2013-02-28, 19:29
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
2013-03-02, 05:47
I have some modification/correction suggestions for the Advanced Launcher support.
Since Frodo ListItem.Premiered parameter do not display the year correctly. Advanced Launcher manage date under this form : YYYY. But the ListItem.Premiered return it into this form : MM/DD/AAAA. To fix this you have to replace all the ListItem.Premiered by ListItem.Year into the following xml files :
- Custom_GamesInfo_1122.xml
- ViewsGamesFanart.xml
- ViewsGamesFanartSquare.xml
- ViewsGamesFanartWide.xml
- ViewsGamesLogoRightlist.xml
- ViewsGamesRightlist.xml
- ViewsGamesRightlistLandscape.xml
- ViewsGamesRightlistSquare.xml
2013-03-02, 06:17
Trailers support for Advanced Launcher. Advanced Launcher support trailers MP4 files since several versions now. So... I think it is not necessary that the trailer file path continue to be completly generated and supported by the skin. So i'm suggesting to replace :
code into custom_PopUpMenu_Games1123.xml file by :
The trailer mp4 file is defined by the custom path (for each launcher and items) and the launcher or item filename. For example if the custom path is /Emulation/playstation/extra and the item filename is sonic.zip then the trailer path will be /Emulation/playstation/extra/zelda.mp4
<onclick>XBMC.PlayMedia($INFO[Skin.String(Menu_GameCustom1_Label)]/$INFO[ListItem.label]/trailer.mp4,1)</onclick>
<onclick>XBMC.PlayMedia($INFO[Skin.String(Menu_GameCustom1_Label)]/$INFO[ListItem.trailer],1)</onclick>
2013-03-02, 13:49
Hi Angelscry. Thanx for the input on the advanced launcher.
I'll put it on the TODO list, and have it done with the next updates.
2013-03-03, 15:43
(2013-03-02, 13:49)paradix Wrote: [ -> ]Hi Angelscry. Thanx for the input on the advanced launcher.Thank you very much. I have another suggestion. Since version 1.13.0 of Advanced Launcher, the extra-fanarts folder path could be mamanged by Advanced Launcher. There still no dedicated XBMC listitem entry for that, so Advanced Launcher use the listitem.director value to pass the extra-fanarts folder path.
To let Advanced Launcher manage extra-fanarts path instead of thr Cirrus Extended skin you just have to replace :
<imagepath background="true">$INFO[Skin.String(Menu_GameCustom1_Label)]/$INFO[ListItem.label]/extrathumb</imagepath>
by
<imagepath background="true">$INFO[ListItem.Director]</imagepath>
2013-03-03, 15:59
(2013-03-02, 06:17)Angelscry Wrote: [ -> ]Trailers support for Advanced Launcher. Advanced Launcher support trailers MP4 files since several versions now. So... I think it is not necessary that the trailer file path continue to be completly generated and supported by the skin. So i'm suggesting to replace :
Code:<onclick>XBMC.PlayMedia($INFO[Skin.String(Menu_GameCustom1_Label)]/$INFO[ListItem.label]/trailer.mp4,1)</onclick>
Code:<onclick>XBMC.PlayMedia($INFO[Skin.String(Menu_GameCustom1_Label)]/$INFO[ListItem.trailer],1)</onclick>
Could also be replaced simply by :
<onclick>XBMC.PlayMedia($INFO[ListItem.trailer],1)</onclick>
(2013-03-03, 15:59)Angelscry Wrote: [ -> ](2013-03-02, 06:17)Angelscry Wrote: [ -> ]Trailers support for Advanced Launcher. Advanced Launcher support trailers MP4 files since several versions now. So... I think it is not necessary that the trailer file path continue to be completly generated and supported by the skin. So i'm suggesting to replace :
The trailer mp4 file is defined by the custom path (for each launcher and items) and the launcher or item filename. For example if the custom path is /Emulation/playstation/extra and the item filename is sonic.zip then the trailer path will be /Emulation/playstation/extra/zelda.mp4Code:<onclick>XBMC.PlayMedia($INFO[Skin.String(Menu_GameCustom1_Label)]/$INFO[ListItem.label]/trailer.mp4,1)</onclick>
Code:<onclick>XBMC.PlayMedia($INFO[ListItem.trailer],1)</onclick>
But in all cases, when you select the Fullscreen option to play the trailer, the video is playing into background. There is a way to force it to play foreground?
