2014-10-17, 09:18
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
2014-10-24, 21:15
any update or its dead
2014-11-20, 18:21
For those who are interested in 1080 Vevo videos, see the next post.
2014-11-21, 15:35
The HLS changes for 1080 and a fix for "Featured" are now in moneymaker's git which is where the most updated version will be:
https://github.com/moneymaker365/plugin.video.vevo
or better, if you want updates as well, use moneymaker's repo:
https://github.com/moneymaker365/reposit...mc-plugins
Please let me know if these changes work for you, there are some moving parts that may not work in all parts of the world.
2014-11-21, 16:27
learningit, for solve log in vevo with facebook, here code facebook.py
for validate log via facebook in Kodi, I use script Facebook Media by ruuk
#!/usr/bin/env python
# Copyright 2010 Facebook
# Licensed under the Apache License, Version 2.0 (the "License"); you may
# not use this file except in compliance with the License. You may obtain
# a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
# WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
# License for the specific language governing permissions and limitations
# under the License.
"""Python client library for the Facebook Platform.
This client library is designed to support the Graph API and the official
Facebook JavaScript SDK, which is the canonical way to implement
Facebook authentication. Read more about the Graph API at
http://developers.facebook.com/docs/api. You can download the Facebook
JavaScript SDK at http://github.com/facebook/connect-js/.
If your application is using Google AppEngine's webapp framework, your
usage of this module might look like this:
user = facebook.get_user_from_cookie(self.request.cookies, key, secret)
if user:
graph = facebook.GraphAPI(user["access_token"])
profile = graph.get_object("me")
friends = graph.get_connections("me", "friends")
from poster.encode import multipart_encode
import poster.streaminghttp
import urllib, urllib2
import sys, re, codecs
from urllib2 import HTTPError
from cgi import parse_qs
import os, xbmc, xbmcaddon
__addon__ = xbmcaddon.Addon(id='script.facebook.media')
poster.streaminghttp.register_openers()
# Find a JSON parser
try:
import json
_parse_json = lambda s: json.loads(s)
_dump_json = lambda s: json.dumps(s)
except ImportError:
try:
import simplejson
_parse_json = lambda s: simplejson.loads(s)
_dump_json = lambda s: simplejson.dumps(s)
except ImportError:
# For Google AppEngine
from django.utils import simplejson
import locale
loc = locale.getdefaultlocale()
print loc
ENCODING = loc[1] or 'utf-8'
def ENCODE(string):
return string.encode(ENCODING,'replace')
def LOG(string):
try:
print 'FACEBOOK MEDIA:facebook.py - %s' % ENCODE(str(string))
return
except:
print "FACEBOOK MEDIA:facebook.py - COULDN'T ENCODE FOR LOG - RETRYING"
try:
print 'FACEBOOK MEDIA:facebook.py - %s' % repr(string)
return
except:
print "FACEBOOK MEDIA:facebook.py - COULDN'T ENCODE FOR LOG - FINAL"
class GraphAPI(object):
"""A client for the Facebook Graph API.
See http://developers.facebook.com/docs/api for complete documentation
for the API.
The Graph API is made up of the objects in Facebook (e.g., people, pages,
events, photos) and the connections between them (e.g., friends,
photo tags, and event RSVPs). This client provides access to those
primitive types in a generic way. For example, given an OAuth access
token, this will fetch the profile of the active user and the list
of the user's friends:
graph = facebook.GraphAPI(access_token)
user = graph.get_object("me")
friends = graph.get_connections(user["id"], "friends")
You can see a list of all of the objects and connections supported
by the API at http://developers.facebook.com/docs/reference/api/.
You can obtain an access token via OAuth or by using the Facebook
JavaScript SDK. See http://developers.facebook.com/docs/authentication/
for details.
If you are using the JavaScript SDK, you can use the
get_user_from_cookie() method below to get the OAuth access token
for the active user from the cookie saved by the SDK.
def __init__(self, access_token=None):
self.access_token = access_token
def get_object(self, ID, **args):
"""Fetchs the given object from the graph."""
return self.request(ID, args)
def get_objects(self, ids, **args):
"""Fetchs all of the given object from the graph.
