it possible to scroll to the power menu items directly without having to press left to switch to the power items in the side blade?
any help is appreciated
I pushed a few fixes, some related to the HUB behavior. https://streamable.com/6k8bg
Going back , is now possible when click 'back' when main menu have focus.
Lock HUBs is now possible global (not restricted to Netflix Home anymore)
Keep in mind, the widget layout layout is based on the "default widget" setting in the Homemenusetting Section.
Can you report back some more issues, as i am not a user of that HUB and also away again for a week.
(actual i am just aware of some positioning issues if the widget layout uses a high *height* value, i think larger than 350, )
