I am trying to add a custom menu item where I can have a direct link to my 'New Movies' located in a specific folder.
When I try and add the custom menu item I can give it a name but when I select path to favorite, I get the 'cannot find Favourites.xml' message.
Initially I thought this was ios specific because it would not work on my aptv2, but then I tried it on my pc and I get the same message.
Just noticed that if I switch to aeon nox skin I can set the path but not when I switch back to confluence.
Seems there is an issue with script.favourites and the mod..is it fixable?
thanks
Well, i ´m here agin with other cuestion; my weather icons no show on home menu , i can see them into weather menu but at home menu i can see olny ºc without icons ... ¿is for the skin or the script? and is posible see the realtime fanart in home scream weather menu? ...
homerjs Wrote:I am trying to add a custom menu item where I can have a direct link to my 'New Movies' located in a specific folder.
thanks
My MOD does not support favorites as custom-menu-items, yet...
Are you sure that you got the right thread?
mm
neno1978 Wrote:Well, i ´m here agin with other cuestion; my weather icons no show on home menu , i can see them into weather menu but at home menu i can see olny ºc without icons ... ¿is for the skin or the script? and is posible see the realtime fanart in home scream weather menu? ...
Well, no problems on my side...
Are you using a nightly that is later than 15th november?
There was a lot of trouble with weather because of api-changes...
take a look here on how to get weather again:
http://wiki.xbmc.org/index.php?title=Weather
mad-max Wrote:Well, no problems on my side...
Ok. I'm change 13th november to 19th november and it's work! but what's about realtime background in home menu? it's posible? thanks!
neno1978 Wrote:Ok. I'm change 13th november to 19th november and it's work! but what's about realtime background in home menu? it's posible? thanks!
possible? yes, of course
Will this be added? Well, yes
Don't know when this will be done...maybe with the next official release from the repository...
mm
mardup Wrote:
sorry, this got a bit lost...will take care of it tonight...
mad-max
mad-max Wrote:try this one:
http://www.megaupload.com/?d=0S0PAD57
mad-max
Thanks a lot !!!
Now it's OK !
just one thing ..
If a day you have some time, perhaps it will be more beautiful if the 3 recently added gadgets ( movies, tv show, albums ) have the same numbers of items
Actually : movies 5, albums and tv shows 4.
5 for all should be nice ....
thanks again !
mardup Wrote:Actually : movies 5, albums and tv shows 4.
Already thought about this, but there is not enough space for 5 items on each category...
I won't change the size in order to still have confluence-style in the widgets...
mad-max
Mad-Max i love the modification you made to the skin. Would it be possible to add weather info on the home screen too? Like we get for latest videos on the top?
hunkyn Wrote:Mad-Max i love the modification you made to the skin. Would it be possible to add weather info on the home screen too? Like we get for latest videos on the top?
Already possible...you have to activtate the "weather widget on home-screen" in skin settings
