(2019-09-15, 21:24)hmoney001 Wrote: [ -> ]The system was upgraded to the AMD APU in May and I have been having this issue since build #0528. All the 10bit files I've tested will freeze when seeking/skipping to a different chapter.
Sorry to be pedantic - "in May" is a little vague, but from this statement am I correct to infer that the AMD APU with #0527 does *not* have this issue?
(2019-09-15, 21:24)hmoney001 Wrote: [ -> ]Which log would best capture this?
A kodi
debug log (wiki) (enable debug logging, then reboot). Reproduce the issue (but don't restart Kodi) then connect over ssh and execute the command
pastekodi
and post the link.
New LibreELEC.tv Matrix build #0915:
Generic
(Supercedes previous build)
SHA256 Checksum:
5dbba691b1bd15568dabe7cd2d512a3e024f450699f20073adca126da30f7760
(Generic)
text:
# uname -a
Linux NUC 5.2.13 #1 SMP Sun Sep 15 21:03:20 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190915210239-#0915-gd799b5a [Build #0915]
# Kodi version
Kodi (19.0-ALPHA1 Git:f95ee82). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (d799b5a,
changelog) and tip of
XBMC master (f95ee82,
- Includes latest kodi-platform master (809c5e9, ahead +2)
- Includes latest libcec master (ba9b538, ahead +1)
- Includes latest libnfs master (4de9fb8, ahead +4)
- Includes latest p8-platform master (cee64e9)
- Includes latest addons: inputstream.adaptive (54ef24e, +19), inputstream.rtmp (ce68b77, +1), peripheral.joystick (4223dad, +2), peripheral.xarcade (51e1a45, +7), pvr.argustv (a8a1ad2, +17), pvr.demo (59e3374, +14), pvr.dvblink (f31aa1a, +17), pvr.dvbviewer (023bd0c, +13), pvr.filmon (7f62242, +15), pvr.freebox (7fb6d44, +10), pvr.hdhomerun (4465445, +14), pvr.hts (e96fdd1, +14), pvr.iptvsimple (72e0b41, +85), pvr.mediaportal.tvserver (84c35b3, +19), pvr.mythtv (dd512aa, +35), pvr.nextpvr (0131278, +16), pvr.njoy (fdffa7d, +17), pvr.octonet (14d3e9d, +9), pvr.pctv (31d8278, +15), pvr.sledovanitv.cz (0384d67, +13), pvr.stalker (4bdf7f3, +8), pvr.teleboy (ace6ad6, +6), pvr.vbox (c665693, +10), pvr.vdr.vnsi (612c1f9, +11), pvr.vuplus (d5c9a74, +84), pvr.waipu (cf8e3f2, +32), pvr.wmc (cfab2b0, +8), pvr.zattoo (ec85eda, +5), vfs.libarchive (bb9bda3, +12), vfs.rar (b688a56, +9), vfs.sftp (1c95802, +19)
- Include [env] compare (perma): kodi19: next
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: mesonbuild: update to 0.51.2
- Include [env] patch: linux (RPi): 5.2.13 update with new DACs
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: graphic: use GLVND to dispatch graphic API calls
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3667 (perma): libbluray: update to 1.1.2
- Include [env] PR:3774 (perma): tinyxml2: update to tinyxml2-7.1.0
- Include [env] PR:3793 (perma): RPi btuart: Sync with upstream 0.1.11
- Include [env] PR:3796 (perma): buildsystem: more fixups
- Include [env] PR:3797 (perma): freetype: update to freetype-2.10.1
- Include [env] PR:3804 (perma): fix filesystem corruption on reboot/shutdown
- Include [env] PR:3807 (perma): rpi-eeprom: update to rpi-eeprom-48a2302
- Include [env] PR:3811 (perma): xf86-video-nvidia: update to xf86-video-nvidia-430.50
- Include [env] PR:3817 (perma): kodi: add pastekodi script
