2013-12-08, 08:20
(2013-12-07, 19:36)hstegeman Wrote: [ -> ]See post 1, you have to make use of the testing repo.
Yes, I did download the testing repo.... Still unable to launch the app
(2013-12-05, 03:15)Devo7v Wrote: [ -> ]This addon works great, the Windows control utility is great. Since this is designed to work with Media Center remotes is there a reason the control utility can't be used to intercept remote presses and map them to the native Netflix hotkeys (a list of them can be found here: http://markwarren.wordpress.com/2010/03/...shortcuts/)?I've posted all useful controls in the first post:
So for instance in the control utility have the option to set the play button on the remote and it would activate the "Page Up" hotkey in the Chrome browser. Maybe these hotkey entries could be entered on a second page.
Is there a reason this couldn't be done?
Seek: Left/Right
Volume +-: Up/Down
Pause/Play: Space or Enter
(2013-12-05, 05:00)Razor Ramon Wrote: [ -> ]Mm, i now added a setting to not use chrome in kiosk mode. Try it to setup chrome. Maybe the screen then gets remembered.(2013-12-02, 03:27)AddonScriptorDE Wrote: [ -> ](2013-12-01, 06:07)Razor Ramon Wrote: [ -> ]I am using a PC with my TV as a dual monitor for XBMC. When I click anything it opens Netflix on my PC screen and not the TV. I tried making it so chrome only opens on the TV screen but that didn't help. Any idea what I can do?When you start Chrome manually, and close it on your preferred display, doesn't Chrome remember the last used display?
I just had a quick look, but couldn't find a parameter to force chrome to use a specific display.
The browser remembers to open on the TV screen but not when Netflix launches, it always automatically opens on the PC screen every time.
(2013-12-05, 05:19)LakersFan Wrote: [ -> ]When I select alt+F4 to exit the program, it kills Chrome but does not bring XBMC back up (it remains minimized). When I go to maximize it, it stays windowed.When using the Control Utility, you should close the browser via the mapped key so the browser and utility get closed correctly.
Another thing, if I close XBMC anytime after using this addon and later reopen, I get "ERROR: Unable to create application. Exiting" From that point I can only open the task manager and kill NetfliXBMC_utility.exe or restart the PC
I'm using Windows 7...
Thank you for creating this and for your support.
(2013-12-05, 22:29)cquilliam Wrote: [ -> ]Got the plugin installed, but I can't seem to get it working.
On Windows 8.1 64bit, XBMC 12.2. I configured the plugin with my netflix account, but it keeps telling me I'm not logged in, and to restart the plugin. I've verified that the email and password is correct, and can log in fine from a web browser on the system system.
The only thing I can think of is that my email has a '+' in it, would that throw your script in some way?
(2013-12-07, 06:51)HardRom Wrote: [ -> ]I changed something on the login. Could you both please try the addon again and report if it's working now. Thanks...(2013-12-05, 22:29)cquilliam Wrote: [ -> ]Got the plugin installed, but I can't seem to get it working.
This, except that I don't have any non-alpha characters in my login, but my password does...?
Edit: I cleared cookies, have restarted XBMC twice, and have disabled and reenabled the addon to no avail.
P.s. I registered to say GREAT JOB and I look forward to using this addon.
P.s.s. In Canada.
(2013-12-06, 00:32)locoguano Wrote: [ -> ]Under Linux... Though I have Chrome set up to play Netflix and it works when just using the browser... when I launch from XBMC I get the "Wrong browser type" page.
(2013-12-07, 05:24)tymanthius Wrote: [ -> ]You have setup your User-Agent and it's working directly via the browser? Are you using the "Use own user profile" setting in Chrome Launcher. Then, you need to setup the user-agent there, too.(2013-12-06, 00:32)locoguano Wrote: [ -> ]Under Linux... Though I have Chrome set up to play Netflix and it works when just using the browser... when I launch from XBMC I get the "Wrong browser type" page.
I just installed, and I'm getting this also.
(2013-12-07, 04:37)Dewordie Wrote: [ -> ]Is there a way to make the player launch in IE rather than safari or chrome? Thanks!Added support for IE...
(2013-12-07, 19:00)hauntvictim Wrote: [ -> ]Successfully added on this .zip file but when I navigate to the enable add on in my "settings" section and click on the add on nothing is there and nothing comes up.
Sorry new to this.
(2013-12-07, 19:26)alander Wrote: [ -> ]Hi guys,To all having problems installing the addon:
I'm assuming I'm missing some very simple and obvious step... but I cannot get this plug in to show in my XBMC (Frodo on Windows 7). I have installed the repository successfully, have the Chrome installed as well, the repo shows up on the list of available repositories (along with Superrepo, bluecop), but there are no addons inside... I.e. it's emplty.... What am I doing wrong any help would be greatly appreciated. Thanks.
(2013-12-07, 22:43)bradwatson Wrote: [ -> ]Been using this add on a lot lately. Have to say it's probably the best add on out there. Thanks!Thanks! Great to hear...
(2013-12-08, 16:00)krish_2k4 Wrote: [ -> ]fyi the Chrome addon says dependencies not met for the recent Gotham monthly build, so to those who want to use this addon don';t upgrade just yet!I updated Chrome Launcher, so it's now also working with Gotham...
