(2012-10-13, 00:32)`Black Wrote: [ -> ]Seems that it stopped working with the nightly from Oct 10.
that could well be the issue... i'm running oct 9.
That's clear but the title property doesn't work anymore.
(2012-10-13, 14:36)`Black Wrote: [ -> ]That's clear but the title property doesn't work anymore.
will do some tests later on and see what's going on
(2012-10-13, 14:37)Martijn Wrote: [ -> ] (2012-10-13, 14:36)`Black Wrote: [ -> ]That's clear but the title property doesn't work anymore.
Just tested and all seems to function again using latest master
@all skinners
Question:
currently RandomArtist.LibraryPath just gives you the path without ActivateWindow()
So what do you want?
a. keep it like it is now and you specify ActivateWindow() in skin
b. script provides the whole RandomArtist.LibraryPath=ActivateWindow(music,musicdb:/2/.... )
b could mean that you can't specify the -> ActivateWindow(window[,dir,return])
Anyone can confirm ?
<label>$INFO[Window(Home).Property(RecommendedAlbum.1.Title)]</label>
Album name is not showing up.
<label2>$INFO[Window(Home).Property(RecommendedAlbum.1.Artist)]</label2>
Artist name works fine.
Using latest nightly and version 0.0.3
Thanx
(2012-10-12, 18:59)Martijn Wrote: [ -> ] (2012-10-12, 18:06)Hack_kid Wrote: [ -> ]so i'm the only one with the script failing on startup heres a snippit from the log
thx
add this after the other imports
thanks man i'll give it a try, so just add this on top of v0.0.3
for the record that was the first thing i thought of but i was like "no......way to easy"
v0.0.4
- Fix missing import
- Fix typo in clearproperty
- Add SetProperty(SkinWidgets_RandomItems_Update,true) to trigger update on all randomitems