- Include [env] PR:3818 (perma): eventlircd: adding new rule for iMON Panel, Knob and Mouse(15c2:ffdc)
- Include [env] PR:3825 (perma): busybox: init: mount squashfs early
- Revert [env] PR:3698 ([url=]perma[/url]): kodi: building with ninja makes xbmc/1600 more likely - don't use ninja
- Include [pkg] patch: kodi: fix addon platform_tag (kodi)
- Include [pkg] PR:16216 (perma): resolution whitelist version 2
Build Highlights:
- [PVR] Fix: we must close all open modal dialogs before we can activate the PVR search window
Build Details:
- LibreELEC.tv:
- systemd: update to systemd-243 (PR:3794, 1 commit, 3 files changed)
- [le10] hyperion: Update to version 2019-08-19 (PR:3808, 1 commit, 2 files changed)
- XBMC:
- Fix "queue item" and "play next" for STRM files with Plugin URL (PR:16604, 1 commit, 2 files changed)
- [PVR] Fix: we must close all open modal dialogs before we can activate the PVR search window. (PR:16612, 1 commit, 4 files changed)
- pvr.waipu:
- Improve formatting (PR:32, 1 commit, 10 files changed)
- Updated: [env] PR:3807 (perma): rpi-eeprom: update to rpi-eeprom-48a2302
- Updated: [env] PR:3817 (perma): kodi: add pastekodi script
New LibreELEC.tv Matrix build #0916:
Generic
SHA256 Checksum:
f06b8abb2c56b8d7bf8702bcf1dff2d5e9b3d0ff5493dc5e159228e2bf35a954
(Generic)
text:
# uname -a
Linux NUC 5.2.13 #1 SMP Mon Sep 16 21:03:22 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190916210242-#0916-gb419665 [Build #0916]
# Kodi version
Kodi (19.0-ALPHA1 Git:f5b3bf1). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (b419665,
XBMC master (f5b3bf1,
- Include [env] PR:3831 (perma): busybox: cleanup persistent log setup when debugging is enabled
Build Highlights:
- busybox: cleanup persistent log setup when debugging is enabled
- [screensaver.xbmc.builtin.dim] reduce dim minimum threshold to zero
Build Details:
- LibreELEC.tv:
- kodi: give kodi enough time to properly shut down (PR:3832, 1 commit, 1 file changed)
- XBMC:
- [modernize] use-bool-literals (PR:16625, 1 commit, 5 files changed)
- [fix] use value initialization after b9d11a2 (PR:16632, 1 commit, 1 file changed)
- [screensaver.xbmc.builtin.dim] reduce dim minimum threshold to zero (PR:16620, 1 commit, 2 files changed)
- added: Inhibit screensaver builtin (PR:16345, 1 commit, 4 files changed)
- Updated: [env] PR:3796 (perma): buildsystem: more fixups
- Added: [env] PR:3831 (perma): busybox: cleanup persistent log setup when debugging is enabled
New LibreELEC.tv Matrix build #0917:
Generic
SHA256 Checksum:
3ec5949670b6a36745ea8eb4ab55a9af0a8dade31fb1d7376f8c61755453cdaa
(Generic)
text:
# uname -a
Linux NUC 5.3.0 #1 SMP Tue Sep 17 21:04:20 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190917210337-#0917-gb419665 [Build #0917]
# Kodi version
Based on tip of
