2016-04-19, 01:39
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
2016-09-09, 18:50
One qestion from beginner:
There is strm file, which is added to the media library and properly scraped with actual info.
when playback is initiated from playlist I am able to catch infoLabel('ListItem.DBTYPE ') during :
and then search for any information needed with json-rpc
but
when strm file playback is initiated from widgets, I am not able find any suitable infoLabel from which would
contain information leading to library database. There is a lot of properties like
but any of them does not indicate which item was selected
Probably I miss something very basic
Thank you very much for any clarification.
class MyPlayer(xbmc.Player):
def __init__(self, *args):
pokus = xbmc.getInfoLabel('ListItem.DBID ')
but
xbmc.getInfoLabel('Window(Home).Property(RecentEpisode.1.Title)')
2016-09-10, 09:02
hi Zbyna,
maybe you should use : Library Data Provider
http://forum.kodi.tv/showthread.php?tid=210063
2016-09-10, 14:29
Hi gates,
thanks for great tip.
I refactored my issue again yesterday and figured out possibility
to include location of strm file in this file itself as parameter.
Then it is possible to obtain strm file name+path fromduring stream playback and mine needed information from video library.
title
VideoPlayer.Title
2018-04-06, 19:10
Is there a more recent support thread than this one marked as [Frodo]?
What I'm wondering is if any progress has been made to allow recognition of video nodes with this widget set.
I have set up a custom node to include only documentary films, which KODI sees as movies and I would like this widget to only return results from that node. So effectively showing only new documentaries instead of all new movies.
Cheers and thanks for such a great widget set. I use it with the Xonfluence skin.
Robert
Robert
2018-04-08, 09:18
(2018-04-06, 19:10)WildPhydeaux Wrote: [ -> ]Is there a more recent support thread than this one marked as [Frodo]?
Robert
You should be able to do pretty much everything that you want with a smart playlist.
2018-04-08, 17:58
(2018-04-08, 09:18)jurialmunkey Wrote: [ -> ]You should be able to do pretty much everything that you want with a smart playlist.
Correct, I have a smart playlists created for my Documentary stuff which excludes "normal" movies and for Movies which excludes Documentary films. That part works fine. The new video node I created created is for the Documentaries, which are all located in a specified folder. And the default Movies node is limited to another specified folder.
My question is if the skin widgets can now recognize and differentiate between different nodes. So for instance right now when set to show Recently Added Movies its actually showing the most recently added items from both the Movies and the Documentaries video nodes.
Now, I understand that I can just use separate smart playlists for each Movies and Documentaries that effectively show just the most recent x-number of items for each, but these are significantly slower to generate and refresh compared to the skin widgets. And they don't display nicely - well, actually the Movies one does, but the TV Episodes doesn't (thumbnail is ok, but label isn't).
Cheers,
Robert
2020-02-06, 21:42
Update to service.skin.widgets
I have updated service.skin.widgets for Kodi 19 Matrix. The updated version is in the python3 branch of my forked repo and can be reached here:
service.skin.widgets python3
scott s.
scott s.
