2012-03-11, 05:54
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148
2012-03-12, 10:20
Lately I upgraded to latest ver (about a week ago) and found some regression in the acc codec.
Now I can't hear liveTV normally. I have echo with pitch changes all the time.
How can I downgrade to previous version?
Working with Mythbuntu 10.04.
Thank you.
Thank you.
2012-03-12, 20:40
I've switched to using this plugin for the last week now, in place of the mythfrontend. It seems to be running OK, but it does crash from time to time seemingly random.
So far the bugs I have come across are:
-After XBMC has been running for more the 24 hours, the 'Currently recording' and 'Next Recording' will show recordings planned for a week or more into the future
-Channel logos only appear in XBMC when running on the same PC as my mythbackend
-XBMC crashes when trying to exit (At first I thought it was just my graphics driver, but it also crashes on my laptop which has a different graphics driver; Intel instead of Nvidia)
-When starting to watch a new recording it will usually repeat the first couple seconds
-Sometimes a recording will just stop randomly when watching (will try to get a log next time it happens)
-when watching a recording that is still recording, the timer that shows how long the recording is doesn't update, unless your watching close to the end of the recording. This makes you only able to fast forward in shorter increments instead of the usual 30 secs
-Cant sort recordings by tvshow/movies(not really a bug, just not implemented)
-Recordings metadata/artwork not showing (Already mentioned by a previous poster)
If it help I have been looking into where myth stores its artwork and as far as I can tell, artwork is stored in the Coverart and Fanart storage groups *Table: storagegroups* then it uses the shows title to store the image (if its a tv shows), movies store images with the TMDB ID (You can find out if its a tvshow or movie by checking the 'recordedprogram' table)
I been trying to look at the source code to see how to get artwork to show up, but I know little c++, and even the little c++ I do know is based on windows, but I'll keep at it until I learn something
Will report more bugs as I find them, these were just the ones I remember of the top of my head.
2012-03-12, 23:38
Hey tsp,
Have a new problem....
My missus recorded One Tree Hill and the title of the show has a / in it: "know this, we/'ve noticed"
Not sure if this is the backend trying to escape the ' in the title, or the frontend trying to deal with it
Debug log snippit:
http://pastebin.com/7ffBP0Qc
All other recordings (including other episodes of One Tree Hill) play just fine, so must be something specific to this title
Regards,
Jim
Edit:
Just to compare, the mysql entries for the two One Tree Hill recordings:
http://pastebin.com/KnNN2MHr
The unsuccessful recording has the title+subtitle in the title field and the date in the subtitle field. Not sure what caused this really (may be an error in the xml grabber data?). Will try to edit the tables with a mysql query and see if the addon can play it. I'll report back......
Edit2:
Used a mysql query to change the title to "One Tree Hill", dropping the problematic / and now the addon plays it just fine. Interestingly, I could not construct a query matching the show's title entry in the database
so had to use the following to change the title based on the starttime instead:
guess if the recording can't be accessed via title during a mysql query, then the addon would have no chance either?
Debug log snippit:
Regards,
Jim
Edit:
Edit2:
mysql> select * from recorded where title = "One Tree Hill: Know This, We\'ve Noticed";
Empty set (0.00 sec)
mysql> UPDATE recorded set title = "One Tree Hill" where starttime = "2012-03-05 20:58:00";
Query OK, 1 row affected (0.00 sec)
Rows matched: 1 Changed: 1 Warnings: 0
2012-03-13, 22:23
(2012-03-07, 09:18)321liftoff Wrote: [ -> ]Trying out the windows binary from the first post (31/12/2011), but am getting this error:
Code:02:06:19 T:2136 NOTICE: -----------------------------------------------------------------------
02:06:19 T:2136 NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 3 build 2600. Built on Dec 31 2011 (Git:20111231-165c5c8, compiler 1600)
02:06:19 T:2136 NOTICE: Intel(R) Core(TM)2 Duo CPU T5250 @ 1.50GHz
02:06:19 T:2136 NOTICE: Desktop Resolution: 1280x800 32Bit at 60Hz
02:06:19 T:2136 NOTICE: Running with administrator rights
02:06:19 T:2136 NOTICE: Aero is disabled
02:06:19 T:2136 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
02:06:19 T:2136 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\XBMC
02:06:19 T:2136 NOTICE: special://masterprofile/ is mapped to: C:\Documents and Settings\xxxxx\Application Data\XBMC\userdata
02:06:19 T:2136 NOTICE: special://home/ is mapped to: C:\Documents and Settings\xxxxx\Application Data\XBMC\
02:06:19 T:2136 NOTICE: special://temp/ is mapped to: C:\Documents and Settings\xxxxx\Application Data\XBMC\cache
02:06:19 T:2136 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
02:06:19 T:2136 NOTICE: Log File is located: C:\Documents and Settings\xxxxx\Application Data\XBMC\xbmc.log
02:06:19 T:2136 NOTICE: Setup SDL
02:06:20 T:2136 NOTICE: Found screen: Plug and Play Monitor on Mobile Intel(R) 965 Express Chipset Family, adapter 0.