We return a map from ID to object. If any of the IDs are invalid,
we raise an exception.
args["ids"] = ",".join(ids)
return self.request("", args)
def get_connections(self, ID, connection_name, **args):
"""Fetchs the connections for given object."""
return self.request(ID + "/" + connection_name, args,update_prog=True)
def put_object(self, parent_object, connection_name, **data):
"""Writes the given object to the graph, connected to the given parent.
For example,
graph.put_object("me", "feed", message="Hello, world")
writes "Hello, world" to the active user's wall. Likewise, this
will comment on a the first post of the active user's feed:
feed = graph.get_connections("me", "feed")
post = feed["data"][0]
graph.put_object(post["id"], "comments", message="First!")
See http://developers.facebook.com/docs/api#publishing for all of
the supported writeable objects.
Most write operations require extended permissions. For example,
publishing wall posts requires the "publish_stream" permission. See
http://developers.facebook.com/docs/authentication/ for details about
assert self.access_token, "Write operations require an access token"
return self.request(parent_object + "/" + connection_name, post_args=data)
def put_wall_post(self, message, attachment={}, profile_id="me"):
"""Writes a wall post to the given profile's wall.
We default to writing to the authenticated user's wall if no
profile_id is specified.
attachment adds a structured attachment to the status message being
posted to the Wall. It should be a dictionary of the form:
{"name": "Link name"
"link": "http://www.example.com/",
"caption": "{*actor*} posted a new review",
"description": "This is a longer description of the attachment",
"picture": "http://www.example.com/thumbnail.jpg"}
return self.put_object(profile_id, "feed", message=message, **attachment)
def put_comment(self, object_id, message):
"""Writes the given comment on the given post."""
return self.put_object(object_id, "comments", message=message)
def put_like(self, object_id):
"""Likes the given post."""
return self.put_object(object_id, "likes")
def delete_object(self, ID):
"""Deletes the object with the given ID from the graph."""
self.request(ID, post_args={"method": "delete"})
def request(self, path, args=None, post_args=None,update_prog=False):
"""Fetches the given path in the Graph API.
We translate args to a valid query string. If post_args is given,
we send a POST request to the given path with the given arguments.
if not args: args = {}
headers = None
post_data = None
if self.access_token:
if post_args is None:
args["access_token"] = self.access_token
post_data = None
else:
post_args["access_token"] = self.access_token
post_data, headers = multipart_encode(post_args)
pre = "https://graph.facebook.com/"
args = "?" + urllib.urlencode(args)
if path.startswith('http'):
pre = ''
args = ''
url = pre + path + args
try:
if headers:
request = urllib2.Request(url, post_data, headers)
fileob = urllib2.urlopen(request)
else:
fileob = urllib2.urlopen(url,post_data)
except HTTPError, e:
if e.code == 400:
reason = e.headers.get('WWW-Authenticate')
LOG('\nMessage: %s\nReason: %s' % (e.msg,reason))
if 'invalid_token' in reason or 'invalid_request' in reason:
if 'unsupported get request' in reason.lower():
raise GraphAPIError( 'BadGetException',
'Unsupported get request')
else:
raise GraphAPIError( 'OAuthException',
'Expired/bad token')
raise
encoding = fileob.info().get('content-type').split('charset=')[-1]
fileob = codecs.EncodedFile(fileob, encoding)
if update_prog: self.updateProgress(30)
try:
data = ''
try:
total = int(fileob.info()['content-length'])
except:
total = 1
update_prog = False
chunk = 4096
sofar = 0
while True:
d = fileob.read(chunk)
if not d: break
data += d
if update_prog:
sofar += chunk
prog = int((sofar * 40) / total)
if update_prog and not self.updateProgress(30 + prog): return
response = _parse_json(data)
finally:
fileob.close()
if type(response) == type({}) and response.get("error"):
raise GraphAPIError(response["error"]["type"],
response["error"]["message"])
return response
def updateProgress(self,pct):
return True
class GraphAPIError(Exception):
def __init__(self, type_, message):