- Includes latest addons: inputstream.adaptive (54ef24e, +19), inputstream.rtmp (ce68b77, +1), peripheral.joystick (4223dad, +2), peripheral.xarcade (51e1a45, +7), pvr.argustv (a8a1ad2, +17), pvr.demo (59e3374, +14), pvr.dvblink (917cea0, +18), pvr.dvbviewer (861cd34, +14), pvr.filmon (59ea0a7, +16), pvr.freebox (7fb6d44, +10), pvr.hdhomerun (4465445, +14), pvr.hts (e96fdd1, +14), pvr.iptvsimple (72e0b41, +85), pvr.mediaportal.tvserver (84c35b3, +19), pvr.mythtv (dd512aa, +35), pvr.nextpvr (10a162d, +17), pvr.njoy (fdffa7d, +17), pvr.octonet (14d3e9d, +9), pvr.pctv (31d8278, +15), pvr.sledovanitv.cz (0384d67, +13), pvr.stalker (4bdf7f3, +8), pvr.teleboy (ace6ad6, +6), pvr.vbox (1a1beb6, +11), pvr.vdr.vnsi (e62073a, +12), pvr.vuplus (d5c9a74, +84), pvr.waipu (cf8e3f2, +32), pvr.wmc (cfab2b0, +8), pvr.zattoo (ec85eda, +5), vfs.libarchive (bb9bda3, +12), vfs.rar (b688a56, +9), vfs.sftp (1c95802, +19)
- Include [env] PR:3716 (perma): linux (RPi/Generic): update to linux-5.3
- Include [env] PR:3840 (perma): mesa: update to mesa-19.1.7
Build Highlights:
- New 5.3.0 kernel
- mesa: update to mesa-19.1.7
Build Details:
- pvr.dvblink:
- [lang] updated language files from Transifex (917cea0)
- pvr.dvbviewer:
- [lang] updated language files from Transifex (861cd34)
- pvr.filmon:
- [lang] updated language files from Transifex (59ea0a7)
- pvr.nextpvr:
- [lang] updated language files from Transifex (10a162d)
- pvr.vbox:
- [lang] updated language files from Transifex (1a1beb6)
- pvr.vdr.vnsi:
- [lang] updated language files from Transifex (e62073a)
- Added: [env] PR:3716 (perma): linux (RPi/Generic): update to linux-5.3
- Added: [env] PR:3840 (perma): mesa: update to mesa-19.1.7
New LibreELEC.tv Matrix build #0918:
Generic
SHA256 Checksum:
c8fb7d493ef3a1a4c444b885c9e546e64ce596aa3523843ac85865d69454632c
(Generic)
text:
# uname -a
Linux NUC 5.3.0 #1 SMP Wed Sep 18 21:03:14 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190918210234-#0918-ga404c44 [Build #0918]
# Kodi version
Kodi (19.0-ALPHA1 Git:a689d1c). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (a404c44,
XBMC master (a689d1c,
- Include [env] PR:3843 (perma): systemd: use upstream method to enable and configure debug shell
Build Highlights:
- intel-ucode: update to intel-ucode-20190918
- systemd: use upstream method to enable and configure debug shell
- [binary addons] use VERSION_MIN instead VERSION for dependency checks
Build Details:
- LibreELEC.tv:
- Amlogic: cleanup options (PR:3828, 1 commit, 1 file changed)
- Amlogic: eliminate config prompts; align compression and drivers with other projects (PR:3841, 4 commits, 2 files changed)
- xf86-video-nvidia: update to xf86-video-nvidia-430.50 (PR:3811, 1 commit, 2 files changed)
- imagedecoder.heif addon (PR:3830, 3 commits, 3 files changed)
- init: make copying SYSTEM to RAM opt-in (PR:3820, 1 commit, 1 file changed)
- graphic: use GLVND to dispatch graphic API calls (PR:3790, 5 commits, 6 files changed)
- fix filesystem corruption on reboot/shutdown (PR:3804, 3 commits, 3 files changed)
- XBMC:
- [modernize] use-emplace (PR:16615, 1 commit, 100 files changed)
- [binary addons] use VERSION_MIN instead VERSION for dependency checks (PR:16591, 1 commit, 23 files changed)
- Updated: [env] patch: mesonbuild: update to 0.51.2
- Updated: [env] PR:3716 (perma): linux (RPi/Generic): update to linux-5.3
- Updated: [env] PR:3825 (perma): busybox: init: mount squashfs early
- Added: [env] PR:3843 (perma): systemd: use upstream method to enable and configure debug shell