2013-03-04, 10:32
Thnx to YoHan all reported issues and enhancements around the Advanced Launcher has been fixed.
I'll look into the issue with the full screen trailer.
2013-03-04, 12:32
hello i found a problem last night, in files view on the right menu, we have "assemble" but not "stack" so if i have movies with -CD1 -Cd2 i see 2 files and not only 1 .. i had to use the default skin then active "stack" then go back to Cirrus, after all was good.. but it'll be better to have it on Cirrus ..
2013-03-05, 09:35
(2013-03-04, 12:32)scool Wrote: [ -> ]hello i found a problem last night, in files view on the right menu, we have "assemble" but not "stack" so if i have movies with -CD1 -Cd2 i see 2 files and not only 1 .. i had to use the default skin then active "stack" then go back to Cirrus, after all was good.. but it'll be better to have it on Cirrus ..
Could you maybe attach a screenshot showing the problem, because based on your description I can't find the problem.
2013-03-05, 16:13
2013-03-06, 17:57
Hi
First of all thx for porting CE on Frodo. I really love this skin.
2 suggestions:
- Home.xml
XBMC.RunScript(script.randomandlastitems,type=Movie,unwatched=True,limit=10,method=Last,playlist=$INFO[Skin.String(Menu_Custom4_Path)],menu=Menu1)</onload>
Can you remove unwatched=True. Skin Widget allow to chose to see all the recently added or only unwatched.
I prefer have all the recently added and not only unwatched. I don't like having empty entry in the widget.
- Is it possible to add (clear) case on movie widget and logo, banner or clearart for TV show widget. It can be a great addition.
Keep up the good work.
2 suggestions:
- Home.xml
2013-03-07, 21:39
Love the skin.
1 little bug I ran into is on the TV Shows Logo Slide it shows Logo Missing for the back Icon? All the other ones show the folder with the arrow going back but this one shows Missing Logo? Any ideas?
Also is there anyway on the Fanart 2 Setting in Movies to have 2 diffrent fanarts? I cant seem to get it to do that. And also on the same one I have show disk is there anyway to have it open the case rather than slide up the top? Just so you can see the full disk?
2013-03-07, 23:11
(2013-03-05, 16:13)scool Wrote: [ -> ]yep sorry i did an error it's not right menu, but LEFT !! was tired... lol .
i put a red line at bottom of the missing option.
hope it'll help
Chris
This problem should be solved with one of the next versions in the passion repo.
The Git version already includes the fix.
2013-03-07, 23:40
(2013-03-06, 17:57)GuiZ Wrote: [ -> ]Hi
2 suggestions:
- Home.xml
I'll consider your suggestions, but adding extra option would require more extensive configuration, and the skin already has a expansive settings menu. We will see
(2013-03-07, 21:39)mcjknell Wrote: [ -> ]Love the skin.
At this point It is developed this way. There is not "folder with arrow" texture that would be acting like a logo. Maybe there should be thought about a way to make it nicer?
(2013-03-07, 21:39)mcjknell Wrote: [ -> ]Also is there anyway on the Fanart 2 Setting in Movies to have 2 diffrent fanarts? I cant seem to get it to do that. And also on the same one I have show disk is there anyway to have it open the case rather than slide up the top? Just so you can see the full disk?1) There is no option to configure more than one fanart for any view. You can always download extrafanart and enable them in the skin settings. Than they will show up randomly after each other.
2) No there is only this one slide animation for the discart.
2013-03-08, 00:29
Thank you for the quick reply. What about creating a Logo or something that looks just like the others icons Movies and other views that shows the back arrow? Just to keep everything Uniform?
Just so when your scrolling through it doesnt pop up with missing logo.
Thanks again for your hard work in this Skin its by far the best.