Exception.__init__(self, message)
self.type = type_
class GraphWrapAuthError(Exception):
self.type = type_
self.message = message
class Connections(list):
def __init__(self,graph,connections=None,first=True,progress=True):
list.__init__(self)
self.first = first
self.graph = graph
self.progress = progress
self.previous = ''
self.next = ''
self.count = 0
if connections:
self.count = connections.get('count',0)
if connections: self.processConnections(connections)
def processConnections(self,connections):
cons = []
for c in connections['data']:
if hasattr(c,'get'):
cons.append(GraphObject(c.get('id'),self.graph,c))
self._getPaging(connections,len(cons))
self.extend(cons)
if self.progress: self.graph.updateProgress(100)
def _getPaging(self,obj,count):
paging = obj.get('paging')
if not paging: return
next_ = paging.get('next','')
prev = paging.get('previous','')
limit = self._areTheSame(next_, prev, count)
if limit:
self.previous = self._checkForContent(prev)
if not self.previous and count < limit and self.first: return
self.next = self._checkForContent(next_)
def _checkForContent(self,url):
if not url: return ''
connections = self.graph.request(url)
if not 'data' in connections: return ''
if not len(connections['data']): return ''
return url
def _areTheSame(self,next_,prev,count):
try:
limit = int(parse_qs(next_.split('?')[-1])['limit'][0])
except:
limit = count
try:
next_ut = int(parse_qs(next_.split('?')[-1])['until'][0])
prev_ut = int(parse_qs(prev.split('?')[-1])['since'][0])
if prev_ut == next_ut: return 0
return limit
except:
return limit
import UserDict
class UTF8DictWrap(UserDict.UserDict):
def get(self,key,failobj=None):
val = UserDict.UserDict.get(self, key, failobj)
if hasattr(val,'encode'): return unicode(val.encode('utf-8'),'utf-8')
return val
class GraphObject:
def __init__(self,ID=None,graph=None,data=None,**args):
if (not ID) and data:
if 'id' in data: ID = data['id']
self.id = ID
self.args = args
self.graph = graph
self._cache = {}
self._data = data
self.connections = GraphConnections(self)
if ID == 'me':
self._data = self._getObjectData(ID,**args)
self.id = self._data.get('id') or 'me'
def updateData(self):
self._data = self._getObjectData(self.id,**self.args)
return self
def toJSON(self):
return self._toJSON(self._data)
def get(self,key,default=None,as_json=False):
return self._getData(key,default,as_json)
def hasProperty(self,prop):
return prop in self._data
def comment(self,comment):
self.graph.put_comment(self.id,comment)
def like(self):
self.graph.put_like(self.id)
def __getattr__(self, prop):
if prop.startswith('_'): return object.__getattr__(self,prop)
if prop.endswith('_'): prop = prop[:-1]
if prop in self._cache:
return self._cache[prop]
if not self._data:
if self.id == 'me': self.id = self._data.get('id') or 'me'
def handler(default=None,as_json=False):
return self._getData(prop,default,as_json)
handler.method = prop
self._cache[prop] = handler
return handler
def _getData(self,prop,default,as_json):
val = self._data.get(prop)
if not val: return default
if type(val) == type({}):
if 'data' in val:
if as_json:
return self._toJSON(val)
elif isinstance(val['data'],list):
return Connections(self.graph,val,progress=False)
else:
val = val['data']
return UTF8DictWrap(val)
return val
def _getObjectData(self,ID,**args):
fail = False
try:
return self.graph.get_object(ID,**args)
except GraphAPIError,e:
if not e.type == 'OAuthException': raise
fail = True
if fail:
LOG("ERROR GETTING OBJECT - GETTING NEW TOKEN")
if not self.graph.getNewToken():
if self.graph.access_token: raise GraphWrapAuthError('RENEW_TOKEN_FAILURE','Failed to get new token')
else: return None
def _toJSON(self,data_obj):
return _dump_json(data_obj)
class GraphData:
def __init__(self,graphObject,data=None):
self.graphObject = graphObject
self.graph = self.graphObject.graph
if not self._data: self._data = self._getObjectData(self.graphObject.id)
def handler(default=None):
val = self._data.get(prop,default)
return val
return handler
fail = False
try:
fail = True
if fail:
else: return None
class GraphConnections:
def __init__(self,graphObject):
self.cache = {}
def __getattr__(self, method):
if method.startswith('_'): return object.__getattr__(self,method)
