2012-10-10, 23:55
(2012-10-10, 23:41)janbar Wrote: [ -> ]I am trying to simplify the process using "make" style like others pvr add-ons. But using Xcode project is also a way.(2012-09-30, 00:46)janbar Wrote: [ -> ]@pgjensen
Right, sometime playback stop. I saw logs and some errors in stream are reported by mythbackend. Then It skip frames and ring buffer is empty for a short period. Probably we need to add a delay when buffer is empty before return and finally stop playback because no stream... I take note.
When tune is not very good, lot of frames are skipped. With a fast channel switch the "timeshift" is short and when buffer cannot to be filled the playback stop.
(2012-10-10, 19:49)cfetzer Wrote: [ -> ]@jskube - The GetPreviewIconPath message doesn't mean that the file is downloaded, it means the addon requests the path to the cached image. The images should be downloaded only once.Hi, cfetzer
However we're now suspending the image download during playback. When you stopped the playback, the remaining images should be loaded and displayed. I'll disable the message soon if we know that the cache is working.
For osx builds we need to create the xcode project and replace all .at() calls by propper find + [] calls since those are cpp11.
All seem good for the addon. It is very stable and timeout work great when network pipe with the backend is congested. Program beak works without issues (since 1 days non-stop).
I just made build for OSX and it works greats without any change (for the moment). But now i must to update packaging for user like update Makefile and adding link for dependencies boost libs and mysqlcient lib.
Nota: for OSX leopard 10.6.8 - Also i build it without use Xcode project.