02:06:20 T:2136 NOTICE: Primary mode: 1280x800 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 320x200 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 320x240 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 400x300 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 512x384 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 640x400 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 1280x600 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
02:06:20 T:2136 NOTICE: load settings...
02:06:20 T:2136 NOTICE: special://profile/ is mapped to: special://masterprofile/
02:06:20 T:2136 NOTICE: loading special://masterprofile/guisettings.xml
02:06:20 T:2136 ERROR: special://masterprofile/guisettings.xml, Line 0
Failed to open file
02:06:20 T:2136 ERROR: Unable to load special://masterprofile/guisettings.xml, creating new special://masterprofile/guisettings.xml with default values
02:06:20 T:2136 NOTICE: Getting hardware information now...
02:06:20 T:2136 NOTICE: Checking resolution 12
02:06:20 T:2136 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
02:06:20 T:2136 NOTICE: Loaded playercorefactory configuration
02:06:20 T:2136 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
02:06:20 T:2136 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
02:06:20 T:2136 NOTICE: No settings file to load to load (special://xbmc/system/advancedsettings.xml)
02:06:20 T:2136 NOTICE: No settings file to load to load (special://masterprofile/advancedsettings.xml)
02:06:20 T:2136 NOTICE: Default DVD Player: dvdplayer
02:06:20 T:2136 NOTICE: Default Video Player: dvdplayer
02:06:20 T:2136 NOTICE: Default Audio Player: paplayer
02:06:20 T:2136 NOTICE: Disabled debug logging due to GUI setting. Level 0.
02:06:20 T:2136 NOTICE: Log level changed to 0
02:06:20 T:2136 NOTICE: Loading media sources from special://masterprofile/sources.xml
02:06:24 T:2136 ERROR: Keymapping error: no such action 'language' defined
02:06:24 T:2136 NOTICE: initializing playlistplayer
02:06:24 T:2136 NOTICE: DONE initializing playlistplayer
02:06:24 T:3640 ERROR: CRemoteControl::Connect - failed to connect
02:06:27 T:2136 NOTICE: EPG::CEpgContainer::Start - EPG thread started
02:06:27 T:2136 NOTICE: initialize done
02:06:27 T:2136 NOTICE: Running the application...
02:06:28 T:2136 NOTICE: ES: Starting event server
02:06:28 T:2868 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
02:06:28 T:2868 NOTICE: UDP: Listening on port 9777
02:06:30 T:2700 NOTICE: -->Python Interpreter Initialized<--
02:06:31 T:2700 ERROR: Error Type: <type 'exceptions.ImportError'>
02:06:31 T:2700 ERROR: Error Contents: No module named simplejson
02:06:31 T:2700 ERROR: Traceback (most recent call last):
File "C:\Program Files\XBMC\addons\weather.wunderground\default.py", line 17, in <module>
import os, sys, urllib2, base64, socket, simplejson
ImportError: No module named simplejson
02:06:33 T:448 ERROR: ADDON: extension '' is not currently supported for service addon
02:06:33 T:448 ERROR: CThread::staticThread : Access violation at 0x0042caa4: Reading location 0x00000000
02:06:39 T:2136 NOTICE: PVRManager - starting up
02:06:44 T:2136 NOTICE: PVRManager - stopping
02:06:44 T:1276 ERROR: PVRManager - PVR::CPVRManager::Process - failed to load PVR data
02:06:44 T:2136 NOTICE: PVRManager - starting up
02:06:46 T:3052 ERROR: Win32DllLoader::Load: Failed to load C:\Program Files\XBMC\addons\..\system\libcmyth.dll with error 127:The specified procedure could not be found.
02:06:46 T:3052 ERROR: LoadLibrary('libcmyth.dll') failed
02:06:46 T:3052 ERROR: AddOnLog: MythTV cmyth PVR Client: Failed to load cmyth library!
02:06:46 T:3052 ERROR: ADDON: Dll MythTV cmyth PVR Client - Client returned bad status (4) from Create and is not usable
02:06:46 T:3052 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'MythTV cmyth PVR Client'
repeat error
I double checked and libcmyth.dll is located in C:\Program Files\XBMC\system.