New LibreELEC.tv Matrix build #0919:
Generic
SHA256 Checksum:
213ef882ac6305c6f1dfe71509bddd4e4f05299850a3082f0168906b24a31aa1
(Generic)
text:
# uname -a
Linux NUC 5.3.0 #1 SMP Thu Sep 19 22:26:20 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190919222540-#0919-gc44ba72 [Build #0919]
# Kodi version
Kodi (19.0-ALPHA1 Git:69ea64a). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (c44ba72,
XBMC master (69ea64a,
- Include [env] PR:3853 (perma): init: add fix for RPi4 serial numbers
- Include [pkg] PR:136 (perma): Stop referencing non-existant window (service.libreelec.settings)
- Include [pkg] PR:137 (perma): Disable firmware flashing when network booting (service.libreelec.settings)
Build Highlights:
- [addons] fix addon version.h, do not give nullptr as string
- [Estuary][PVR] DialogPVRInfo: Add support for 'first aired' and 'rating'
Build Details:
- LibreELEC.tv:
- [GLVND] restore the mess in some graphic packages (PR:3849, 3 commits, 3 files changed)
- linux: update Amlogic to 5.3.0 (PR:3842, 1 commit, 188 files changed)
- Revert "Merge pull request #3841 from MilhouseVH/le10_amlogic_cleanup" (PR:3851, 1 commit, 2 files changed)
- mesonbuild: update to 0.51.2 (PR:3776, 8 commits, 9 files changed)
- linux (RPi/Generic): update to linux-5.3 (PR:3716, 34 commits, 15 files changed)
- Allwinner: Update to Linux 5.3 (PR:3806, 2 commits, 13 files changed)
- Allwinner: ffmpeg: Update v4l2 request api chain (PR:3852, 2 commits, 14 files changed)
- XBMC:
- [addons] fix addon version.h, do not give nullptr as string (PR:16641, 1 commit, 1 file changed)
- [application] Fix CApplication::ActivateScreenSaver to always allow 'Black' screen saver. Closes #16123. (PR:16636, 1 commit, 1 file changed)
- [PVR] Cleanup: Replace Observer/Observable with EventSource/EventStream. (PR:16637, 1 commit, 27 files changed)
- [Estuary][PVR] DialogPVRInfo: Add support for 'first aired' and 'rating' (PR:16640, 2 commits, 2 files changed)
- [depends] bump fribidi to 1.0.5 (PR:16606, 1 commit, 1 file changed)
- Added: [env] PR:3853 (perma): init: add fix for RPi4 serial numbers
- Added: [pkg] PR:136 (perma): Stop referencing non-existant window (service.libreelec.settings)
- Added: [pkg] PR:137 (perma): Disable firmware flashing when network booting (service.libreelec.settings)
New LibreELEC.tv Matrix build #0920:
Generic
SHA256 Checksum:
74f2fa5c541eb7d46377253514b5503d776320ce63c3714f5d0e0efbf95f21c9
(Generic)
text:
# uname -a
Linux NUC 5.3.0 #1 SMP Sat Sep 21 00:48:41 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190921004757-#0920-g77a2119 [Build #0920]
# Kodi version
Kodi (19.0-ALPHA1 Git:35e6ca1). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (77a2119,
XBMC master (35e6ca1,
- Include [env] PR:3854 (perma): bluez: update to bluez-5.51
- Include [env] PR:3857 (perma): linux (Mainline/RPi): update to linux-5.3.5
- Include [env] PR:3858 (perma): dosfstools/e2fsprogs: update to latest
Build Highlights:
- bluez: update to bluez-5.51
- dosfstools/e2fsprogs: update to latest
- kodi: Cmake cpp14
Build Details:
- LibreELEC.tv:
- Allwinner: Update kernel configs (PR:3855, 1 commit, 2 files changed)
- XBMC:
- Cmake cpp14 (PR:13034, 3 commits, 14 files changed)