if method in self.cache:
return self.cache[method]
def handler(**args):
fail = False
try:
return self._getConnections(method,**args)
LOG(e.type)
fail = True
if fail:
LOG("ERROR GETTING CONNECTIONS - GETTING NEW TOKEN")
else: return None
handler.method = method
self.cache[method] = handler
return handler
def _getConnections(self,method,**args):
connections = self.graph.get_connections(self.graphObject.id, method.replace('__','/'), **args)
self.graph.updateProgress(70)
return Connections(self.graph,connections)
def _processConnections(self,connections,paging):
return self.graph._processConnections(connections,paging)
class GraphWrap(GraphAPI):
def __init__(self,token,new_token_callback=None,version='8.0'):
GraphAPI.__init__(self,token)
self.uid = None
self._newTokenCallback = new_token_callback
self._progCallback = None
self._progModifier = 1
self._progTotal = 100
self._progMessage = ''
self.uid = None
self.cookieJar = None
self.version = version
def withProgress(self,callback,modifier=1,total=100,message=''):
poster.streaminghttp.PROGRESS_CALLBACK = callback
self._progCallback = callback
self._progModifier = modifier
self._progTotal = total
self._progMessage = message
return self
def updateProgress(self,level):
if self._progCallback:
level *= self._progModifier
return self._progCallback(int(level),self._progTotal,self._progMessage)
return True
def fromJSON(self,json_string):
if not json_string: return None
data_obj = _parse_json(json_string)
if type(data_obj) == type({}):
if 'data' in data_obj:
return Connections(self,data_obj,progress=False)
elif 'id' in data_obj:
return GraphObject(graph=self,data=data_obj)
return data_obj
def putWallPost(self,message, attachment={}, profile_id="me"):
fail = False
try:
return self.put_wall_post(message, attachment, profile_id)
LOG(e.type)
fail = True
if fail:
LOG("ERROR POSTING TO WALL - GETTING NEW TOKEN")
if not self.getNewToken():
if self.access_token: raise GraphWrapAuthError('RENEW_TOKEN_FAILURE','Failed to get new token')
else: return None
def putObject(self,parent_object, connection_name, **data):
fail = False
try:
return self.put_object(parent_object, connection_name, **data)
LOG(e.type)
fail = True
if fail:
LOG("ERROR POSTING OBJECT - GETTING NEW TOKEN")
else: return None
def getObject(self,ID,**args):
return GraphObject(ID,self,**args)
def getObjects(self,ids=[]):
data = self.get_objects(ids)
objects = {}
for ID in data:
objects[ID] = GraphObject(ID,self,data[ID])
return objects
def urlRequest(self,url):
connections = self.request(url)
return Connections(self,connections,first=False)
def setLogin(self,email,passw,uid=None,token=None):
self.uid = uid or self.uid
self.login_email = email
self.login_pass = passw
if token: self.access_token = token
def setAppData(self,aid,redirect='https://www.facebook.com/connect/login_success.html',scope=None):
self.client_id = aid
self.redirect = redirect
self.scope = scope
def checkHasPermission(self,permission):
url = 'https://api.facebook.com/method/users.hasAppPermission?format=json&ext_perm='+permission+'&access_token='+self.access_token
fobj = urllib2.urlopen(url)
try:
response = _parse_json(fobj.read())
finally:
fobj.close()
return (response == 1)
def browserRead(self,readable,post=''):
html = readable.read()
if False:
htmlFile = os.path.join(xbmc.translatePath(__addon__.getAddonInfo('profile')),'cache','DEBUG_HTML%s.html' % post)
with open(htmlFile,'w') as f:
f.write(html.strip("'"))
return html
def checkIsAppUser(self):
url = 'https://api.facebook.com/method/users.isAppUser?format=json&access_token='+self.access_token
try:
finally:
fobj.close()
return response
def getNewToken(self):
import mechanize #@UnresolvedImport
br = mechanize.Browser()
cookiesPath = os.path.join(xbmc.translatePath(__addon__.getAddonInfo('profile')),'cache','cookies')
LOG('Cookies will be saved to: ' + cookiesPath)
cookies = mechanize.LWPCookieJar(cookiesPath)
if os.path.exists(cookiesPath): cookies.load()
self.cookieJar = cookies
opener = mechanize.build_opener(mechanize.HTTPCookieProcessor(cookies))
mechanize.install_opener(opener)
br.set_cookiejar(self.cookieJar)
br._ua_handlers["_cookies"].cookiejar.clear()
