(2014-11-16, 01:04)Arse4life Wrote: [ -> ]After update I could not go into the addon.
Got a log?
(2014-11-16, 01:12)wgstarks Wrote: [ -> ]How do I get Pandoki to launch Artist Slideshow? It would be nice to get artist fanart
I don't know about Artist Slideshow, but if you're using "Save to library" in Pandoki you should get fanart automatically
after XBMC rescans the library
(2014-11-16, 01:15)gominoa Wrote: [ -> ] (2014-11-16, 01:04)Arse4life Wrote: [ -> ]After update I could not go into the addon.
Got a log?
I was going to enable debugging but I was able to get into Pandoki after I rebooted Xbmc. It's working great now.
(2014-11-16, 01:17)Arse4life Wrote: [ -> ]I was going to enable debugging but I was able to get into Pandoki after I rebooted Xbmc. It's working great now.
Were you listening while you did the update? It may have been still running the old version in the background. Press 'stop' on the playlist to exit Pandoki then reopen it to get new version.
I stopped it prior to update. It's working great now. Not sure what happened after update might've still been running in background somehow.
How do I do the thumbs up/down? Thanks for this addon! It's quality and close to being perfect!
(2014-11-16, 01:15)gominoa Wrote: [ -> ] (2014-11-16, 01:12)wgstarks Wrote: [ -> ]How do I get Pandoki to launch Artist Slideshow? It would be nice to get artist fanart
I don't know about Artist Slideshow, but if you're using "Save to library" in Pandoki you should get fanart automatically after XBMC rescans the library
Yes. If I play from the library in Party Mode or something like that I get fanart, but I was hoping to be able to get it running Pandoki since most of the artists being played probably already have fanart in my database.
When Pandoki is running this is all that is displayed-
The art is from The Hollies which was first in the queue, but obviously that's not what's being played. Just always displays the first track.
(2014-11-16, 01:26)Arse4life Wrote: [ -> ]How do I do the thumbs up/down?
Press 'i' on a song in the playlist to open 'Song information' then adjust the number of stars.
See first post. Ive updated it a bit.
(2014-11-16, 01:46)wgstarks Wrote: [ -> ]The art is from The Hollies which was first in the queue, but obviously that's not what's being played. Just always displays the first track.
Can you move the cursor up/down? My fanart always follows whatever song is highlighted in the play list
Gominoa, if I am playing a song with no rating and if I skip it without rating it that's not giving it a thumbs down, just a skip correct?
(2014-11-16, 02:09)Arse4life Wrote: [ -> ]Gominoa, if I am playing a song with no rating and if I skip it without rating it that's not giving it a thumbs down, just a skip correct?
Correct. It won't send anything to Pandora
(2014-11-16, 01:54)gominoa Wrote: [ -> ]Can you move the cursor up/down? My fanart always follows whatever song is highlighted in the play list
Sure. And the art will shift if I move the cursor. I was just hoping you might look at adding a call to
Artist Slideshow to display art for the currently playing track. Maybe this is already supported and I just don't have mine set right. Not sure. But if not, please consider this a feature request.
Starting to get a grip of this addon. Brilliant addon!
Planning on adding a background to this addon to give it a cool look? I see my personal background. Not a big deal.
Also, the cool thing about this is when I'm playing a song and leave the station and go back into the same station the song and list doesn't get interrupted. Great attention to detail there!
(2014-11-16, 02:23)Arse4life Wrote: [ -> ]... leave the station and go back into the same station the song and list doesn't get interrupted.
Also, side note. You can queue up songs from your own library and the station will resume after playing them.
(2014-11-16, 05:05)gominoa Wrote: [ -> ] (2014-11-16, 04:45)Arse4life Wrote: [ -> ]Tried adding a new station and got a script fail.
Fixed! plugin.audio.pandoki-0.7.1.zip Thanks!
Wow gominoa that was fast! Fixed and working well!
Playing around with this a bit and I love the concept. Allows for a lot more freedom than the Pandora addon I've been using for a long time now. I have been able to add stations and rename them but I can't really do anything else. I use the Eminence skin and it doesn't have any star ratings to access these other options. The star thing is potentially confusing and won't work in all skins. Is it possible to make all this work from context menus? I know it may be a lot of work, just my opinion. This is a great addon and I can't wait to see what you do with it. Also, the add to library functions are amazing. This could be the only music addon I ever need again.