- Added: [env] PR:3854 (perma): bluez: update to bluez-5.51
- Added: [env] PR:3857 (perma): linux (Mainline/RPi): update to linux-5.3.5
- Added: [env] PR:3858 (perma): dosfstools/e2fsprogs: update to latest
New LibreELEC.tv Matrix build #0921:
Generic
SHA256 Checksum:
2793608978918eac521588aac7b7105cee0f61f603f16a1946563b1bd582a860
(Generic)
text:
# uname -a
Linux NUC 5.3.1 #1 SMP Sun Sep 22 00:43:18 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190922004236-#0921-g77a2119 [Build #0921]
# Kodi version
Kodi (19.0-ALPHA1 Git:1842103). Platform: Linux x86 64-bit
Based on tip of
XBMC master (1842103,
- Includes latest addons: inputstream.adaptive (54ef24e, +19), inputstream.rtmp (ce68b77, +1), peripheral.joystick (4223dad, +2), peripheral.xarcade (51e1a45, +7), pvr.argustv (a8a1ad2, +17), pvr.demo (59e3374, +14), pvr.dvblink (917cea0, +18), pvr.dvbviewer (861cd34, +14), pvr.filmon (59ea0a7, +16), pvr.freebox (7fb6d44, +10), pvr.hdhomerun (4465445, +14), pvr.hts (e96fdd1, +14), pvr.iptvsimple (72e0b41, +85), pvr.mediaportal.tvserver (84c35b3, +19), pvr.mythtv (dd512aa, +35), pvr.nextpvr (10a162d, +17), pvr.njoy (fdffa7d, +17), pvr.octonet (14d3e9d, +9), pvr.pctv (31d8278, +15), pvr.sledovanitv.cz (0384d67, +13), pvr.stalker (ea4f292, +16), pvr.teleboy (e2dbf10, +9), pvr.vbox (1a1beb6, +11), pvr.vdr.vnsi (e62073a, +12), pvr.vuplus (d5c9a74, +84), pvr.waipu (cf8e3f2, +32), pvr.wmc (9aa5467, +15), pvr.zattoo (685f28d, +7), vfs.libarchive (bb9bda3, +12), vfs.rar (b688a56, +9), vfs.sftp (1c95802, +19)
- Include [env] PR:3856 (perma): init: fsck: wait for devices and unhide messages
- Include [env] PR:3862 (perma): bcmstat: update to bcmstat-0.5.3
Build Highlights:
- New 5.3.1 kernel
- init: fsck: wait for devices and unhide messages
Build Details:
- XBMC:
- fixed: make archive files work via UPnP (PR:16650, 1 commit, 1 file changed)
- pvr.stalker:
- [Matrix] update CMakeLists.txt to 3.5, remove one -fPIC use and change include way (PR:127, 8 commits, 12 files changed)
- pvr.teleboy:
- [Leia] update CMakeLists.txt to 3.5 (PR:23, 1 commit, 1 file changed)
- [Matrix] update CMakeLists.txt to 3.5 (PR:22, 2 commits, 3 files changed)
- Merge remote-tracking branch 'origin/Leia' into Matrix (e2dbf10)
- pvr.wmc:
- [Matrix] update CMakeLists.txt to 3.5 and change header include way (PR:72, 7 commits, 9 files changed)
- pvr.zattoo:
- [Matrix] update CMakeLists.txt to 3.5 (PR:56, 1 commit, 1 file changed)
- [Leia] update CMakeLists.txt to 3.5 (PR:55, 1 commit, 1 file changed)
- Change version to 19.2.1 related to Kodi API update and build changes (PR:54, 1 commit, 3 files changed)
- Merge remote-tracking branch 'origin/Leia' into Matrix (685f28d)
- Updated: [env] PR:3857 (perma): linux (Mainline/RPi): update to linux-5.3.5
- Added: [env] PR:3856 (perma): init: fsck: wait for devices and unhide messages
- Added: [env] PR:3862 (perma): bcmstat: update to bcmstat-0.5.3
Any changes to get hdr working on Gemini lake j5005 .on the night buld
(2019-09-22, 10:59)tomtomclub Wrote: [ -> ]Any changes to get hdr working on Gemini lake j5005 .on the night buld
If/when it is ready for testing, it will be mentioned.