br.set_handle_robots(False)
agent = 'XBMC/{0} Facebook-Media/{1}'.format(xbmc.getInfoLabel('System.BuildVersion'),self.version)
LOG('Setting User Agent: {0}'.format(agent))
br.addheaders = [('User-agent',agent)]
scope = ''
if self.scope: scope = '&scope=' + self.scope
url = 'https://www.facebook.com/dialog/oauth?client_id='+self.client_id+\
'&redirect_uri='+self.redirect+\
'&type=user_agent&display=popup'+scope
LOG(url)
try:
res = br.open(url)
html = res.read()
except:
LOG("ERROR: TOKEN PAGE INITIAL READ")
raise
script = False
try:
#check for login form
br.select_form(nr=0)
LOG("HTML")
except:
self.genericError()
script = True
LOG("SCRIPT")
if script:
#no form, maybe we're logged in and the token is in javascript on the page
url = res.geturl()
token = self.extractTokenFromURL(url)
if not token: token = self.parseTokenFromScript(html)
else:
try:
#fill out the form and submit
br['email'] = self.login_email
br['pass'] = self.login_pass
res = br.submit()
url = res.geturl()
LOG("FORM")
except:
LOG("FORM ERROR")
raise
script = False
html = self.browserRead(res,'-noscript')
if not token:
#if 'class="checkpoint"' in html:
token = self.handleLoginNotificationCrap(br)
if not token: script = True
if script:
LOG("SCRIPT TOKEN")
#no token in the url, let's try to parse it from javascript on the page
try:
htmlFile = os.path.join(xbmc.translatePath(__addon__.getAddonInfo('profile')),'cache','DEBUG_HTML.html')
open(htmlFile,'w').write(html)
LOG('html output written to: ' + htmlFile)
except:
pass
token = urllib.unquote(token.decode('unicode-escape'))
if not self.tokenIsValid(token):
#if script: LOG("HTML:" + html)
return False
LOG("\n|--------------------\n|TOKEN: %s\n|--------------------" % token)
self.saveToken(token)
if self.cookieJar is not None:
self.cookieJar.save()
return token
def handleLoginNotificationCrap(self,br):
LOG('Handling Login Notification Crap')
res = br.submit()
self.browserRead(res,'-loginnotifycrap1')
#if not 'Media XBMC' in html: return None
url = res.geturl()
LOG('LN First URL: ' + url)
if 'login.php' in url:
raise GraphWrapAuthError('BAD_USERPASS','Failed: Probable bad user/pass')
if 'access_token' in url: return self.extractTokenFromURL(url)
try:
res = br.submit(name='submit[Continue]')
except:
res = br.submit()
res.read()
url = res.geturl()
LOG('LN Second URL: ' + url)
self.isolateSubmitButton(br, 'save_device')
res = br.submit()
html = res.read()
url = res.geturl()
LOG('LN Third URL: ' + url)
if 'name="submit[Continue]"' in html:
LOG("Found 'Continue' page: submitting")
res = br.submit()
url = res.geturl()
else:
LOG("No Token In URL: {0}".format(url))
return None
def isolateSubmitButton(self,br,value):
return
submit_buttons = self.find_controls(br,ctype="submit")
for button in submit_buttons[:]:
if button.value != value: br.form.controls.remove(button)
def find_controls(self, br,name=None, ctype=None, kind=None, cid=None, predicate=None, label=None):
i = 0
results = []
try :
while(True):
results.append(br.find_control(name, ctype, kind, cid, predicate, label, nr=i))
i += 1
except Exception as e: #Exception tossed if control not found @UnusedVariable
pass
return results
def extractTokenFromURL(self,url):
try:
#we submitted the form, check the result url for the access token
import urlparse
token = parse_qs(urlparse.urlparse(url.replace('#','?',1).replace('??','?'))[4])['access_token'][0]
LOG("URL TOKEN: %s" % token)
return token
except:
LOG("TOKEN URL: %s" % url)
self.genericError()
return None
def tokenIsValid(self,token):
if not token: return False
if 'login_form' in token and 'standard_explanation' in token:
reason = re.findall('id="standard_explanation">(?:<p>)?([^<]*)<',token)
if reason: LOG(reason[0])
LOG("TOKEN: " + token)
raise GraphWrapAuthError('LOGIN_FAILURE',reason)
return False
if 'html' in token or 'script' in token or len(token) > 250:
return False
if 'login notifications' in token:
raise GraphWrapAuthError('RENEW_TOKEN_FAILURE','Disable login notifications, then retry')
return False
if 'temporarily locked' in token:
raise GraphWrapAuthError('RENEW_TOKEN_FAILURE','Facebook account is locked')
return False
#Because you enabled login notifications, your account is temporarily locked.
