2015-08-28, 17:10
(2015-08-23, 02:28)bitterkitten Wrote: [ -> ]I need this skin in my life ASAP!! It's beautiful and I can't wait for the release.
HAHAHAHAHAHAHA +1!!!!!!!!!!!!
(2015-08-28, 18:48)bitterkitten Wrote: [ -> ]I tried to install KOver by the normal way but got a failed to meet dependencies notification so I extracted the zip directly into the addons folder. After a restart, I was able to run it! Steep learning curve (that's usually the sign of a great skin) but it looks amazing. The only issue I've run across is trying to figure out how to display fanart on the homescreen. I love having the ability to create my own custom library views! I don't think my anatomy homework will get done this weekend thanks to this skin If I notice any bugs, I'll post a log file. Thanks!
(2015-08-28, 18:58)Jayz2K Wrote: [ -> ](2015-08-28, 18:48)bitterkitten Wrote: [ -> ]I tried to install KOver by the normal way but got a failed to meet dependencies notification so I extracted the zip directly into the addons folder. After a restart, I was able to run it! Steep learning curve (that's usually the sign of a great skin) but it looks amazing. The only issue I've run across is trying to figure out how to display fanart on the homescreen. I love having the ability to create my own custom library views! I don't think my anatomy homework will get done this weekend thanks to this skin If I notice any bugs, I'll post a log file. Thanks!
Are you sure you installed the latest Jarvis dev build ? This should not happen. Will investigate.
For Home fanart see my reply to Saner some posts above. I will try to get this working ASAP.
(2015-08-28, 19:26)bitterkitten Wrote: [ -> ]Erm yeah, that's what I thought. Don't try using it on isengard or you're going to get real bad experiences like buttons / textboxes not showing and some weird navigation issues.(2015-08-28, 18:58)Jayz2K Wrote: [ -> ](2015-08-28, 18:48)bitterkitten Wrote: [ -> ]I tried to install KOver by the normal way but got a failed to meet dependencies notification so I extracted the zip directly into the addons folder. After a restart, I was able to run it! Steep learning curve (that's usually the sign of a great skin) but it looks amazing. The only issue I've run across is trying to figure out how to display fanart on the homescreen. I love having the ability to create my own custom library views! I don't think my anatomy homework will get done this weekend thanks to this skin If I notice any bugs, I'll post a log file. Thanks!
No, I'm running Isengard still but I'll install Jarvis tonight. And the fanart is no biggie, I understand that you have a "real" job! Thanks for the quick reply.
(2015-08-29, 00:55)BobCratchett Wrote: [ -> ]I've spent the evening playing around with the beta skin and there is only one word for it: Wow.
The time and effort that have gone into creating something that is as customisable as this is incredible, and I tip my hat to you. The only - and I really do mean the ONLY - thing missing are the recent changes to the Skin Shortcuts script (most notably the new - but-not-yet-on-the-repo - widgets and templates stuff (which I'll undoubtedly add myself because this is going to become my households new default skin, and will then PR if that's all right with you).
Other than that, this is not only amazingly customisable but a genuinely usable skin (which isn't a given, when so many aspects can be customised - it would have taken just one element that could have been customised that shouldn't be able to be, and the user would be able to create an unusable skin) that I think this is the most impressible Kodi-related thing I have ever seen.
To sum up, even with the risk of repeating myself: Wow!
(2015-08-29, 11:53)clubfilth Wrote: [ -> ]Will this skin become availeble for kodi isengard?Just Tested the latest 15.2RC because I didn't follow the backported features. The most ennoying thing is the autowidth buttons I use so you see them 1 pixel. Other than that (which makes it not really usable) it starts. Rewriting all the buttons to match the text sizes is not really my priority actually, sorry.
It looks amazing!
(2015-08-30, 18:35)jdoo Wrote: [ -> ]Anyone have any layouts they want to share? I have been messing around with the customizer but still getting the hang of things.I will try later to upload to git some templates and colorschemes in the extra folder. You will be able to import them from the top right button of the designer. I'll tell when it's done.