New LibreELEC.tv Matrix build #0922:
Generic
SHA256 Checksum:
7b071367278cc302c6aabb8385fcbcff530286e06dbf3aa51ebccaeb25537b0b
(Generic)
text:
# uname -a
Linux NUC 5.3.1 #1 SMP Sun Sep 22 21:33:03 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190922213223-#0922-g77a2119 [Build #0922]
# Kodi version
Kodi (19.0-ALPHA1 Git:bf90ec9). Platform: Linux x86 64-bit
Based on tip of
XBMC master (bf90ec9,
- Includes latest addons: inputstream.adaptive (54ef24e, +19), inputstream.rtmp (ce68b77, +1), peripheral.joystick (4223dad, +2), peripheral.xarcade (51e1a45, +7), pvr.argustv (a8a1ad2, +17), pvr.demo (59e3374, +14), pvr.dvblink (917cea0, +18), pvr.dvbviewer (861cd34, +14), pvr.filmon (59ea0a7, +16), pvr.freebox (7fb6d44, +10), pvr.hdhomerun (4465445, +14), pvr.hts (e96fdd1, +14), pvr.iptvsimple (72e0b41, +85), pvr.mediaportal.tvserver (84c35b3, +19), pvr.mythtv (dd512aa, +35), pvr.nextpvr (10a162d, +17), pvr.njoy (fdffa7d, +17), pvr.octonet (14d3e9d, +9), pvr.pctv (31d8278, +15), pvr.sledovanitv.cz (0384d67, +13), pvr.stalker (ea4f292, +16), pvr.teleboy (e2dbf10, +9), pvr.vbox (1a1beb6, +11), pvr.vdr.vnsi (e62073a, +12), pvr.vuplus (d5c9a74, +84), pvr.waipu (cf8e3f2, +32), pvr.wmc (9aa5467, +15), pvr.zattoo (685f28d, +7), vfs.libarchive (bb9bda3, +12), vfs.rar (b688a56, +9), vfs.sftp (40e4a41, +20)
Build Highlights:
- [PVR][guiinfo][Estuary] New GUI info label Listitem.IsPremiere
Build Details:
- XBMC:
- [PVR][guiinfo][Estuary] New GUI info label Listitem.IsPremiere + impl (PR:16645, 1 commit, 8 files changed)
- vfs.sftp:
- fixed: Using ssh:// prefixes was broken (PR:43, 1 commit, 1 file changed)
New LibreELEC.tv Matrix build #0923:
Generic
SHA256 Checksum:
4c86a1f35ac00687b1081d7393ddcaf082c9577f75c304919ab77dbc0ac360dc
(Generic)
text:
# uname -a
Linux NUC 5.3.1 #1 SMP Mon Sep 23 22:14:09 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190923221328-#0923-g77a2119 [Build #0923]
# Kodi version
Kodi (19.0-ALPHA1 Git:a34bfcd). Platform: Linux x86 64-bit
Based on tip of
XBMC master (a34bfcd,
- Includes latest addons: inputstream.adaptive (54ef24e, +19), inputstream.rtmp (ce68b77, +1), peripheral.joystick (4223dad, +2), peripheral.xarcade (51e1a45, +7), pvr.argustv (a8a1ad2, +17), pvr.demo (59e3374, +14), pvr.dvblink (917cea0, +18), pvr.dvbviewer (861cd34, +14), pvr.filmon (59ea0a7, +16), pvr.freebox (7fb6d44, +10), pvr.hdhomerun (4465445, +14), pvr.hts (e96fdd1, +14), pvr.iptvsimple (1f42a62, +86), pvr.mediaportal.tvserver (84c35b3, +19), pvr.mythtv (dd512aa, +35), pvr.nextpvr (10a162d, +17), pvr.njoy (fdffa7d, +17), pvr.octonet (8032f08, +13), pvr.pctv (31d8278, +15), pvr.sledovanitv.cz (19e8297, +19), pvr.stalker (ea4f292, +16), pvr.teleboy (e2dbf10, +9), pvr.vbox (1a1beb6, +11), pvr.vdr.vnsi (e62073a, +12), pvr.vuplus (d5c9a74, +84), pvr.waipu (cf8e3f2, +32), pvr.wmc (9aa5467, +15), pvr.zattoo (685f28d, +7), vfs.libarchive (bb9bda3, +12), vfs.rar (b688a56, +9), vfs.sftp (40e4a41, +20)
- Include [env] PR:3859 (perma): llvm: update to llvm-9.0.0 / updated PKG_URL
- Include [env] PR:3860 (perma): pulseaudio: update to 13.0 / dropped upstreamed & renamed patch
- Include [env] PR:3861 (perma): open-vm-tools: update to open-vm-tools-stable-11.0.0
- Include [env] PR:3863 (perma): linux-drivers: update RTL drivers with kernel 5.3 support.