return True
def genericError(self):
LOG('ERROR: %s::%s (%d) - %s' % (self.__class__.__name__
, sys.exc_info()[2].tb_frame.f_code.co_name, sys.exc_info()[2].tb_lineno, sys.exc_info()[1]))
def parseTokenFromScript(self,html):
return urllib.unquote_plus(html.split("#access_token=")[-1].split("&expires")[0])
def saveToken(self,token=None):
if token:
if self._newTokenCallback: self._newTokenCallback(token)
2014-11-21, 16:52
Sorry, I don't see anything different in your version of facebook.py and the one in the git. Did you modify it in anyway?
2014-11-21, 16:57
This is the same used by ruuk, and work perfect, with actual in git have error when try log.
2014-11-21, 17:02
Ok, thanks now I understand.. I will look into it further and make the corrections to fix facebook login. I will sometime (after Thanksgiving) add in bitrate selection and staff picks to fix those problems, as well as some updates to the website. I have them coded, just need to test. thanks
2014-11-21, 19:22
(2014-11-21, 15:35)learningit Wrote: [ -> ]The HLS changes for 1080 and a fix for "Featured" are now in moneymaker's git which is where the most updated version will be:
I have repository.xbmcplus.xbmc-plugins-1.3.zip. Is it the same as the master zip you posted? Thanks.
2014-11-21, 19:24
(2014-11-21, 19:22)Arse4life Wrote: [ -> ]I have repository.xbmcplus.xbmc-plugins-1.3.zip. Is it the same as the master zip you posted? Thanks.
I think so. You will probably need to do a force refresh or update on either the repo or the VEVO addon to get the latest version.
2014-11-21, 19:50
(2014-11-21, 19:22)Arse4life Wrote: [ -> ]Yes, it is. Wait or do a force refresh like learningit git mentioned.(2014-11-21, 15:35)learningit Wrote: [ -> ]The HLS changes for 1080 and a fix for "Featured" are now in moneymaker's git which is where the most updated version will be:
2014-11-21, 19:51
I was stuck on available update for some reason. I have moneymakers repo installed. I tried a force refresh and check for updates. The vevo update is available but it goes from downloading 0% to update available again. However, after waiting some time the update kicked in on its own.
Thanks for the time and effort that goes into this addon. Much appreciated!
2014-11-22, 13:09
I can not get this addon working. When I go to Featured I get a HTTP Error 500: Internal server error. If I go to Artist and try to play a video I get a playback failed error. Debug log: http://pastebin.com/dUV3WDdk
2014-11-22, 15:31
(2014-11-22, 13:09)Zyma Wrote: [ -> ]I can not get this addon working. When I go to Featured I get a HTTP Error 500: Internal server error. If I go to Artist and try to play a video I get a playback failed error. Debug log: http://pastebin.com/dUV3WDdk
Firstly, thanks for not giving up on the addon when you got some errors. I see two things when I look into your log: 1) a definite bug because the video version numbering is different than what the addon expects in your locale; and 2) a bunch of what look like http timeouts and http 500 internal server errors.
The bug in 1 should still play a video, it will just play it in low res because that is the first video in the version it would select. I can fix this once I look into the version sequencing a bit in your locale.
Bug 2 could be a number of things, I'd like to see some more debug details.
For item #2, I need 2 things: 1) turn on verbose debugging under settings->system->debugging and enable CURL library debug. 2) re-run the sequence you did - Artists - Electronic/Dance - Most Viewed and select the video you did previously - let me know the name of your choice, whatever you chose previously I don't see in my locale. Send me the debug log and the artist you chose.
If you are ok with it, let me know what country you're in - you can PM me if you don't want it in the forum.
And just to be sure, what version of the addon are you running?
2014-11-22, 16:28
Thank you for your answer. I am in Sweden. Now I choose Artist -> Electronic/Dance -> Most Viewed -> Most viewed today -> Calvin Harris -> Summer. Debug with curl: http://pastebin.com/rruUBtJX
Edit: I Think it was the same video I choose first time.
Edit2: Version is 0.7.8
