2014-10-07, 22:14
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
2014-10-07, 23:19
(2014-10-07, 22:14)Dixon Butz Wrote: [ -> ]Would turning on debug logging in Kodi help?I think I found this bug. Try plugin.audio.pandoraslim-0.4.1.zip
If still broken, post a debug log. I'll see what I can do.
2014-10-08, 00:38
0.4.1 is up. Please test
Defaults to streaming only with no disk space usage
Caching / Save to Library optional
2014-10-08, 12:24
Did some testing on 0.3.5 My problems seemed to be fixed. Now bumped Kodi to 14A4 and PandoraSlim to 0.4.1 so far so good.
scott s.
scott s.
2014-10-08, 15:06
Just wanted to say, "Thanks!"
2014-10-08, 23:02
(2014-10-08, 00:38)gominoa Wrote: [ -> ]0.4.1 is up. Please test
Good idea, does streaming skip the ads?
Issues still pending,
kodi freezes on exit
context menu need more sources
back button
Dude i think it's almost ready to release
2014-10-09, 00:21
0.4.1 on Kodi 14A4 (Win7 portable mode) doesn't seem to cache or save tracks any more. Reverted to 0.3.5 and that works.
scott s.
scott s.
2014-10-09, 00:36
2014-10-09, 02:25
(2014-10-09, 00:21)scott967 Wrote: [ -> ]0.4.1 on Kodi 14A4 (Win7 portable mode) doesn't seem to cache or save tracks any more. Reverted to 0.3.5 and that works.
scott s.
It's working fine on my Win7, maybe just with the portable mode... Silly question but did you adjust the new settings menu?
2014-10-09, 06:57
(2014-10-08, 23:02)wpbpete Wrote: [ -> ]Good idea, does streaming skip the ads?Nope. Just hands it off to XBMC to play. No way to know it's an ad at this point
(2014-10-08, 23:02)wpbpete Wrote: [ -> ]kodi freezes on exitI'm dicking with loop/thread timing, see if I can fix this.
(2014-10-08, 23:02)wpbpete Wrote: [ -> ]context menu need more sourcesPlease post a screenshot. Mine let's me pick an image from anywhere. Code:
img = xbmcgui.Dialog().browseSingle(2, 'Select Thumb', 'files', useThumbs = True)
(2014-10-08, 23:02)wpbpete Wrote: [ -> ]back buttonDon't think I can do anything. Back handling is an internal XBMC/skin thing
(2014-10-09, 02:25)wpbpete Wrote: [ -> ]Do check settings. I moved them around/renamed. It re-defaults to no saving.(2014-10-09, 00:21)scott967 Wrote: [ -> ]0.4.1 on Kodi 14A4 (Win7 portable mode) doesn't seem to cache or save tracks any more. Reverted to 0.3.5 and that works.It's working fine on my Win7, maybe just with the portable mode... Silly question but did you adjust the new settings menu?
2014-10-09, 11:16
(2014-10-09, 06:57)gominoa Wrote: [ -> ]Do check settings. I moved them around/renamed. It re-defaults to no saving.
OK I blew it away and reinstalled and see now the settings defaulted to "stream only" so changing that fixed it. I can't remember now if I had looked at the previous settings but I know it was set to add to library in 0.3.5 so maybe in the update from 0.3.5 to 0.4.1 (I have your repo installed and auto-update so it updated itself) settings.xml didn't get updated correctly, or maybe it did and I just missed it.
edit: I see now it is in the settings as "mode" but before it was "save" so I missed it (admit I was editing settings.xml directly instead of using the UI while testing).
scott s.
2014-10-09, 13:59
Config for the Newbies out there for an Instant Saved Music Library with Album Art and Metadata:
Pandora Slim Config:
Track handling --> Save to Library
Skip Ads --> Tick
XBMC: (Raspberry Pi) folders
Music ---> Files ---> Select Music ---> Context © ---> Edit Source ---> Browse ---> Home Folder ---> .xbmc ---> userdata/addon_data/plugin.audio.pandoraslim.Pandora/
Settings ---> Music ---> Library ---> Override songs tags with Online information ---> Tick (Uses MediaBrainz metadata already in the files and folders)
Music ---> Update Library
Done. One Happy camper !!
Thanks gominoa :-)
Skip Ads --> Tick
Thanks gominoa :-)
2014-10-09, 23:41
I left Pandora Slim playing for 18 hours straight with no interruptions. Just stopped it with 846 files created. Also, I am saving to a folder in my Dropbox, so no matter where I listen (bedroom, livingroom, work) the songs get archived.
2014-10-09, 23:56
(2014-10-09, 23:41)locoguano Wrote: [ -> ]I left Pandora Slim playing for 18 hours straight with no interruptions. Just stopped it with 846 files created.Nice! Glad to hear it!
(2014-10-09, 23:41)locoguano Wrote: [ -> ]Any idea how often the links to these songs get changed by Pandora?If you're talking about streaming only, they seem to expire an hour or so after requested.
But the filenames in the cache folder are Pandora's songID and I haven't seen one change.
(2014-10-09, 23:41)locoguano Wrote: [ -> ]Also, I am saving to a folder in my DropboxAwesome idea. If Pandora Slim finds the song in your library it will play from there instead of redownloading
2014-10-10, 00:01
(2014-10-09, 06:57)gominoa Wrote: [ -> ]This is my kodi box, it's only seeing an addon, no C drive, home folder etc.. My Gotham box sees one of my source drives and a couple of file sources where do I find that code?(2014-10-08, 23:02)wpbpete Wrote: [ -> ]context menu need more sourcesPlease post a screenshot. Mine let's me pick an image from anywhere. Code:
context menu>>>select thumb
(2014-10-09, 23:56)gominoa Wrote: [ -> ](2014-10-09, 23:41)locoguano Wrote: [ -> ]I left Pandora Slim playing for 18 hours straight with no interruptions. Just stopped it with 846 files created.Nice! Glad to hear it!
Awesome!!! gominoa, front page info