- Revert [env] PR:aba3fedea7dd21aa19c02fcf16d14a52b7d7603c (): RTL8812AU: Repository changed to use a newer version v5.1.5 vs v5.2.20.2. (reason: switch back to MilhouseVH repo)
- Revert [env] PR:3698 ([url=]perma): kodi: building with ninja makes xbmc/1600 more likely - don't use ninja
- Include [pkg] PR:5 (perma): linux-5.3: add raw vendor command policy (RTL8812AU)
- Include [pkg] PR:16642 (perma): [DemuxClient] Parse for mid stream changes (optional)
- Include [pkg] PR:16658 (perma): [VideoPlayer] Change avsync handling
- Include [pkg] PR:16667 (perma): [Inputstream] Make API backwards compatible to old addons
Build Highlights:
- Updated RTL8812AU with 5.3 policy fix
- llvm: update to llvm-9.0.0 / updated PKG_URL
- open-vm-tools: update to open-vm-tools-stable-11.0.0
- pulseaudio: update to 13.0 / dropped upstreamed & renamed patch
- [Log] Use Thread ID instead NativeHandle for logging
- [DemuxClient] Parse for mid stream changes (optional) and [VideoPlayer] Change avsync handling (peakd3)
Build Details:
- XBMC:
- Cleanup Music DirectoryNodes, inconsistent "*All" item and node labeling (PR:16626, 4 commits, 27 files changed)
- [Log] Use Thread ID instead NativeHandle for logging (PR:16655, 1 commit, 4 files changed)
- [addons] add interface helper class to translate "C" to "CPP" (PR:16649, 1 commit, 1 file changed)
- [Inputstream] Add IChapter interface (PR:16581, 1 commit, 7 files changed)
- pvr.iptvsimple:
- Speed up EPG loading (PR:283, 1 commit, 3 files changed)
- pvr.octonet:
- [Matrix] update CMakeLists.txt to 3.5 and change include way (PR:33, 4 commits, 9 files changed)
- pvr.sledovanitv.cz:
- [Matrix] update CMakeLists.txt to 3.5, change header include and increase version to 2.2.1 (PR:37, 6 commits, 8 files changed)
- Updated: [env] PR:3853 (perma): init: add fix for RPi4 serial numbers
- Updated: [env] PR:3858 (perma): dosfstools/e2fsprogs: update to latest
- Added: [env] PR:3859 (perma): llvm: update to llvm-9.0.0 / updated PKG_URL
- Added: [env] PR:3860 (perma): pulseaudio: update to 13.0 / dropped upstreamed & renamed patch
- Added: [env] PR:3861 (perma): open-vm-tools: update to open-vm-tools-stable-11.0.0
- Added: [env] PR:3863 (perma): linux-drivers: update RTL drivers with kernel 5.3 support.