(2013-12-08, 18:51)AddonScriptorDE Wrote: [ -> ]v1.0.9:
- Fixed login issue
- Added "Viewing Activity"
- Added support for IExplorer (Win)
- Added function to add "My List" to library
- Added TMDb integration to get cover & fanart images
- Added context menu "Play trailer"
I don't think there are any other useful hotkeys listed in the article you posted. I am controlling everything via remote: Up/Down/Left/Right/OK for above contols and BACK to close the browser.Code:Seek: Left/Right
Volume +-: Up/Down
If you really need to map these hotkeys to other remote keys, i could implement it...
(2013-12-08, 18:51)AddonScriptorDE Wrote: [ -> ]v1.0.9:No change here- I uninstalled the addon and reinstalled, went to videos and it still says you are not logged in. Trying a restart to see if that helps...
(2013-12-08, 18:51)AddonScriptorDE Wrote: [ -> ]You have setup your User-Agent and it's working directly via the browser? Are you using the "Use own user profile" setting in Chrome Launcher. Then, you need to setup the user-agent there, too.
I now added a setting to not use the kiosk mode. Activate it and setup chrome so it works for you. It (hopefully) then also works with kiosk mode...
- Fixed login issue
(2013-12-08, 19:37)Devo7v Wrote: [ -> ]You're right. Default controls are currently not mappable. I thought it's fine with the hotkeys from their site. Working perfectly for me with my remote.(2013-12-08, 18:51)AddonScriptorDE Wrote: [ -> ]v1.0.9:
- Fixed login issue
Volume +-: Up/Down
Thanks for responding. Maybe I'm completely missing something, but the way I envisioned this working was the same way the remote works in XBMC. For instance, in XBMC when I press the play or pause button on my remote (MCE remote) it plays or pauses the video. When I do the same thing in Netflix, since the keys aren't mapped they don't do anything.
I understand that I can use up/down, left/right, but the way the config utility you provide works and the way the MCE remote is setup I cannot map the arrow keys on the remote because in XBMC they are mapped to the arrow keys as expected, but in your utility the arrow keys move between the options and there is no way to map an arrow key to an option.
Again, I feel like I'm missing something, but it seems like the buttons on the MCE remote should work the same way in this addon as they do in XBMC. This is why I suggested being able to map all the hotkeys on the page I linked to with your utility. Please let me know if I'm completely off base.
EDIT: Let me say that this addon works better than expected and everything you've implemented works as advertised, I'm just trying to make my remote work seamlessly between XBMC and Netflix.
(2013-12-08, 19:58)HardRom Wrote: [ -> ](2013-12-08, 18:51)AddonScriptorDE Wrote: [ -> ]v1.0.9:No change here- I uninstalled the addon and reinstalled, went to videos and it still says you are not logged in. Trying a restart to see if that helps...
No such luck.
Inserting from imgur isn't working for some reason- full link:
http://imgur.com/8BiJgQt
Edit- Removed it, reinstalled it, then removed (Del Key) the info in the username and pass, reentered it (verififying my username/pass on the website before hand).... and it works.
I would hate to think that I just typed my combo wrong the first time and I've wasted your time since then- So instead I'll casually say thanks for your fix this morning that surely must have fixed it.
(2013-12-09, 00:36)cquilliam Wrote: [ -> ]Yes, the login is now working for me, thanks!Thank you both for the feedback! Nice it's now also working for you...
(2013-12-08, 20:39)tymanthius Wrote: [ -> ]I think the easiest way is to use an extension like this...(2013-12-08, 18:51)AddonScriptorDE Wrote: [ -> ]You have setup your User-Agent and it's working directly via the browser? Are you using the "Use own user profile" setting in Chrome Launcher. Then, you need to setup the user-agent there, too.
I don't really understand this, but I'll see if I can figure it out. Thanks.
EDIT: Ok, got it mostly figured out. I just don't know how to get the user agent change to stick. I can go into dev tools, and change it each time, but it won't stick!! Grrr
(2013-12-09, 00:21)xcalibrate Wrote: [ -> ]Your last update just adds that missing icing. Despite several US DNS providers not wanting to play nice with this addon, it is still a superb little addition to the addon family. XBMC needed a workable Netflix solution and credit where it is due, this addon is probably the closet anyone will get to that solution using Silverlight. Congrats.Thanks for your feedback.
(2013-12-09, 02:07)HardRom Wrote: [ -> ]I can't figure out how to quit the fullscreen IE window either- changed the key to ESC (so it's the same as back on my Harmony One Remote), but it just shows the timebar. No exit. If I try to play something else/use the extension by alt tabbing back to XBMC, it says script failed.Should be working fine with IE, too. Closing Chrome is working via the mapped key but IE not?
(2013-12-09, 02:07)HardRom Wrote: [ -> ]edit: I use the IE side instead of my preferred chrome as IE is Full Screen and chrome has the top and bottom bars, ruining the experience as well as potentially giving my plasma burn in (*long term)Chrome is working fine in kiosk (fullscreen) mode. Everyone here is using Chrome without problems. I would recommend you to use Chrome also...
(2013-12-07, 05:24)tymanthius Wrote: [ -> ](2013-12-06, 00:32)locoguano Wrote: [ -> ]Under Linux... Though I have Chrome set up to play Netflix and it works when just using the browser... when I launch from XBMC I get the "Wrong browser type" page.
(2013-12-09, 07:45)jawilljr Wrote: [ -> ]Another Linux user...getting wrong browser and OS. If I close XBMC and open Chrome the user agent works.To all linux/pipelight users: You need to change your user-agent! It's all mentioned on the pipelight homepage.
Debug Log
