Bluecop: Could you please enable the https(http tunnel) proxy settings. The http proxy settings you provided seems unable to bypass the Geo-blocking.
The only successful examples were ITV and I radio player plug-ins, they seems have an advanced proxy settings,which enable users to watch streams outside UK.
http://forum.xbmc.org/showthread.php?tid=51322 Iradio plug in
http://xbmc-itv-player.googlecode.com/fi..._1.0.6.zip itv plug in
I would appreciate it so much if you could take time to look into it. I knew it's not your job to bypass the geo blocking for us. Thank you very much indeed.
Thanks bluecop for the proxy settings. Works fine.
Was able to access vevo using 184.73.41.245:8000
You have to click the video a few times for it to finally work, prolly cause the proxy is quite busy.
Seems only anonymous proxies will work, Noa proxies don't seem to work, but I haven't tested that extensively. The proxy I posted above is anonymous and it works after a few tries, might not work for playlists unless u have a less busy proxy.
ailingcoot: I just used the proxy code from hulu. It is just an http proxy with authentication support if you want. I see that iPlayer has some pretty robust proxy options with http, http(tunneled), socks4, and socks5. I just haven't looked into it because no one ever really requested any further options. I don't use the feature at all so adding other proxy options wasn't a priority. I will still put it on my to do list to add more proxy options. It should be easy to add to all plugins because I use a urllib2 everywhere.
BlueCop, I am still having problems with the playlists. I have vevo enabled in Facebook and I have also logged in vevo using facebook account.
When I go try to go the playlist, it gives me a facebook login failed error.
(2012-07-16, 23:31)BlueCop Wrote: [ -> ]ailingcoot: I just used the proxy code from hulu. It is just an http proxy with authentication support if you want. I see that iPlayer has some pretty robust proxy options with http, http(tunneled), socks4, and socks5. I just haven't looked into it because no one ever really requested any further options. I don't use the feature at all so adding other proxy options wasn't a priority. I will still put it on my to do list to add more proxy options. It should be easy to add to all plugins because I use a urllib2 everywhere.
Thanks a lot. I believed that the proxy in HULU never successfully bypassed the Geo blocking. So it is a surprise to see the proxy actually work in iPlayer or Itv plug-ins.
VEVO changed a month ago to block the video streaming outside the US(it was working for streaming before by disabling the cache/download option.) I am curious to know whether a successful proxy settings would be better than VPN or not.
Thanks again for all the efforts.
This is the addon that I have been looking for for months. Absolutely exactly what I wanted and absolutely brilliant in execution so kudos to bluecop. anyway i can make a financial contribution for your time and efforts?
I'm in the UK so wasn't sure if it would work, but it works like a charm, and I love the cache capability because I have a monthly download limit so this way I only need to watch a video once, and then after that it automatically plays the video that is cached don my pc, s i don't have to download it every time.
Quick questions:
1 Is there any way to turn off the subtitles?
2 Does anyone know if there is an option on vevo to only show music videos (so that it doesn't show live performances in the lists)?
3 My "Current Playlist" button on my remote just gives me the "audio offset" control on the screen. How can I use the "Current Playlist" screen with this vevo addon?
4 I've been adding songs to a playlist using the addon, but when i look back at vevo in my browser the playlist is still empty, is it not supposed to update the website?
This is for everyone having problems with the playlists. I setup my playlist on vevo.com, did the facebook app, login/logout, token on/off, etc. Nothing was working. I thought I'd tell people how I got it to work. I installed the Vevo app on my phone and synced it with my facebook account. Now my playlists are finally showing up in xbmc.
A BIG GIANT BUNCHA THANKKKKKKK YOU TO YOU BLUECOP U D MANNNNN... AGAIN THANK YOU THANK YOU THANK YOU
KEEP UP THE GREAT WORK
i was having the same problem like the others with the "facebook login failure"
i was able to get it to connect on my atv2 through xbmc once i installed the app on my iPhone.
here is what happened to me from the start...
went to vevo.com and logged in using facebook accout.
created a custom playlist with just couple of songs
installed the vevo on my atv2 in xbmc
went to systems> add-ons> enabled add-ons> video add-ons> vevo
in the configure tab> user data> put in my facebook email and password.
went to vevo plugin on the xbmc and tried to get into playlist
THIS IS WHERE IT KEPT GIVING ME THE LOGIN FAILURE
i spent about 20 minutes trying to figure out what was wrong and googling..
logged in/out of Facebook few time on the puter just to make sure i was putting it in correctly
so i figured i'll try it on my iPhone.
so i installed it on my iPhone. tried logging in through facebook and it too wouldn't connect
until i realized that i wasn't logged in to Facebook site at all... i know a noob mistake
once i logged in to facebook i tried again to log in using vevo on my iPhone.
once that connected and i was in i went back to vevo plugin on xbmc on atv2
went down to the playlist and it loaded my custom playlist i created on vevo.com
it took a bit longer to load than the previous attempt but it works now.
the whole process took a little bit over 30 minutes.
Excellent! I got my playlist to show up. Thank you everyone for all your help and making it soo simple.
Is there a way to play the videos on shuffle?
Is there a way to have the plugin include a download option?
Not this playlist off logging to facebook
Similar issues with Facebook login here, copied the auth request URL out of the xbmc.log and hit it in a browser, allowed it through and then it worked fine.
Hi great plugin I'm a big fan
Is anyone having any issues when playing a high def vid? My system "blacks"out very odd ... It's not even like something crashes .... My system goes black and imactually lose video .... Then if I hit stop I get my video back and I'm in stop mode .... Can someone try playing that Gangum style video ... Let me know if it plays for ya.
Many thanks in advance
Love this app so much and hoping someone can take a look at my log here:
http://pastebin.com/xpBMBUgB
This is what happens:
1. Problem only exists on high quality videos.
2. If I DONT run XBMC in full window mode the video actually plays just fine.
3. Problem only exists when playing XBMC in full screen mode.
4. Video plays for about 4-5 seconds, then my entire screen goes black and I lose all video - even the PC video.
5. I hit the backspace.
6. Brings back the main Vevo screen.
7. I hit TAB - and the video resumes playing just fine until the end.
8. Vevo via web browser (firefox) plays fine - window'd and full screen.
Notes: I have an ATV2 in my room via the same network and Vevo works just fine.
One other thing- is when i go to load my playlist and it says opening up stream - it just sits there - then i hit backspace and I get into the interface.
Running Win7, Intel core i3-2100
Acus P8H67-M Pro
I tried disable / enable hardware acceloration in flash (right click the video in Vevo via web)
Lastly: Although I am not having the problem in my web browser (firefox and ie) I found this and tried these steps as well ... with no luck.
http://helpx.adobe.com/flash-player/kb/n...-mode.html
The "Enable Set View" option is not working for me. I am using Quartz skin and almost everything shows up as list view regardless of what I set this option to.