I've found it works fine on my Windows 7 machine but I get the above for XP. Must be using something that works for the later OS I guess?
If I find out what I'll post back here....
Cheers
Simon
2012-03-14, 00:58
inet_ntop seems to be the function call that's for Vista and later, it will need a change to libcmyth to make it XP compatible I think
2012-03-14, 13:32
Does anyone know if someone has 0.25 working in cmyth? It's currently in the beta phase and due out soon.
2012-03-14, 13:50
2012-03-14, 14:22
(2012-03-14, 13:50)ZyanKLee Wrote: [ -> ]I'm running this @head ( from github.com/tsp/xbmc ) ...
But I'm not sure how far this is from 0.25rc2
I've been playing with the current cmyth provided by XBMC and playback and stuff works fine but I am looking for LiveTV functionality. Was wondering if anyone tested that with 0.25.
2012-03-15, 21:01
(2012-03-14, 00:58)simonind Wrote: [ -> ]inet_ntop seems to be the function call that's for Vista and later, it will need a change to libcmyth to make it XP compatible I think
Is that a change I need to make in the source and compile, or can that change be made in the binary?
2012-03-16, 01:44
(2012-03-12, 23:38)Jimmer Wrote: [ -> ]Hey tsp,
Debug log snippit:
Regards,
Jim
Edit:
Edit2:
Code:mysql> select * from recorded where title = "One Tree Hill: Know This, We\'ve Noticed";
Code:mysql> UPDATE recorded set title = "One Tree Hill" where starttime = "2012-03-05 20:58:00";
Just wanted to add that I had this issue as well. Mine was a different show but when it was scheduled via the cmyth addon it inserted a '\' to escape the apostrophe and this showed in the title from that point on. The show recorded just fine but would not play until I changed the show name manually on the mysql cli.
2012-03-16, 09:27
(2012-03-16, 01:44)robweber Wrote: [ -> ]Just wanted to add that I had this issue as well. Mine was a different show but when it was scheduled via the cmyth addon it inserted a '\' to escape the apostrophe and this showed in the title from that point on. The show recorded just fine but would not play until I changed the show name manually on the mysql cli.
Hey Rob,
One thing that I never tried was playing the defective title in mythfrontend. Would be interested to know if it could successfully play the file. Guess it all depends whether it forms it mysql queries based on title alone (never really used mythfrontend, so I'm not sure what it does). Like I said, mysql could not look up the recording based on title, so this is probably one thing that the libcmyth addon will struggle with. Sounds like a mythtv issue to me.... but wanted tsp to confirm/deny!
2012-03-16, 20:06
(2012-03-16, 09:27)Jimmer Wrote: [ -> ](2012-03-16, 01:44)robweber Wrote: [ -> ]Just wanted to add that I had this issue as well. Mine was a different show but when it was scheduled via the cmyth addon it inserted a '\' to escape the apostrophe and this showed in the title from that point on. The show recorded just fine but would not play until I changed the show name manually on the mysql cli.
Hey Rob,
That's a good point, I didn't try that either. I guess I was more concerned about where the slash came from originally. I've never seen mythtv insert something like that on it's own so I'm guessing the addon did it when trying to escape characters when I set the timer. If it is a self-introduced problem I would imagine this will happen more often as people use only the addon to schedule and play recordings.
2012-03-17, 11:59
(2012-03-16, 20:06)robweber Wrote: [ -> ](2012-03-16, 09:27)Jimmer Wrote: [ -> ](2012-03-16, 01:44)robweber Wrote: [ -> ]Just wanted to add that I had this issue as well. Mine was a different show but when it was scheduled via the cmyth addon it inserted a '\' to escape the apostrophe and this showed in the title from that point on. The show recorded just fine but would not play until I changed the show name manually on the mysql cli.
Hey Rob,
I guess one way to test this would be to find a program (that's repeated) in the schedule with an apostrophe in the title. Schedule one showing to record via xbmc and another via mythweb and see what happens..... I'll go scan the schedules and see if anything likely looking is coming up......
2012-03-18, 23:37
'Kr0nZ: Thanks for reporting the bugs. Most of them are just not implemented yet. Not sure if the crash at exit is due to my or dushmaniacs code?
simonind: Thanks for pointing the xp problem out. Will look into it.
pyrodex: libcmyth does not (yet) support v0.25. They changed the mythtv backend protocol so libcmyth will have to be updated (mostly related to how the program info is encoded, so playback will still work).
Jimmer: I suspect that the extra backslash is due to the strings being escaped twice when communicating with the SQL server. Will try to fix it in the libcmyth code.
