2016-03-22, 22:02
2016-03-22, 22:55
cURL?
the image is not found:
it's interesting because the video file works perfect over UPnP
http://172.27.2.12:1645/%25/1CE342C656B4...5emhoU.jpg --> Not Found
http://172.27.2.12:1645/%25/511AA543229C...-1080p.mkv --> OK
Quote:Not Found
The requested URL was not found on this server.
2016-03-22, 22:59
is that file on the server, the movie file is there but perhaps the jpg is missing
2016-03-22, 23:05
i don't have images next to my video files (on a NAS) but my KODI on openELEC can deliver art over UPnP
afaik are the images taken from the Thumbnails folder - also on headless Kodi the Thumnails folder exist and is filled with art after using the kodi web site to fetch all the images but the UPnP Server doesn't know where to take the images from
2016-03-29, 14:54
(2016-03-13, 12:47)celedhrim Wrote: [ -> ]Hi,
I have rework jarvis Dockerfile.
Now base on ubuntu 16.04 ( new lts) , this LTS reintroduice ffmpeg , so I now build kodi with system ffmpeg to reduce image build time.
Hello,
Just a dummy question.
Is it possible to run your image on a NAS running OMV with the docker plugin?
Just asking because you mention thath your dockerfile is based on ubuntu 16.04, but OMV is based on Debian 7.0
thanks
2016-03-29, 15:02
(2016-03-29, 14:54)mika91 Wrote: [ -> ](2016-03-13, 12:47)celedhrim Wrote: [ -> ]Hi,
Hello,
thanks
It's ubuntu inside the container , every thing that can run docker can launch the container , whatever inside.
Tis is the Docker technology primary goal
2016-03-29, 16:33
ok thanks
Another question: in the future, how can I add a source and set its content and scapper language?
Do I have to use a full GUI kodi for adding and configuring the new source?
Then it will automaticaly update the kodi-headless sources.xml and where-ever-it-is content type files ?
Or I need to copy the .kodi/userdata fodler again?
2016-03-29, 16:43
You can share source over network : http://kodi.wiki/view/MySQL/Sync_other_p...di#Sources
But if you add a new scrapper addon , you need to add it to the kodi-headless ( editing the server profile)
Personnally , I use copy :
- stop container
- launch a full kodi with the server-profile
- Do what I want
- copy back the server profile
- start the container
BUt I rarely change source / scrapper ( 0 time last year ! )
- stop container
- Do what I want
2016-04-01, 10:58
ok thanks.
I successfully installed docker yesterday, and the image seems to run.
But when I check log, after a library update, I have the following error:
My folders have the same permission: 775 root:users
Do I need to add a "docker" or anything else user to my 'users' group.
Or maybe docker runs as root user?
08:48:28 T:139832902321920 NOTICE: VideoInfoScanner: Starting scan ..
08:48:29 T:139832659539712 ERROR: SetThreadInfo: error Permission denied
08:48:30 T:139832902321920 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:02
2016-04-01, 11:08
Image run as root.
The error is normal , try to add content and see if it's really add , it's the best way to validate
2016-04-01, 11:27
ok.
Just made a test adding a fake new movie.
So it seems everything worked fine!
Just a few more questions:
Thanks a lot for your work and support.
09:08:26 T:139776477202176 DEBUG: VideoInfoScanner: Finished adding information from dir smb://192.168.1.10/Movies/Films/Million Dollar Baby
- I had to to manualy run a 'xmbc-send' to update the library.
Is your image compatible with an headless watchdog addon?
Or maybe use a 'xbmc-send' cron job combined with sickrage/couchpotato notifications?
- On my RPI clients, many videos miss the codecs flags (HD/SD, codecs, ...). Those informations are stored in the DB too? Retrieve after scrapping? Compatble with smb shares?
2016-04-21, 04:01
Sorry for asking but what is needed to run this version on a RPi and is version 16 supported? also will the system still be usable for other functions?
Thanks,
Yonu
Thanks,
Yonu
2016-04-24, 21:19
ok now I am going to ask I have been looking at Docker but I am trying to figure out is it possible to run it on top of an existing copy of raspbian. would anyone mind poing my towards any help on getting it setup?
Thanks,
Yonu
Thanks,
Yonu
2016-04-25, 14:44
https://github.com/Celedhrim/docker-kodi-server
Master & jarvis branch update to 16.1
I don't know if it would be better to create a specific thread for docker kodi ( supplementary tool / developpement ?).
Now we talk docker kodi server in middle of other thread about headless and not docker specific .
2016-04-25, 21:44
(2016-04-25, 14:44)celedhrim Wrote: [ -> ]https://github.com/Celedhrim/docker-kodi-server
Many thanks for your work celedhrim!
Yes, I also think that you should open a new specific thread about docker support in Kodi and leave this for a more generic way of installing a headless instance of Kodi
I would also like to ask you about this error that I'm seeing using your docker container:
19:14:06 T:140411599316736 NOTICE: WakeOnAccess [192.168.1.100] trigged by accessing : MySQL : MyVideos99
19:14:06 T:140411599316736 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:06 T:140411599316736 INFO: WakeOnLan - Magic packet send to 'xx:xx:xx:xx:xx:xx'
19:14:07 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:07 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:07 T:140411599316736 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:09 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:09 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:09 T:140411599316736 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:10 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:10 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:10 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:12 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:12 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:12 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:13 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:13 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:13 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:15 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:15 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:15 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:16 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:16 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:16 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:18 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:18 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:18 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:19 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:19 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:19 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:21 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:21 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:21 T:140411599316736 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:22 T:140412834526976 ERROR: Previous line repeats 11 times.
19:14:22 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:22 T:140411599316736 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:24 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:24 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:24 T:140411599316736 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:25 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:25 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:25 T:140411599316736 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:27 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:27 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:27 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:28 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:28 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:28 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:30 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:30 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:30 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:31 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:31 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:32 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:33 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:33 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:33 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:35 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:35 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:35 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:14:36 T:140412834526976 ERROR: Previous line repeats 13 times.
19:14:36 T:140412834526976 DEBUG: webserver: request received for /jsonrpc
19:14:36 T:140412842919680 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:15:24 T:140412842919680 ERROR: Previous line repeats 437 times.
19:15:24 T:140412842919680 NOTICE: WakeOnAccess timeout/cancel while waiting for response
19:15:24 T:140412842919680 WARNING: WakeOnAccess failed to bring up [192.168.1.100] - there may be trouble ahead !
19:15:24 T:140411599316736 ERROR: Ping fail : status = 32512, errno = 0 : 'ping -c 1 -w 1 192.168.1.100'
19:15:26 T:140411599316736 ERROR: Previous line repeats 9 times.
19:15:26 T:140411599316736 NOTICE: WakeOnAccess timeout/cancel while waiting for response
19:15:26 T:140411599316736 WARNING: WakeOnAccess failed to bring up [192.168.1.100] - there may be trouble ahead !
My docker host is a Ubuntu Server 14.04 machine (192.168.1.100) running a MySQL database.
Do you know what is happening here? It seems that the "ping" command is not installed by default in Ubuntu and that it can be installed using "apt-get install inetutils-tools inetutils-ping". As Kodi seems to use the ping command after executing a WakeOnLan command to ensure that the remote machine is awake, could you add the "ping" command to your docker container?
Many thanks again for all your work and if you need more information don't hesitate to ask.
Best regards,
Aitor
