Well, latest huge update.
KOver 0.80.2 is available on git.
This signs the end of Designer V1 support (RIP) and Designer V2 final official launch (except bugs fixings).
Major speed improvement in sizing / moving (reacts instantly).
Now I'm done for the WE. Let's track bugs before stable and repo push
Next step is 1.0.0
What about Textures.xbt? Could help with menu speed...
(2016-02-13, 00:35)Jayz2K Wrote: [ -> ]Well, latest huge update.
Next step is 1.0.0
Well done ! it 's great work that you give we
Thx
There is a problem, the Builder no longer works. All my views (in the builder are inert.) No action possible.
Edit : I made several test: Kover completely delete and reinstall: Some things to break the builder and a few menu options.
Kodi delete and remove Gui folder: reinstall kodi, install Kover 0.7repo: Works well.
Update 0.7 => 0.8 (builder V2 final): no work. Some things is broke.
As primary rule, please always provide a debug log. This can avoid me to reproduce the bug from scratch.
Found it. Had a file locked that didn't pass through git. Fixed.
Thx for reporting.
(2016-02-13, 01:27)Shogun Wrote: [ -> ]What about Textures.xbt? Could help with menu speed...
Didn't investigate this way since it's automatically done at repo push. Have you tried it on your side ?
@blustein + kokonutcreme :
Will check to add 3 more custom lists. Hope it doesn't make Libraries opening to slow down too much.
Also I have to try to fix this xmls overriding issue at skin Update. Marcel developped a feature for that in skin.helper but have to find a good way to proceed.
Bug in Designer V2 additional processes detected.
One more update. Sorry.
Fixed on git.
EDIT : This bug can lead views breakage so is not optional.
Quote:As primary rule, please always provide a debug log. This can avoid me to reproduce the bug from scratch.
Thx for reporting.
Sorry , thx all is good now
I play with Custom_List today ! and it s fun !
(2016-02-13, 17:31)Reynald Wrote: [ -> ]I play with Custom_List today ! and it s fun !
Man I need to learn and understand this shit so I can play around as well
Thx for posting this in the custom list thread Reynald
(2016-02-13, 12:16)Jayz2K Wrote: [ -> ]@blustein + kokonutcreme :
As an alternative Jay, would you consider changing the default properties of fixed list or wide list to only display text and not poster art? That would save using one of the 3 custom lists and you would just need to add a further two and not three, capping the custom lists to 5 if it causes performance issues with opening libraries.
Hmm...Import and Export buttons do not seem to work for me anymore on all my media player Anybody experiencing the same issue?
Have you updated with the latest version Github?
Yes I did. And after that I cannot trigger Import and Export buttons anymore.
