(2012-10-30, 19:34)Martijn Wrote: [ -> ]0.0.8
- Added a lot of new labels
- Use foo.Art(bar) for artwork [old labels are still there so nothing will break]
See code for labelnaming. Should be pretty easy to read which ones are there.
@Hitcher
SkinWidgets_RecentItems 'true/false' was already there.
Will update wiki if everything works[/php]
All working my end, thanks.
Art(fanart) for movies is missing.
How to access logo.png for recent tvshow?
"Path" contains file name. "File" misses the show name folder. And "Title" removes some characters like dots (punt).
Still trying to get resolution cases to work ...
added resolution tag :
PHP Code:
<property name="Resolution">$INFO[Window(Home).Property(LatestMovie.1.Resolution)]</property>
now how we can define which case should show for a specific resolution? For example 720p ...
PHP Code:
$INFO[Container(8000).ListItem.Property(Resolution,720)]
Thanx in advance ...
LatestMovie > RecentMovie
0.0.10
- Synced with Frodo style of using foo.Art(bar)
- Got rid of all ugly hacks since we can now use clearlogo, clearart, discart, banners, landscape native in XBMC. You can remove all the local files now since we will use the HTTP link
Current version:
How to integrate:
Wiki page
(2012-11-05, 21:17)Martijn Wrote: [ -> ]0.0.10
What does that mean exactly? I want local files.
(2012-11-05, 21:23)`Black Wrote: [ -> ] (2012-11-05, 21:17)Martijn Wrote: [ -> ]0.0.10
You will get ListItem.Art(clearlogo) everywhere available in your library.
Previous is was just a dirty hack with combining "path+logo.png". Now AD will directly push the URL to your library. The mayor advantage is that your disks won't spin up anymore for checking artwork.
imo this is the way to go
Would be nice if artwork downloader could check if a file is available locally and use that instead of the default http one.
And landscape for episodes?
(2012-11-05, 22:29)Hitcher Wrote: [ -> ]And landscape for episodes?
you mean the landscape.jpg?
