2016-02-07, 16:33
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
2016-02-07, 16:37
Quote:I edited my previous post for the template. Can help me to reproduce it.What ?
My view ? or my problem ? My god you are french ? it s amazing !
2016-02-07, 16:56
(2016-02-07, 16:37)Reynald Wrote: [ -> ]Both Are you sure you reproduced the bug before sending me the log, I can't find any Dialog info init in ?Quote:I edited my previous post for the template. Can help me to reproduce it.What ?
Yep, I'm french, PM me if you want ... Maybe easier.
2016-02-07, 17:12
i sent mp
2016-02-07, 18:47
(2016-02-07, 17:12)Reynald Wrote: [ -> ]i sent mpSo for information, seems latest git version fixes it.
2016-02-07, 19:22
Yes all is fixed , thx for your amazing work /
I have a suggestion. Is it possible to add the function to hide the submenu when we use the main menu medium? and it appears with row up? .
http://prntscr.com/a07m85
as we could have a big fan art for a nice home menu.
2016-02-07, 19:48
(2016-02-07, 19:22)Reynald Wrote: [ -> ]Yes all is fixed , thx for your amazing work /
You can customize Home views like any library ones are. The selection method is just a bit different. Ex :
For your films item, got to skins settings > Edit Home menu ...
So for Movies (Films)… > Select viewtype > Libraries.
Those viewtypes are customizable or you can create new ones as you wish in Designer (Libraries is one). Just select them as discribed previously
Check this
https://plus.google.com/1023314611843415...yJPYiRoeJZ
2016-02-07, 20:10
wow !!!!!!!!!! This is exactly what I want to do! I'm impressed, how much time you spent to create this skin! . You thought of everything! This is the most amazing skin that exists. this skin can replaced Confluence!!
2016-02-07, 20:21
(2016-02-07, 20:10)Reynald Wrote: [ -> ]wow !!!!!!!!!! This is exactly what I want to do! I'm impressed, how much time you spent to create this skin! . You thought of everything! This is the most amazing skin that exists. this skin can replaced Confluence!!
Thx,
Erm... 1year and a half ?
I tried to think to what can be useful and interresting from different users point of view. Not everything but at least what is somehow possible. Also, got nice ideas and requests here that improved it a lot
2016-02-07, 20:48
Hi Jayz2K,
did you say Designer V2 is not working yet because of skin.helper needing an update? But I am already using Designer V2 (Designer V1 has not been working anymore since a few days ago, so I had to switch to V2). Perhaps it's because I am already running Kodi 17 (Krypton) nightly? However, I have some issues with the Designer:
1. EPG-View (LiveTV): Hiding the Menu-bar does not work. You can select "hidden" or "idle fade", but the menu bar stays visible all the time. That's annoying because you can hide it in every other view type but not in EPG-view. And it keeps covering the nice icons of my channel list on the left side (I have vertical view with sidebar on the left).
2. "Dialoge Slide Typ" always stays at "over", even if you select "push".
3. Any chance to have an option to select the position of the menu bar in fullscreen video? As I just said I am using vertical menu with the sidebar on the left side, but in fullscreen video I would rather like to have it at the bottom.
2016-02-07, 21:03
@fantasticn :
Yes, Designer V2 requires latest skin.helper script not yet on the official repo. If you know how to upgrade it, then you're fine using V2.
(If you're using V2, please let me know how it goes and if you're fine with it, I've not been able to test everything. I wanted to launch a test period when it will be available)
Designer V1 was broken for a day, I messed up with parameters but is now fixed on git.
Will check the issue with epg.
For dialog slide, is it also for epg or every windows ?
For the menubar, I already added it for Fullscreen. In skin settings > general, toggle "Keep OSD controls sticking to bottom".
EDIT : Big Fat warning using KRYPTON. There's heavy changes in it, mostly gathering windows. I can't say what can happen using this until I apply changes to my code. Meaning if I don't get your errors now on 16, I won't be able to help you until I start working on it ... not so soon.
2016-02-07, 21:56
Hi Jayz2K,
dialoge slide cannot be set in all views in Designer V2.
As to Krypton I am totally fine. Everything seemes to be working just perfectly (besides the aformentioned small issues which I suppose are not Kodi related). I have been upgrading to Krypton because I am using three NVidia Shield TVs at my place and I want to try out the passthrough option which will not become available for Jarvis anymore.
2016-02-07, 22:39
@fantasticn :
Everything should be fine now on git.
Can you please test and review ?
Thx
Also settings > general, toggle "Keep OSD controls sticking to bottom" ... is it what you were looking for ?
Cheers
Thx
Cheers
2016-02-08, 09:47
Ah, perfect. Just chcked it and everything seems to work fine. Thank you very much!
Now I am absolutely fine with my configuration. The only thing would be to think of a way to implement my beautiful cleararts, logos and CDarts for movies, tv-shows and music. Currently I can only set them alternatively as bloc 3 art. But this means losing any other graphics diplayed (e.g. image or fanart). Also as bloc 3 graphic those images are displayed rather big (e.g. logos). And I think cleararts is something for the OSD. I know I could play around with custom views, but that is something I have been trying to find a way around. It is much more complicated than handling the Designer :-)
2016-02-08, 09:59
(2016-02-08, 09:47)fantasticn Wrote: [ -> ]Ah, perfect. Just chcked it and everything seems to work fine. Thank you very much!
Have you checked this for Bloc 4 Fallback arts ?
http://forum.kodi.tv/showthread.php?tid=...pid2235068
An option allows to set Bloc 4 to show Fallback only so works as Bloc 3 allowing to show a 2nd arts ...
It's already available in the latest build you downloaded.
