(2015-01-01, 15:33)learningit Wrote: [ -> ] (2014-12-31, 17:45)m0uthless Wrote: [ -> ]hi learningit, thx for the answer
here kodi.log
http://pastebin.com/0vZE5vH5
Are you able to play the following url?
http://hls-aka.vevo.com/v3/hls/2014/12/TIVEV1419227/index.m3u8
You can put it in a .strm file and try playing it. This seems to be where you fail. I can play it, but I see that your country id is different from mine and it may be blocked where you are.
Yes i can reproduce the .strm file without the first video is skipped.
About the possibility of shuffle and skip a video to the next there is any chance in future updates?
I am relatively new to kodi,
I have tried installing vevo addon 0.7.8 from super repo, all the links work fine and video list shows up , however everytime i am about to play a video i got script error.
Thinking it might be version problem , i downloaded 0.8.2 version and installed from here ,
https://github.com/moneymaker365/xbmc-xb...video.vevo
it still has same problem
Can any of you help me figure out what the problem is, my debug log is here
http://pastebin.com/mhBxjVPy
(2015-01-02, 14:09)sudhirp Wrote: [ -> ]Hi,
Can any of you help me figure out what the problem is, my debug log is here http://pastebin.com/mhBxjVPy
I would uninstall any addons, download again from moneymaker's repo and install. The error you're getting is because the addon is defaulting to YouTube video playing and the YouTube addon you have has issues playing external links. Neither situation should happen, but because you loaded the addon initially from an extremely unreliable source there may be other issues with your setup.
Newb here. I can find the bluecop version.
How do install moneymakers as shown above?
Worked like a charm.
I have the latest version of vevo moneymaker repo installed on my ATV1 it worked fine with the older version now it stutters and is out of sync any advice please thank you
(2015-01-21, 02:38)delwashy Wrote: [ -> ]I have the latest version of vevo moneymaker repo installed on my ATV1 it worked fine with the older version now it stutters and is out of sync any advice please thank you
A log would be useful. What version were you previously running?
I can´t play any video. Give a script error. I installed from normal Repo. What can I do?
(2015-01-26, 16:37)CaBrA Wrote: [ -> ]I can´t play any video. Give a script error. I installed from normal Repo. What can I do?
A log would be useful. Also I don't know what you mean by normal Repo, what version are you running?
(2015-01-26, 16:54)learningit Wrote: [ -> ] (2015-01-26, 16:37)CaBrA Wrote: [ -> ]I can´t play any video. Give a script error. I installed from normal Repo. What can I do?
Here are the Infos:
LOG:
http://pastebin.com/Qh9sBp93
VEVO Version: 0.8.2
Problem: FEATURED Videos gives HTTP error 500 / Any other video qhen opening streams gives script failed.
(2015-01-26, 18:59)CaBrA Wrote: [ -> ]LOG: http://pastebin.com/Qh9sBp93
VEVO Version: 0.8.2
Looks like you need to use a proxy from your location. Just to confirm is HLS mode selected in addon settings?
(2015-01-26, 23:30)CaBrA Wrote: [ -> ]HLS Mode is disabled
HLS mode MUST be selected, other feeds do not work.
(2015-01-27, 00:01)learningit Wrote: [ -> ] (2015-01-26, 23:30)CaBrA Wrote: [ -> ]HLS Mode is disabled
Enabled HLS but same script error.