- Reverted: [env] PR:aba3fedea7dd21aa19c02fcf16d14a52b7d7603c ([url=]perma[/url]): RTL8812AU: Repository changed to use a newer version v5.1.5 vs v5.2.20.2. (reason: switch back to MilhouseVH repo)
- Added: [pkg] PR:5 (perma): linux-5.3: add raw vendor command policy (RTL8812AU)
- Added: [pkg] PR:16642 (perma): [DemuxClient] Parse for mid stream changes (optional)
- Added: [pkg] PR:16658 (perma): [VideoPlayer] Change avsync handling
- Added: [pkg] PR:16667 (perma): [Inputstream] Make API backwards compatible to old addons
New LibreELEC.tv Matrix build #0924:
Generic
SHA256 Checksum:
fceb86a937d1a9c24a712dc93fc4a474d726b5046b2b05fe4123781152d55ca8
(Generic)
text:
# uname -a
Linux NUC 5.3.1 #1 SMP Tue Sep 24 22:17:40 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190924221701-#0924-g39f0f80 [Build #0924]
# Kodi version
Kodi (19.0-ALPHA1 Git:802f922). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (39f0f80,
XBMC master (802f922,
- Include [env] PR:3864 (perma): udev: fix systemd-243 warnings
Build Highlights:
- kernel-firmware: update to kernel-firmware-20190923
- udev: fix systemd-243 warnings
Build Details:
- LibreELEC.tv:
- Docs: add speed and size build flags to package.mk readme (PR:3839, 1 commit, 1 file changed)
- bcmstat: update to bcmstat-0.5.3 (PR:3862, 1 commit, 1 file changed)
- mesa: update to mesa-19.1.7 (PR:3840, 1 commit, 1 file changed)
- RPi btuart: Sync with upstream 0.1.11 (PR:3793, 1 commit, 1 file changed)
- kodi: add pastekodi script (PR:3817, 2 commits, 3 files changed)
- buildsystem: more fixups (PR:3796, 3 commits, 3 files changed)
- bluez: update to bluez-5.51 (PR:3854, 1 commit, 5 files changed)
- init: add fix for RPi4 serial numbers (PR:3853, 2 commits, 2 files changed)
- busybox: init: mount squashfs early (PR:3825, 3 commits, 1 file changed)
- busybox: cleanup persistent log setup when debugging is enabled (PR:3831, 1 commit, 4 files changed)
- systemd: use upstream method to enable and configure debug shell (PR:3843, 1 commit, 1 file changed)
- init: fsck: wait for devices and unhide messages (PR:3856, 1 commit, 1 file changed)
- XBMC:
- [cmake] give CMAKE_SYSTEM_NAME and CMAKE_SYSTEM_VERSION also to normal Windows (PR:16662, 1 commit, 1 file changed)
- [Inputstream] Make API backwards compatible to old addons (PR:16667, 1 commit, 1 file changed)
- [ios] fix broken touch input after closing keyboard on iOS 13 (PR:16582, 1 commit, 1 file changed)
- Updated: [env] PR:3861 (perma): open-vm-tools: update to open-vm-tools-stable-11.0.0
- Updated: [env] PR:3863 (perma): linux-drivers: update RTL drivers with kernel 5.3 support.
- Added: [env] PR:3864 (perma): udev: fix systemd-243 warnings
New LibreELEC.tv Matrix build #0925:
Generic
SHA256 Checksum:
37cbf3f9c0d20b2320c7d751d41d46dc0efae7ab773bb582d6bd9b8cca5a0db0
(Generic)
text:
# uname -a
Linux NUC 5.3.1 #1 SMP Wed Sep 25 21:13:00 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190925211218-#0925-g6a80bae [Build #0925]
# Kodi version
Kodi (19.0-ALPHA1 Git:4e8f965). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (6a80bae,
XBMC master (4e8f965,
- Include [env] PR:3869 (perma): xf86-video-nvidia/xf86-video-nvidia-legacy: use toolchain linker
- Include [env] PR:3870 (perma): mesa: update to mesa-19.2.0
Build Highlights:
- xf86-video-nvidia/xf86-video-nvidia-legacy: use toolchain linker
- mesa: update to mesa-19.2.0
Build Details:
- LibreELEC.tv:
- kodi: fix pastekodi efi check (PR:3867, 1 commit, 1 file changed)
- XBMC:
- [guiinfo]Fix Musicplayer.position(n).xyz and Musicplayer.offset(n).UserRating info labels (PR:16657, 2 commits, 3 files changed)
- add support for xcode 11 (PR:16668, 1 commit, 1 file changed)
- Updated: [env] PR:3864 (perma): udev: fix systemd-243 warnings
- Added: [env] PR:3869 (perma): xf86-video-nvidia/xf86-video-nvidia-legacy: use toolchain linker
- Added: [env] PR:3870 (perma): mesa: update to mesa-19.2.0
- Updated: [pkg] PR:137 (perma): Disable firmware flashing when network booting (service.libreelec.settings)
