I had a quick look at your package, but I think something is wrong with the textures. I'll check again during the weekend.
Can you tell me what the "Manage View" and this dialog shown on the screenshot above are for?
Hi Paradix,
The textures are same as yours. I've just added some png image in the media directory.
"Manage View" allows to enable/disable view (for the new view selector).
I have to rename the view for more understanding.
The screenshot above shows the view selector.
It displays the available view for the current container.
I let the button "View: <view_name>" in order to check if all the view were OK.
It will be replace by the new function.
First Jarvis version (3.4.0) committed to the Kodi repository.
Tests and bug reports are welcome as soon as the update is available.
Hi Paradix, congrats for your first Jarvis release.
I just tested from github and everything is ok, but if i test from official repos, all textures are lost. Skin is usable but lines, bars, buttons backgrounds are lost.
If i replace with github, all goes perfect again, but kodi alert me that an update is available 3.4 instead 33.5
any idea what is happening ,/
Hi paradix, first thank you for keeping this skin alive.
I'm experiencing the same problems as ktpires. Everything is translucent. No opacity at all. I'm on jarvis rc1 under windows 8.1.
Makes it really hard to read menus.
I made screenshots.
Is there a work around?
thx in advance, regards
Thanx for reporting the problem. I'll check it out right away. Didn't experience anything like that with my build.
For now please use this version -->
http://1drv.ms/1Ux3XHd
You might need to uninstall the repo version first or just copy over the ./media directory to your skin.
Thx, I will give it a try.
Ah, lovely, fixed one works. I uninstalled it first - installed the version from onedrive. I will post it if I find another issue. thx paradix.
It works perfectly now
The reason is found. Need to make some changes and will commit new version soon. Sorry for the inconvenience.
Fixed version 3.4.1 soon available through official repo.
Paradix. A small request. Could you add a HEVC and/or x265 logo?
(2016-02-12, 15:16)FriedLocust Wrote: [ -> ]Paradix. A small request. Could you add a HEVC and/or x265 logo?
Hey bud, I know you were addressing Paradix and all...
Here are some quick 'n dirty ones I whipped up using the base H264 flags from Cirrus. Unzip this archive to your skin.cirrus.extended directory. Hope it helps.
https://drive.google.com/file/d/0BwDWRn5...sp=sharing
